Mclaren MCL40
Nicktendo86
Nicktendo86
Re: Mclaren MCL40
Dr Obbs says there is a diffuser cutout. I can’t see it but he’s insisting it is there
https://x.com/dr_obbs/status/2016591820 ... 9iyhp-jHmg
FNTC
FNTC
Re: Mclaren MCL40
I think its just the space between the outside of the diffuser and the other strakes, not a hole in the actual diffuser
Re: Mclaren MCL40
Nicktendo86 wrote:
28 Jan 2026, 21:56
The thing he believes/has highlighted as the cutout is just the diffuser winglet
Emag
Emag
137
Re: Mclaren MCL40
Nicktendo86 wrote:
28 Jan 2026, 21:56
It is a bit weird honestly, I can't 100% confirm what exactly they're doing here.
But, it seems like they might be "extending" this bit from outer floor into the cut of the diffuser as a strake? So it looks like a full piece. I am trying to find some images of other cars from this angle to confirm.
Developer of F1InsightsHub
Badger
Badger
46
Re: Mclaren MCL40
His evidence for that is that "it's there", and he draws a line where there is nothing. Sometimes I feel like these "analysts" are just engagement farming, telling fans what they want to hear. If you can't see it... Image
Re: Mclaren MCL40
Badger wrote:
28 Jan 2026, 22:07
His evidence for that is that "it's there", and he draws a line where there is nothing. Sometimes I feel like these "analysts" are just engagement farming, telling fans what they want to hear. If you can't see it... https://pbs.twimg.com/media/G_xaag9XwAA ... name=large
I think brakeboosted has a view that clears up the issue quite easily.
We're seeing the leading edge of the diffuser winglets
The carbon is really quite reflective
Emag
Emag
137
Re: Mclaren MCL40
Badger wrote:
28 Jan 2026, 22:07
I think he is trying to make this point :
But even if it is like this, I don't think it's in the same spirit with what the others are doing.
Badger
Badger
46
Re: Mclaren MCL40
28 Jan 2026, 22:17
Badger wrote:
28 Jan 2026, 22:07
https://i.ibb.co/PG3jpYGN/20260128-201645.jpg
That's a standard part afaik. And you can clearly see the diffuser wall extending backwards, it doesn't have a hole in it.
vorticism
vorticism
449
Re: Mclaren MCL40
The diffuser Fence (FIA's term) is more outboard than others hence it's visible behind the foxhole.
deadhead
86
Re: Mclaren MCL40
Showing the real deal in the renders is pretty cool
LionsHeart
LionsHeart
Re: Mclaren MCL40
Nicktendo86 wrote:
28 Jan 2026, 21:56
He say: “Also a curious triangular shape to the diffuser winglet. You can see this at the rear of the car. I'm assuming that's the winglet, because I won't think the diffuser sidewall is allowed to be this angled”.
It's not the mouse hole that many have raised, but rather the shape of the diffuser at the rear, where he mentioned a triangular shape. My point is that the side view most likely points not to the diffuser geometry, but to the flaps and vertical elements of the brake ducts. Typically, the geometry of the diffuser's trailing edge is always strictly vertical relative to the longitudinal axis of the chassis.
SiLo
145
Re: Mclaren MCL40
The airbox is not only big, it’s big quite a long way back too.
Felipe Baby!
Emag
Emag
137
Re: Mclaren MCL40
SiLo wrote:
28 Jan 2026, 23:03
I suppose they had to do it because the undercut is quite massive (you can refer to another post I made in the previous page).
Would be interesting to see a comparison between the RedBull's centerline and McLaren's.
Avocado
Avocado
Re: Mclaren MCL40
SiLo
145
Re: Mclaren MCL40
Emag wrote:
28 Jan 2026, 23:07
SiLo wrote:
28 Jan 2026, 23:03
I didn’t mean the airbox was rearwards, more that it’s big and has volume quite a lot towards the rear (for clarity)
Felipe Baby!
