Mercedes W17
Re: Mercedes W17
Mercedes has a diffuser extending winglet
Lasssept
122
Re: Mercedes W17
Lasssept
122
Re: Mercedes W17
Re: Mercedes W17
The shape of the car is really similar to Mercedes dominance days. :shock:
GrizzleBoy
GrizzleBoy
35
Re: Mercedes W17
27 Jan 2026, 02:39
The engine cover looks vacuum sealed tight like it used to compared to the others aswell.
K1Plus
K1Plus
Re: Mercedes W17
Pack it up, I've seen enough. W17 dominance it is. /sarcasm
Lasssept
122
Re: Mercedes W17
SilviuAgo
126
Re: Mercedes W17
A comparison between Mercedes, Red Bull and Ferrari shows that all three teams are running a hole in their diffuser, something which helps improve the diffuser flow.
🤯 What also stands out is just how narrow the RB22’s sidepods are in comparison to the W17 and SF-26!
source: Formula Aerodynamics
michl420
michl420
Re: Mercedes W17
The middle part of the front wing is fix. Maybe the actuators are in the endplates or the entire mechanism is in this fix part.
https://pbs.twimg.com/media/G_lEqL4WwAA ... name=small
zibby43
zibby43
Re: Mercedes W17
SilviuAgo wrote:
27 Jan 2026, 14:52
https://pbs.twimg.com/media/G_lPts1XgAA ... name=large
https://pbs.twimg.com/media/G_lPts_XQAE ... name=large
What also stands out to me is Merc have a significant undercut and RBR have none.
vorticism
vorticism
449
Re: Mercedes W17
michl420 wrote:
27 Jan 2026, 15:40
Good catch, I was just noticing that as well. There's a central pylon beneath the nosecone that intersects the static third element. My guess would be that there is a bellcrank within that pylon, acting upon torsion-arms/extension-shafts within the static center section that extend to the pivot axis on the flaps.
23 Jan 2026, 08:09
Re: Mercedes W17
michl420 wrote:
27 Jan 2026, 15:40
#ReleasetheADUO
SB15
SB15
Re: Mercedes W17
27 Jan 2026, 19:24
michl420 wrote:
27 Jan 2026, 15:40
https://cdn-5.motorsport.com/images/amp ... ced-2.webp
This is some advanced front wing trickier that I don't think any other team came up with. This maybe a huge advantage if they can use it in some high speed sections.
Re: Mercedes W17
I think I understand how Mercedes will adjust the front wing angle (for the balance adjustments, not the active aero). There's a hole on top of the nose. Tool inserted here to adjust the wing angle.
#ReleasetheADUO
