Aston Martin AMR26
Xyz22
Xyz22
125
Re: Aston Martin AMR26
.poz
.poz
53
FNTC
FNTC
3.10.9 Front Wing Rotation System
Except for the forwardmost volume, the Front Wing Profiles, including any fitted gurney and
portions of Front Wing Auxiliary Components that are attached to these volumes, may be
rotated about a fixed axis whilst the car is in motion. Bodywork that can rotate in such way is
defined as FW Flap
The "forwardmost volume" (assuming first element) isn't allowed to rotate.
mzso
mzso
76
From this it looks like the suspension arms connect at the sides of the exhaust. :)
Not sure how all the structural parts can be there, right next to the hot exhaust.
BassVirolla
This car has at least five interesting points:
Front suspension
Rear suspension
Nose
Cooling outlets
Undercut / floating sidepod.
It's wild.
FNTC
FNTC
I still can't figure out how the front wing is supposed to pivot. Is it a fixed front wing for the first test?
edu2703
edu2703
37
mzso wrote:
29 Jan 2026, 20:12
Yeah. I was wondering if the suspension arms go through the rear wing pylon and connect directly to the exhaust, or if the pylon itself is bolted to the exhaust.
Egresi Tamás
Egresi Tamás
49
mzso
mzso
76
FNTC wrote:
29 Jan 2026, 20:14
I'm guessing they don't, for now.
F1NAC
173
Sensors for something, all that casing looks temporary molded to the nose
mzso
mzso
76
I'm guessing those are driver cooling inlets on the sides. There's nothing else between that and the cockpit. They're mandatory, right? The only other thing I see is the teeny hole on the tip of the nose.
DRCorsa
DRCorsa
Looks like there is a cooling inlet on the nose itself!
F1 would have been such a boring sport without Adrian!
mzso
mzso
76
DRCorsa wrote:
29 Jan 2026, 20:31
https://i.ibb.co/Xrf65LQN/Screenshot-20 ... ned-Te.png
On the video there's clearly nothing there though. Just that tiny hole on the tip. And that trapezoid cover or whatever is also visible on this image. Is it AI enhanced?
stewie325
stewie325
This looks like they're using the rear suspension arm as a beam wing now that it's been removed in the regs.
yinlad
42
mzso wrote:
29 Jan 2026, 20:38
DRCorsa wrote:
29 Jan 2026, 20:31
Can’t stop the Newey cult from going bananas of the most mundane thing and even inventing things that clearly don’t exist
MVRC - Panthera
