2026 car comparisons
Badger
Badger
46
All the cars we've seen on track so far and the best images available.
Cadillac
Audi
So far I'd say Merc looks the most advanced in terms of tight packaging and innovative bits. Second is VCARB. Third Alpine.
chlebekf1
chlebekf1
Re: 2026 car comparisons
Mercedes 1 Alpine 2
Badger
Badger
46
lio007
327
I think with Cadillac, Ferrari and Merc we have 3 teams having a diffuser opening.
Cadillac
vorticism
vorticism
449
Merc and Ferrari:
-Similar sidepod undercuts
-Front wings preferencing installation stiffness. Merc centered the pylons within the wing area by way of the second element, which limits the FWAS to a single element. Ferrari carries both the center and the front of the wing area by way of a large first element, which allows a smaller two-element FWAS
All cars:
-They have the new side indicators. Very visible on the Ferrari. Little rectangular LED lights.
Giando
93
where i've seen those Ferrari and Mercedes sidepod shape before?
mmmm
f1316
88
Giando wrote:
23 Jan 2026, 16:49
mmmm
https://i.ibb.co/cKw2sGSK/Screenshot-20 ... -39-32.png
Yes, I’ve said this a few places but there’s definite trend towards the “coanda” style sidepods from 2012/13 (of the McLaren variety) this year. I guess it makes sense that they want to feed the diffuser airflow in a similar sense to how they wanted to feed it hot exhaust gases, but I do now wonder if it’s this diffuser “hole” trick that has pushed them in that direction now.
vorticism
vorticism
449
You both raise an interesting point, to me at least. Those Coanda type sidepods lofted the exhaust over top the inflow arriving from the undercut. If they end up using big cooling louvers or sidepod cannons it might again be a way to loft a heated airstream over the undercut inwash. Not necessarily to energize the diffuser but simply to steer the efflux through the rear suspension members which cause drag & turbulence anyway, so why not blast them with the radiator efflux while the diffuser gets clean undercut inwash. If the Meredith effect can be achieved below 300kph via tuned, short path ducting (sidepod cannons, f.e.) then the radiator outflow could be slightly more energetic than ambient airflow, in which case, maybe you would want them to feed the diffuser. Radiator blown diffuser.
vorticism wrote:
14 Aug 2025, 18:24
All told I see one major potential differentiation available across teams: a FWAS that has either one, two, or four rotating flaps. Another less visible one will be the choice to use a hydraulic piston or an electromechanical actuator.
Already all three FWAS variations have been seen.
4-element: VCARB, Ferrari, Haas
2-element: RB (rendering)
1-element: Mercedes
Correct me if I'm wrong but the regulations seem to indicate the there are also three potential rear wing variations:
1-element rear wing with no RWAS
2-element rear wing with 1-element RWAS
3-element rear wing with 2-element RWAS (all we've seen yet)
BassVirolla
vorticism wrote:
23 Jan 2026, 22:55
vorticism wrote:
14 Aug 2025, 18:24
1-element: Mercedes
Not for discrediting your ideas, but Meredith effect has been discussed before, and does not seem feasible for low speeds and "weird" sections (the effect seems very sensitive to the shape of the duct, as well as proportions of inlet vs outlet (looks like too much volume / section for an F1).
Nevertheless, if you could give some relevant insight, I'll be more than happy to know, and aknowledge it. I'm not an expert in aero nor thermodynamics, I just say what I've read some time ago.
euv2
euv2
Emag
Emag
137
With regards to the diffuser slot "loophole", I think it's probably not as big of a loophole as I initially thought.
It's apparently present (in a basic form) on the FIA finalized render :
Developer of F1InsightsHub
vorticism
vorticism
449
RBR arriving with a narrow engine cover compared to Merc and Ferrari's intentionally wide sidepods. RBR also bring the first sidepod cannon exits i.e. large louvers. What will Newey bring with AMR? There will have been some cross pollination given that Newey exited RBR while the '26 car would have been in development.
BassVirolla wrote:
25 Jan 2026, 22:43
For lack of a better term I use it, because it simply implies otherwise higher radiator efflux velocity--if it can approach free stream velocity (ambient airspeed) then it could be put to beneficial use with other aero components. In this context it wouldn't be about producing thrust, necessarily, only that it might not be consider dirty air as it usually is.
euv2
euv2
Red bulls diffuser hole looks quite weird, I think it's because we can't see the top and the side of the diffuser sidewalls join together.
Now that we've seen the pictures of Mclaren and Red Bull, it's proving my theory that there was some intense cross pollination between Mercedes and Ferrari.
Beware of T-Rex
euv2
euv2
26 Jan 2026, 12:41
https://x.com/Motor_Sport/status/201571 ... 99797?s=20
MCL and FER are quite similar too. I think the rest of the team have more differentiation.
