RB VCARB 03
FW17
184
Re: RB VCARB 03
FW17
184
Re: RB VCARB 03
vorticism
vorticism
449
Re: RB VCARB 03
First sighting of floor stays in these regs.
Owen.C93
Owen.C93
189
Re: RB VCARB 03
Looks like the edge of the diffuser has some interesting details. Hard to see through the spray, but potentially some up flicks like the brake fairings used to have.
Giando
93
Re: RB VCARB 03
Is that a beam wing, sort of? Loophole found?
pantherxxx
pantherxxx
Re: RB VCARB 03
The packaging looks very compact here, given how much of the floor is visible at the back. Much narrower than Haas. Hopefully the Red Bull-Ford engine will be fine if they managed to make it this compact.
vorticism
vorticism
449
Re: RB VCARB 03
Giando wrote:
20 Jan 2026, 17:09
https://i.ibb.co/Q5Gfw1x/Screenshot-202 ... -36-36.png
Rear wing stay. A small single-element airfoil profile is permitted there to locate the endplates. It looks big there because it's blending in with the suspension arms.
Giando
93
Re: RB VCARB 03
vorticism wrote:
20 Jan 2026, 17:23
Giando wrote:
20 Jan 2026, 17:09
Ok clear. Thanks!
Nickel
Nickel
Re: RB VCARB 03
Is it just me or does that airbox look gargantuan?
edu2703
edu2703
37
Re: RB VCARB 03
Nickel wrote:
20 Jan 2026, 17:59
prox
Re: RB VCARB 03
Cassius wrote:
20 Jan 2026, 14:14
Does it look like a significant high-rake design has been reintroduced?
The car will look higher than normal as its on full wets
FW17
184
Re: RB VCARB 03
edu2703 wrote:
20 Jan 2026, 18:03
Nickel wrote:
20 Jan 2026, 17:59
https://pbs.twimg.com/media/G_HlphIWQAI ... name=large
not much larger than STR 10
They had put one of the ERS cooler on the sides of the fuel tank, others had done on top of the intake manifold
Badger
Badger
46
Re: RB VCARB 03
BorisTheBlade
50
Re: RB VCARB 03
Emag wrote:
20 Jan 2026, 15:39
As for cooling, I don't see this as a surprise because many technical people had already anticipated that the 2026 cars, as they were described, had more challenging cooling requirements compared to the last gen. The RedBull livery render broke that expectation because it had both slim sidepods and a slim centerline, however we don't know if that's a real car or not.
Honest question: What is the reasoning behind this stance?
As I see it, Thermal Efficiency of the ICE should be one of the highest priorities on everyone's list in order to maximize usable power and energy recovery for the max. 833 KW provided. The same goes for the whole electrical part, which should be well above 90% TE for recovery as well as supply. So there is not a lot of heat to be produced by the latter one.
What else is there that should require lots of cooling?
I would rather suspect, that centre line cooling does not cost a lot of already much less RW downforce, while giving you design freedom for the sidepods in order to work the floor as good as you can.
Seanspeed
Seanspeed
Re: RB VCARB 03
Emag wrote:
20 Jan 2026, 15:39
however the general sidepod shape + inlet is quite similar to the renders.
Sidepods are definitely different.
EDIT: ah geez, are those site ads showing up on my photos for everybody else, too? Really need to find a better place for image hosting I guess. smh
EDIT2: Based on newer pics, perhaps sidepods are actually the same. Looked steeper in the angle of the photo above, but not so elsewhere.
