RB VCARB 03
mzso
mzso
75
Re: RB VCARB 03
Cassius wrote:
20 Jan 2026, 14:14
Does it look like a significant high-rake design has been reintroduced?
The car just seem high in general
wiktor977
wiktor977
43
Re: RB VCARB 03
Badger
Badger
46
Re: RB VCARB 03
Damn, that's an air-plow :lol:
Without seeing the size of the sidepod inlets it's hard to judge the overall cooling requirement. Could also be a precautionary thing whilst they come to grips with the new engine.
It seems like they've opted for more center-line cooling though, the sidepods are clearly smaller.
_cerber1
302
Re: RB VCARB 03
Emag wrote:
20 Jan 2026, 14:35
What an absolute behemoth of an airbox. Very interesting detail regarding the cooling requirements of these power units.
Central cooling is back.
wiktor977
wiktor977
43
Re: RB VCARB 03
There are some small vertical vanes behind the floor board
Badger
Badger
46
Re: RB VCARB 03
wiktor977
wiktor977
43
Re: RB VCARB 03
Badger wrote:
20 Jan 2026, 14:49
Smaller than those on renders but they are not small, inlets are also pretty wide
sucof
39
Re: RB VCARB 03
Without seeing the CFD, I would think you would need smaller sidepods if you choose inwashing front wings, hence larger top inlet.
But this is the opposite here. Interesting.
Luscion
Luscion
153
Re: RB VCARB 03
Badger
Badger
46
Re: RB VCARB 03
wiktor977 wrote:
20 Jan 2026, 15:01
Badger wrote:
20 Jan 2026, 14:49
First gen cars usually have quite a lot of cooling and then it gets optimised with time. We'll need to see RBR and the others to judge what is the new normal.
I wouldn't say that the total area is huge because the sidepod inlets aren't that big, but centerline cooling does stand out more with the big airbox.
Giando
93
Re: RB VCARB 03
again, as already pointed out in the Cadillac thread, it seems that part of the "usual" floor in front of the rear tyres is missing, don't you think?
Dmkos
Dmkos
Re: RB VCARB 03
Badger
Badger
46
Re: RB VCARB 03
This explanation to me means that we can expect bigger airboxes in general. It's not for the ICE, it's for the hybrid system which makes perfect sense.
Emag
Emag
137
Re: RB VCARB 03
This car is quite similar to its renders actually, but the renders seem to have either been based on some early iteration, or they just went for a simpler representation of what they had. The airbox and engine cover for example were not shown, however the general sidepod shape + inlet is quite similar to the renders. Also the front wing actuators, which from what we have seen so far, this is the only team which has this solution as opposed to the other more "hidden" one (although this is to be taken with a grain of salt as we have only seen renders and some blurry images, can't say for certain what other teams have done).
In any case, this being a new regulation cycle, don't expect these cars to have crazy details visible from the get go. Especially considering how early FIA demanded them to go testing. Even in the first Bahrain test, it's likely the teams will have "simpler" cars that will be used for data correlation.
It was the same thing in Barcelona for 2022 cars. The initial iteration of floors were not overly complicated.
As for cooling, I don't see this as a surprise because many technical people had already anticipated that the 2026 cars, as they were described, had more challenging cooling requirements compared to the last gen. The RedBull livery render broke that expectation because it had both slim sidepods and a slim centerline, however we don't know if that's a real car or not.
This airbox though, even when you account for the challenging cooling requirements, is really big. I doubt the top teams will be like this.
Developer of F1InsightsHub
michl420
michl420
Re: RB VCARB 03
The sidepod inlet is reminiscent of the 2017 Ferrari. (side crash structure)
