2026 car comparisons
dialtone
dialtone
139
Re: 2026 car comparisons
28 Jan 2026, 01:31
venkyhere wrote:
27 Jan 2026, 21:36
Indeed. I was looking for the 'flap adjust' thingie and couldn't find it on the Redbull/Merc
Btw,
forget the aero bits, huge differences in the front suspension geometries. Didn't expect such a large variance. Waiting to see what 'suspension tricks' RobMarshall has cooked up on the McLaren tomorrow.
I think I found the answer. Mercedes and Red Bull have a hole on top of the nose above active aero mechanism. This would appear to allow them to insert a T-wrench directly into the adjuster mechanism in order to set the static cornering mode angle when setting up the car or during pit stops.
It's quite clever and minimizes the blockage typically associated with having front wing adjuster by integrating it with the active aero mechanism which is already there.
How's your research going for teams sharing knowledge about holes in floors? Does it include holes in nosecones?
Emag
Emag
137
Developer of F1InsightsHub
Obviously rake is something they can vary but looks like McLaren running more rake today than other top teams from the limited images we have. Vcarb too
Then a comparison with red bull involved Image
FW17
189
Old concept brought back, Merc over hang is taller
JRodrigues
JRodrigues
Is it just me or McLaren downwash sidepods seem very similar to Cadillac's?
Badger
Badger
46
JRodrigues wrote:
28 Jan 2026, 17:32
https://pbs.twimg.com/media/G_v-IBeXkAARTvd.jpg
https://pbs.twimg.com/media/G_mF0oiW0AERqdH.jpg
Very similar. McLaren perhaps slightly tighter undercut, but more inlet area. The Cadillac is a neat package for a first car.
SICK AL SPEEDSHOP
euv2 wrote:
26 Jan 2026, 14:47
https://postimg.cc/5QYzrQBg
https://x.com/racepluscom/status/201576 ... 00560?s=20
Yes, Red Bull has the lowest mainplane curvature. Mercedes is the only team with the nose not connected to the mainplane.
I just read an article in AMuS in german the Mercedes is the only team who has the front wing connected to the second plane and only moves the third plane with active aero. all other teams have their wings connected to first plane but the regulations dont say clear if you wanna open only the second or the third or both planes. should be possible to open the second plane and keep the third one closed.
edith: article was on Motorsport-Total
amr
amr
I think the sidepods will evolve the most this year, along with the front wing, of course. Teams will soon start exploiting the X and Z modes and will change their solutions such that most of the cooling is done in X mode, when it is actually needed.
That means cooling will move as much as possible to the sidepods, leaving a small air scoop, like Ferrari is doing.
Also, if they can manage tyre wake, they might lower the sidepods, like Audi is doing, such that less air gets into them in Z mode due to the upwash of the front wing, reducing the drag, and full cooling capacity only in X mode when the front wing is dropped.
SB15
SB15
The render was true, that Mclaren looks "basic" in comparison.
vorticism
vorticism
449
28 Jan 2026, 01:31
venkyhere wrote:
27 Jan 2026, 21:36
I think I found the answer. Mercedes and Red Bull have a hole on top of the nose above active aero mechanism. This would appear to allow them to insert a T-wrench directly into the active aero mechanism in order to set the static angle when setting up the car or during pit stops.
https://i.postimg.cc/6QJyg4xZ/image.png
https://i.postimg.cc/g0X1XrxV/image.png
Excellent. Two linkages to the flaps but one adjustment point for both--might imply one actuator as well.
euv2
euv2
16
28 Jan 2026, 01:31
venkyhere wrote:
27 Jan 2026, 21:36
Same solution on the MCL40 too. Very neat solution, now pitstops will need 1 less mechanic to adjust the flap.
I agree. The Mclaren wing is very tidy.
Beware of T-Rex
dialtone
dialtone
139
euv2 wrote:
28 Jan 2026, 01:31
venkyhere wrote:
27 Jan 2026, 21:36
Aside from the obvious alignment between the top 3 teams in a 20 mile radius, which we’re probably going to see in the remaining ones as well like AM and Williams, is this actually better?
On the edge of the wing you had a quick in and out, only issue to solve is that you need to have synced up adjusters, but now you are walking in front of the wheel and need to get through a small hole… feels at best marginal to me, might be slower as the human movement is the slow part.
Emag
Emag
137
dialtone wrote:
28 Jan 2026, 22:55
euv2 wrote:
28 Jan 2026, 01:31
https://postimg.cc/z3NfdwSV
With a magnetic head it can be a bit easier for the mechanic to latch in and adjust I suppose, but I don't know if any solution is better or worse.
f1isgood
f1isgood
Interesting that Red Bull after pioneering the downwash + large undercut sidepods last regulations went away from it but some front running teams have stuck with it.
