Mercedes W17
Re: Mercedes W17
23 Jan 2026, 02:04
There is something funny going on with the front brake ducts. What is this? :lol:
https://i.postimg.cc/CxCZw3h6/image.png
:shock:
#ReleasetheADUO
Longley
Longley
Re: Mercedes W17
23 Jan 2026, 02:04
Seems like Mercedes goes back to a solution used with the W06
Lasssept
122
Re: Mercedes W17
inst ckrphotography__
Stu
Re: Mercedes W17
23 Jan 2026, 02:04
Possibly a very old school solution, similar to late 80’s/early 90’s when the front wing endplates were similarly located in relation to the tyre and ‘simple’ front wing profiles were
https://share.google/1S8O462wzifR3Naom
Badger
Badger
46
Re: Mercedes W17
The way these cars are going to be driven there will be much less energy going through the front brakes. It makes sense to have smaller brake ducts, and I guess one solution is what Merc has done here.
ScottB
ScottB
Re: Mercedes W17
Badger wrote:
23 Jan 2026, 10:06
Didn't Brembo flag last year there was a big difference in brake disc sizes some teams had been asking for, with some going very aggressive etc etc
Makes sense that will turn up in things like this I guess!
matteosc
matteosc
32
Re: Mercedes W17
What are your toughts about this? Something interesting about the front wing and (maybe most importantly) the diffuser.
https://www.youtube.com/watch?v=zYqi-qvOkNI
De Wet
Re: Mercedes W17
Craig Scarborough:
Lasssept
122
Re: Mercedes W17
Seanspeed
Seanspeed
Re: Mercedes W17
Badger wrote:
23 Jan 2026, 10:06
Aren't we expecting them to spend less overall time on the straights, though?
michl420
michl420
Re: Mercedes W17
ScottB wrote:
23 Jan 2026, 11:21
Badger wrote:
23 Jan 2026, 10:06
Brembo said that primarily about rear brakes.
Badger
Badger
46
Re: Mercedes W17
Seanspeed wrote:
23 Jan 2026, 14:39
Badger wrote:
23 Jan 2026, 10:06
We're expecting them to spend a lot of time harvesting at the end of the straights, that 350 kW MGU-K will be doing a lot of the retardation, putting less strain on the front and rear brakes.
670
Re: Mercedes W17
Badger wrote:
23 Jan 2026, 15:08
Badger wrote:
23 Jan 2026, 10:06
The way these cars are going to be driven there will be much less energy going through the front brakes. ...
... that 350 kW MGU-K will be doing a lot of the retardation, putting less strain on the front and rear brakes.
well .....
the front brakes will still be braking up to the limit of the grip of the front tyres ....
so we could say that the 'strain' on the front brakes isn't relieved
ok it's relieved to the extent of the all-round reduced tyre grip due to the reduced aero DF
Badger
Badger
46
Re: Mercedes W17
Tommy Cookers wrote:
23 Jan 2026, 15:24
Badger wrote:
23 Jan 2026, 15:08
Badger wrote:
23 Jan 2026, 10:06
well .....
I disagree. The aim in the braking zone will not be to slow the car at the fastest possible rate like before, it will be to regenerate as much energy as possible. The way to do that will be to maximise the 350 kW regen for the most amount of time. The more energy you absorb at the front brakes the less energy you can harvest at the rear. There will therefore be less energy going through the front brakes which equals less brake cooling required.
matteosc
matteosc
32
Re: Mercedes W17
Badger wrote:
23 Jan 2026, 15:41
23 Jan 2026, 15:24
Badger wrote:
23 Jan 2026, 15:08
well .....
That is true, but it would be slower in that specific corner. It may be faster overall, but that depends on a lot of factor and it will likely be different in qualifying vs race. Bottomline, the front brakes may be designed to break at the limit.
Another thing to remember is that this year's cars are lighter, which should help.
