Red Bull RB22
bananapeel23
34
Re: Red Bull RB22
euv2 wrote:
28 Jan 2026, 22:21
pantherxxx wrote:
28 Jan 2026, 22:17
I just read that comment under a Youtube video. Probably bs tho :D.
Having more downforce than last year's cars combined with the new drag modes would make this the fastest car in f1 history and that is not happening in year 1 of these regs, and the FIA would not have released figures claiming the new car would be a couple secs slower either.
Maybe in quali. Remember that theh are still dealing with a ~30% loss in sustained engine power, which would not be compensated for by the new aero modes.
But I also agree that the downforce numbers won’t be anywhere near 2020 or 2025 levels. These cars will be slower at most tracks, especially in terms of race pace.
cplchanb
cplchanb
Re: Red Bull RB22
https://www.reddit.com/r/formula1/s/gs5uN48ycI
Apparently theres cooling issues for their powertrain in at least the vcarb team. Is it affecting rb as well and will they need more cooling to their near zeropods?
Emag
Emag
137
Re: Red Bull RB22
cplchanb wrote:
29 Jan 2026, 13:54
There is plenty of cooling going into both. I would aruge it’s actually better in the main RB team because they have much better resources to come up with smarter solutions. In spite of the tighter body and smaller sidepods.
The vcarb just looks “bad” because the airbox inlet is huge. The actual centerline behind it, its not crazy enormous when compared to some other cars we have seen. And same goes for RedBull.
I don’t know where they got this information from though. No other source is reporting such problems as of this moment.
Developer of F1InsightsHub
Andi76
Andi76
476
Re: Red Bull RB22
basti313 wrote:
26 Jan 2026, 15:43
TeamKoolGreen wrote:
26 Jan 2026, 15:11
It is the closest thing to a Mercedes zeropod
From what I can see, it is a zeropod. Once there are better pictures we need to compare the width around the sidepods, from what I can see this is basically the same as the cars are less wide.
I wonder if the approach here is like in 2014....go as aggressive as possible and widen up if needed?
Sorry, its definetely not a "zeropod". Not even close
venkyhere
45
Re: Red Bull RB22
Andi76 wrote:
29 Jan 2026, 14:05
basti313 wrote:
26 Jan 2026, 15:43
26 Jan 2026, 15:11
https://postimg.cc/4mHgnt4T
Bingo.
Rather than a 'undercut region' , It's more of a 'turning wall' to the attached air coming from the sides of the nose. That means 'smaller pressure build up'** on the outer walls of the driver cockpit, which in turn means less drag.
** just enough pressure to y-direction feed the 'venetian blind' bargeboard as the incoming air 'turns'.
matteosc
matteosc
33
Re: Red Bull RB22
Andi76 wrote:
29 Jan 2026, 14:05
basti313 wrote:
26 Jan 2026, 15:43
26 Jan 2026, 15:11
Could it be that the sidepodes are "simply" placed as back as possible, exposing the side cone? Maybe they are doing that to create some outwash despite the prescribed badgeboards.
venkyhere
45
Re: Red Bull RB22
matteosc wrote:
29 Jan 2026, 17:15
Andi76 wrote:
29 Jan 2026, 14:05
basti313 wrote:
26 Jan 2026, 15:43
I perceive it the 'other way around'. The sidepods are 'as forward as possible' in the RB22 compared to the other cars we have seen so far. Imagine the typical sidepod from 2025, chop off the leading half of it, bring the remaining half 'forward' and put a 'rounded slab' in the region wherever some of the undercut remains, to make it no-undercut. So we have a sidepod where it tapers off into the body/floor far ahead in the y-direction, than others. That's how I see it.
GrizzleBoy
GrizzleBoy
35
Re: Red Bull RB22
Andi76 wrote:
29 Jan 2026, 14:05
basti313 wrote:
26 Jan 2026, 15:43
26 Jan 2026, 15:11
Wow have not seen that sidepod shape since Amber coanda exhaust times is it?
Re: Red Bull RB22
GrizzleBoy wrote:
29 Jan 2026, 18:55
Andi76 wrote:
29 Jan 2026, 14:05
It looks like a tear drop
Beware of T-Rex
Owen.C93
Owen.C93
192
Re: Red Bull RB22
Let’s not start the red bull tear drop discussion again #-o
Re: Red Bull RB22
Twist angle on the bargeboard stay.
Beware of T-Rex
Re: Red Bull RB22
29 Jan 2026, 21:45
https://i.postimg.cc/vZKctzdH/image.png
Twist plus angled. I expected this direction once I saw Ferraris angled stay
Re: Red Bull RB22
The launch render from mid-january featured a thin sidepod shape with large undercut which is quite similar to what we have seen from Mclaren/Aston Martin. So they have evaluated this at some point and decided to be unconventional. They are the only team that has developed a no-undercut concept (Williams unknown). I would like to understand the purpose.
Beware of T-Rex
f1isgood
f1isgood
Re: Red Bull RB22
Maybe we will see the undercut return later. Maybe they just didn't produce it yet. To me this current sidepod looks like 2022 sidepods version 1 used before Day 3 Bahrain
Or maybe this is their evolution and the render is from the past.
Gridlock
42
Re: Red Bull RB22
I still feel like the actual undercut may be 'blanked off' with a massive vanity panel here, although I appreciate that is far from ideal for testing and data. It just looks like everything under ORACLE is.. too smooth and bulbous? What would be in there? Is it for outwash? Anyway Bahrain will be fascinating.
#58
