Aston Martin AMR26
Re: Aston Martin AMR26
wiktor977 wrote:
29 Jan 2026, 18:33
Some winglets, not seen so far on other 2026 cars
https://i.postimg.cc/4xYtCkY8/Aston-details.jpg
I don’t think the front one is a winglet. In the other picture, it’s the front of the halo but unfortunately many pictures appeared to be ai damaged.
Beware of T-Rex
FW17
184
Rear leg of the top wishbone seems to be connected so far back almost in line to the halo bulkhead
wiktor977
wiktor977
43
29 Jan 2026, 18:38
wiktor977 wrote:
29 Jan 2026, 18:33
I don’t think the front one is a winglet, that’s the front of the halo, or a shadow
It's weird because in the picture from the side I also see something there but I it's very possible it's only a shadow. I don't think it's a halo because of the angle, it looks vertical
edu2703
edu2703
37
FNTC
FNTC
Underbite sidepod inlets. That's different. Halo side wings. "Devil horn" airbox wings. Packaging around the engine looks extremely tight.
Front wing is like Mercedes. Middle element attachment.
Beware of T-Rex
GrizzleBoy
GrizzleBoy
35
These pics are making me want to punch things.
Will be interesting to see how much these wings still flex under load and how mounting position can influence it.
A floating main plane could theoretically flex lower to create greater downforce at higher speeds.
A fixed main plane with floating mid and upper elements has the possibility to provide negative downforce on straights.
Pushrod front.
Beware of T-Rex
Redragon
I brought the midlevels up so more detail
https://ibb.co/XZXjkV8Z
Giando
93
Nose cone vaguely reminds me the 2009 Mercedes W01 :shock:
Unzinn
Looks like they might have the same scallop under the nose that Audi has.Image
FNTC wrote:
29 Jan 2026, 18:47
It looks similar to their 2024 car.
Beware of T-Rex
mzso
mzso
76
Why are the rear suspension arms seem to be floating in mid-air?
Emag
Emag
137
From this angle it looks like a more “aggressive” mercedes.
Developer of F1InsightsHub
Redragon
I know is the exit of the engine air but feels like it is a widlet on itself indented on the body
https://ibb.co/DgDpLvdw
