Mercedes W17
dialtone
dialtone
139
Re: Mercedes W17
28 Jan 2026, 01:22
I think I understand how Mercedes will adjust the front wing angle (for the balance adjustments, not the active aero). There's a hole on top of the nose. Tool inserted here to adjust the wing angle.
https://i.postimg.cc/6QJyg4xZ/image.png
does that wing have negative angle of attack when flipped open?
Re: Mercedes W17
Another thing that can be seen really well in this angle is how the deflector at the bottom of the brake tin directs the tire wake through the slots of the bargeboard.
Beware of T-Rex
Lasssept
135
Re: Mercedes W17
Lasssept
135
Re: Mercedes W17
dren
228
Re: Mercedes W17
28 Jan 2026, 01:52
https://i.postimg.cc/fLb5FRdD/image.png
https://i.postimg.cc/sx7nP0Sc/image.png
They've used components in that area in the past to keep the tire squirt from being sucked into the front floor area.
Honda!
Lasssept
135
Re: Mercedes W17
Emag
Emag
137
Re: Mercedes W17
Except for the nose-cone attaching on the 2nd element, I think it's also interesting how Mercede's top flap is also relatively "linear". What I mean is that if you compare it to the top flap of RedBull, Ferrari and especially McLaren, they all have this parabolic shape with a "dimple" focused on the outer edge close(r) to the endplates.
Basically, the Mercedes front wing seems to be generating less upwash.
Considering that the front wing shapes pretty much everything that goes on downstream, it seems like Mercedes is doing things quite differently to the others.
Developer of F1InsightsHub
venkyhere
45
Re: Mercedes W17
The floor front 'daggers' - do they have any other purpose other than to send energizing vortices under the floor ? Is there any scope for 'outwash vortices' like the ground effect era floor front strakes did ?
HungarianRacer
HungarianRacer
37
Re: Mercedes W17
venkyhere wrote:
29 Jan 2026, 13:23
They do work in tandem with the "mini diffuser" behind the "bargeboards" (short curled up edge section of the floor... also, they used to have flow conditioning devices roughly around the place of the new "bargeboards" pre-2022, but we didn't identify them as such, they were the "floor/sidepod fences", but I digress...), but they don't extend beneath the floor itself, so the magnitude of their outwash effect is diminishingly small compared to what it was from 2022 to 2025 with the underside strakes.
2021 SPWB
2021 SPWB
Re: Mercedes W17
So I had a thought, with all the mechanicals in the front wing now, how difficult will it be to swap out a front wing when damaged. And when damaged will it have a larger effect going forward until it is changed out.
Never argue with a fool, they will drag you down to their level and beat you every time.
Farnborough
Farnborough
152
Re: Mercedes W17
HungarianRacer wrote:
29 Jan 2026, 13:36
venkyhere wrote:
29 Jan 2026, 13:23
Possibly to control entry shear in yaw flow situation, in providing consistency from there backward.
SB15
SB15
Re: Mercedes W17
2021 SPWB wrote:
29 Jan 2026, 14:49
You could have the front wing be connected with electrical pins that can allow you to swap it out even if their's damage. My thought at least.
Lasssept
135
Re: Mercedes W17
matteosc
matteosc
33
Re: Mercedes W17
SB15 wrote:
29 Jan 2026, 16:05
2021 SPWB wrote:
29 Jan 2026, 14:49
That would make the most sense. You may still lose the front DRS, so you may have to replace the wing even for small contacts, while before you could keep going.
venkyhere
45
Re: Mercedes W17
Farnborough wrote:
29 Jan 2026, 14:55
29 Jan 2026, 13:36
venkyhere wrote:
29 Jan 2026, 13:23
Pic of the McL40 :
these look like ground effect era style 'strakes' meant to channel the air during yaw. I am guessing that these are turning from x-y direction to x direction (rather than x-y to y for floor edge vortex in the ground effect era) as we move from front to rear on the floor. I wonder whether all/some of the other teams are doing this.
