Red Bull RB22
venkyhere
43
Re: Red Bull RB22
Maybe the idea is to NOT go all guns blazing to keep 'out' the front wheel wake (albeit disposing some of it via the up-n-out-washing 'single bargeboard') and instead 'invite' what remains of it, (however stupid it may seem to invite turbulent dirty air) , to be 'cleaned up' by getting lost amidst a huge 'mass flow' towards the large rear coke bottle opening, which in turn is powered by the diffuser. Remember, there is no beamwing, so diffuser has to do a lot of 'heavy lifting' (or heavy suction rather), so maybe the way to go is to 'use' the front wheel wake ?
I am just shooting in the dark, but I am almost sure they found a way to 'do something with front wheel wake that others haven't thought of ' , because what we saw today can't be a 'dummy' because the team definitely needs 'real data' inorder for the testing to be useful before race1.
Stu
Re: Red Bull RB22
venkyhere wrote:
26 Jan 2026, 21:14
Maybe ‘encouraging’ the dirty turbulence to the rear tyre to reduce the drag?
Badger
Badger
46
Re: Red Bull RB22
Looks like the cooling louvre position is now next to the headrest, that's what we were seeing earlier.Image
Re: Red Bull RB22
Badger wrote:
26 Jan 2026, 21:46
It's a different bodywork configuration. This one does not have it:
#ReleasetheADUO
venkyhere
43
Re: Red Bull RB22
Stu wrote:
26 Jan 2026, 21:21
venkyhere wrote:
26 Jan 2026, 21:14
possible, yeah. Aerodynamics is dark-arts/black-magic :lol:
Badger
Badger
46
Re: Red Bull RB22
26 Jan 2026, 21:50
https://i.postimg.cc/8CWNffY0/Screenshot-4872.png
Either way, it doesn't seem like there is an inlet by the headrest. The outlet there is just extra cooling for the sidepod.
venkyhere
43
Re: Red Bull RB22
26 Jan 2026, 21:50
Badger wrote:
26 Jan 2026, 21:46
https://i.postimg.cc/qMHNQnn1/image.png
Also noting that the typical 'tip vortex' generating strakes that we usually see mounted on top of the halo (just before the halo's rear submerges into the body) aren't present anymore. Is this the case for other cars as well ?
Emag
Emag
137
Re: Red Bull RB22
26 Jan 2026, 21:06
https://i.ibb.co/pv5MW39d/20260126-190615.jpg
Super bluff front of the sidepod region. Compared to others I imagine there is a larger stagnation pressure at the leading edge of the floor despite the sidepod not being as wide
The belief must be that this forward, bluff sidepod is enough to control the lower/mid tyre wake. The exposed sis tube wing, like previous regs, is there but without the wing mirror stay attaching to the end to reduce power of tip vortex. The vortex that forms with suction side above sis-wing will rotate with a sense that helps to drive outwash of the upper-mid tyre wake, and increase downwashing effect of SP
The floor edge curl and stacked venetian blinds generating up+outwash will be helping to manage tyre wake too. Combined with more flexibility to create and position structures shed by FW, maybe these are sufficient to make this sidepod approach work.
Overall you end up with less frontal area
Is it just me or does the Airbox look kind of big here? In a vertical direction, not horizontal like vcarb. Inlet's total area maybe 1.5x bigger than Mercedes? Which to be fair it wouldn't be crazy if it was true considering their respective sidepod sizes.
Developer of F1InsightsHub
Re: Red Bull RB22
Badger wrote:
26 Jan 2026, 22:03
26 Jan 2026, 21:50
They're playing with Lego again in the garage
Re: Red Bull RB22
Emag wrote:
26 Jan 2026, 22:28
Many of us suspect that the intercooler is on top of the engine, as suggested by several sketches from scarbs.
#ReleasetheADUO
Re: Red Bull RB22
#ReleasetheADUO
carisi2k
29
Re: Red Bull RB22
ScottB wrote:
26 Jan 2026, 17:31
Probably looks closer to the RB-16B than any zero pod Merc
Actually to me it looks very RB6/7 like.
Re: Red Bull RB22
26 Jan 2026, 23:03
Red bull has the same bib support mercedes is running - a single strut
In this image you can also see the t-tray has the signature shape that we came to expect in pre-2022 rules
Can also see the halo inlets which are semicircular
Re: Red Bull RB22
Sidepod inlet is swept backwards around 40-45 degrees. This was not obvious in any other shots
#ReleasetheADUO
TNTHead
Re: Red Bull RB22
