Red Bull RB22
Re: Red Bull RB22
Front brake duct/debris shield detailing
Floor edge and outboard face of bargeboard upwashing detail
ME4ME
82
Re: Red Bull RB22
Looks like the front wing flap actuator linkage is coming out near the side of the nose and connects to a structural metal member connecting the 2nd and 3rd flap.
Re: Red Bull RB22
26 Jan 2026, 12:08
https://i.ibb.co/Q7Pr6Q0s/20260126-115832-2.jpg
https://i.ibb.co/mVXnFKFZ/20260126-115832-1.jpg
lol that diffuser side is completely open
Re: Red Bull RB22
I don't understand the diffuser sidewall. What am I looking at?
#ReleasetheADUO
vorticism
vorticism
449
Re: Red Bull RB22
vorticism wrote:
26 Jan 2026, 12:08
First sidepod cannon exits we’ve seen this year. What I alluded to back in June.
https://www.f1technical.net/forum/viewt ... 1#p1293691
Trailing the side headrest.
vorticism
vorticism
449
Re: Red Bull RB22
26 Jan 2026, 12:10
There's an allowance for it. Viewed from the side, the diffuser sidewall only has to exist within a small area (a polygon defined in the regs). Hence these gaps we've been seeing--an intentional allowance by the FIA. No loopholes here. The vertical element you see to the side of the diffuser hole is a wheel-mounted turning vane (a standard part common to all teams, similar to the previous regulations' various shared winglets). The diffuser can also be continuous with no cut-outs. That is also an option.
nico5
25
Re: Red Bull RB22
Did RB not get the memo there's no OP bargeboards like in 2020, or do they wanna be Merc 2022 2.0?
Lasssept
122
Re: Red Bull RB22
discojesus100
discojesus100
Re: Red Bull RB22
Zero undercut at the front of the sidepod like it’s 1999
Emag
Emag
137
Re: Red Bull RB22
discojesus100 wrote:
26 Jan 2026, 13:20
It's because the sidepod is very small. Almost half in width compared to the likes of Mercedes and Ferrari, and it's also almost completely "pressed-against" the body. This is basically a zero pod but with a horizontal inlet instead of vertical.
Developer of F1InsightsHub
SiLo
144
Re: Red Bull RB22
26 Jan 2026, 13:20
Reminds me of the Sauber C31 sidepods.
Felipe Baby!
matt_b
matt_b
Re: Red Bull RB22
Need to see more angles but it looks like a Mercedes 2023 sidepod with a horizonal inlet rather than vertical one, their thinking must be that the minimal sidepod design can work to good effect under these reguilations. You would think Mercedes wouldve looked into this given the data they gathered over those years.
wiktor977
wiktor977
43
Re: Red Bull RB22
matt_b wrote:
26 Jan 2026, 13:46
Or they have PTSD, and words like 'zero-pod' or minimal sidepods are prohibited in their factory
Re: Red Bull RB22
It's a zero pod done right!
I mean zero pod was not compatible with Ground effect floors but it might be a silver bullet in these regs!
ScottB
ScottB
Re: Red Bull RB22
26 Jan 2026, 14:12
Didn't the zero pod start out as an idea for the pre ground effect car, they just didn't get to it?
Though does make sense that they might be too internally scarred to revisit the idea...
