2026 Hybrid Powerunits
670
yes
and consider ....
essentially engine powers before 2014 were 'air-limited' - by engine capacity/rpm and induction air pressure
so the fuelling was always somewhat rich ie 'fuel-unlimited'
so power depended on the amount of heat coming from the amount of fuel that consumed a unit mass of air
this amount of heat is the stoichiometric-mass-specific heating value ... so ....
in a F1 car pre-2014 rules alcohols give this (more heat per kg of air) and so more power (than a 'gasoline- type fuel)
eg 100% methanol is for this reason about 10% more powerful eg than E5&E10 gasoline-type fuels of 2014-2025 ...
often impracticably, more kg of (alcohol) fuel are needed because alcohol has a smaller heating value (heat per kg)
2014-25 & 2026 engines use excess air - so are air-unlimited but fuel-limited (2014-25 fuel rate limited to 100 kg/hr)
so (2014-25) they demanded fuel with the greatest heating value per kg (regardless of heat per kg of air)
but from 2026 F1 has limited the fueling rate by heat rate (MJ/hr) not by mass rate (kg/hr)
there is no formal limit on total fuel kg consumed ie 'fuel load'
but it has limited fuel heat per kg (Lower Heating Value LHV) to between 38 and 41 MJ/kg
as methanol LHV is maybe 20 MJ/kg and ethanol LHV is maybe 28 MJ/kg ....
a 2026 fuel cannot contain much methanol (also there's a formal limit of 4% methanol) ... or much ethanol
because of the fueling fixed by heat rate more power is not possible
but the unlimited fuel load might allow a relative increase race-total energy via combined mechanical&electrical routes
or if 2026 fuel's explosive range is greater than 2025's engines might be run leaner and be more efficient and powerful
so eg some methanol content might help in this
CORRECTED FOR ERRORS IDENTIFIED BY GG IN HIS POST FOLLOWING
gruntguru
gruntguru
579
Tommy Cookers wrote:
26 Jan 2026, 18:39
ie alcohols inherently give more power and energy from a given ICE ....
eg 100% methanol is about 10% more powerful than E10 (in a given ICE) but .....
a 38 MJ/kg fuel blend cannot contain much methanol (there's anyway a limit of 4% methanol) ... or ethanol
but could give slightly more power and energy than E10 (at the cost of more fuel weight)
Alcohols won't be capable of "more energy" in the sense of heat energy released during combustion - energy flow is limited and based on LHV of the fuel.
I assume you meant more energy at the crank due to the higher TE.
(Just clarifying for the sake of others here.)
johnnycesup
johnnycesup
From the regulations regarding oxygen content, there is in essence a 20% mass limit on ethanol, and that is if every other component in the fuel is completely free of oxygen.
TeamKoolGreen
TeamKoolGreen
Audi isn't taking no for an answer with regard to the compression "loophole". If this was settled like the media claims it is , there wouldn't be 2 meetings scheduled.
Make or Break Week on Engines!
⚠️ ​The Race reveals two key FIA meetings (Monday & Thursday) to quash the "compression loophole" row.
👉 Ferrari, Honda & Audi want a new "hot engine" test to see Mercedes/RBPT gains
bonjon1979
bonjon1979
30
It seems to me that this is a classic f1 rules paradox. The rule states that the compression ratio must be one thing. But then mandates that it is only measured under certain conditions. Teams say they comply as they past the test, but that doesn’t negate what the overall rule dictates. See flexi-wings, fuel flow etc etc. much arguing here, no right or wrong, bun fight in the paddock technical directive incoming but not applicable until such time that it has no real discernible effect.
bonjon1979
bonjon1979
30
Hoffman900 wrote:
26 Jan 2026, 04:43
As I posted in the other thread;
V8 drag race and circle track builders set P-H around .040in (1mm) with steel rods which in practice is near zero Piston to Head clearance at redline (the goal is to run around 0.1mm running clearance). This isn’t out of the realm at all.
For a typical racing US domestic V8 with a 4.25in bore, 64cc chambers, and a 10cc dome, that’s a change from to 12:1 to 13.9:1.
This has been a “thing” for decades in race engine building. No fancy degrees or materials needed and certaintly not an industry secret.
All engines are limited by piston to head clearance. You can’t modify this, at some point, they meet, and it’s expensive. Now depending on the rods being used, it may matter. For example, on an American V8 drag race engine, aluminum rods may require 1.50mm p-h clearance ambient vs the 1mm for steel rods. Both will end up around .1mm near redline if you’re doing it right. Both will measure slightly different geometric compression ratios (aluminum being lower) but the same running compression ratio.
Binotto as an engine guy should know this. People building engines in their garages who struggled through high school even know this. This sounds more like sour grapes than anything.
Thought you might find this interesting...
Hoffman900
Hoffman900
242
diffuser wrote:
01 Feb 2026, 03:14
Hoffman900 wrote:
26 Jan 2026, 04:43
https://youtu.be/hLzto55W3RU?si=Bu9_J7zOVmZDJMLX
It largely said what I have said over a few posts, just with a lot more words.
Interesting he brings up “dynamic compression” which basically calculates compression ratio starting at the crank angle at intake valve closing (IVC). This thought comes from the 2 stroke world where they don’t have valves and the engine can’t begin compressing the mixture until the piston closes off the ports. On a 4 stroke it’s a little bit misleading as once the engine is “on song”, cylinder pressure is above 1 atmosphere before intake valve closing (IVC) as the inertia of air against a rapidly closing intake valve raises port pressure, so compression is occuring to a small amount prior to IVC.
A certain and controversial performance authorhas coined “effective compression ratio” as “dynamic” and has tried to correlate to octane needs for a given combination. This is wrong as octane needs are driven by lots of things like peak firing cylinder pressure, turbulent kinetic energy (TKE), plug position, atomization (and its effect on the mixture temp in the cylinder), etc.
There is nothing dynamic about “dynamic compression ratio”.
Further complicating things is on a Miller Cycle engine, which F1 engines and some of the diesel LeMans engines before 2014 were, closes the intake valve before BDC on the intake stroke. This means the engine has a higher expansion ratio than compression ratio, which in turn lowers cylinder temperatures. This was used by Mazda and Subaru in the early 90s, still used in locomotive engines. It requires big boost / high air flow from the turbo or supercharger to make up for lack of open time of the intake valve. Pat does a great job describing it here starting at 13:00 https://youtu.be/mUq-K9jcaB8?si=06uO7-077SuZjlix . As he points out, by closing the intake valve so early you do lose some of the effect of a longer intake period adding in cylinder motion in the cylinder (typically tumble on a 4 valve head), or when you factor in a few more things, TKE. So that’s why thints like turbulent jet ignition (TJI) are sought out. Honda has a good white paper published this past September about developing TJI systems for large bore sport bike engines, why you want it (the jets increase TKE and create a larger flame surface area, thus reducing knock, and allowing for a higher geometric compression ratio for a given octane), but they also point out it struggles at part throttle operation and is part why you haven’t seen it widely adopted on the street, but I digress…
The Wikipedia and subsequently the AI searches that have trained on the wiki part are wrong about the Miller Cycle. Overall, as he brings it up in the video, the dynamic compression ratio isn’t entirely well explained and it just felt like he was dropping it in there to sound smarter, and also has no idea what it means.
670
the biggest nonsense talked in the 2026 (or 2014) F1 context is 'octane'
(anyway there is no such thing)
RON is a 600 rpm test
MON is a 900 rpm test
(not 10500 rpm or 12000 rpm or 15000 rpm etc)
the biggest factor is TIME
F1 permitted sensitivity is 15
ie F1 fuel can have a RON of 102 and a MON of 87
but 'octane' tests RON and MON are made with reference fuel that tests at 100 RON and 100 MON (what a surprise !)
2014 fuel rules were about avoiding dieselisation
what are 2026 rules about ?
Hoffman900
Hoffman900
242
2014 was a failure from that standpoint because they all moved towards “rapid combustion” concepts, ie: self ignition, supplemented with TJI
FW17
184
Furthermore, there is no scope in the regulations to simply run a quick outlap on the internal combustion engine alone, as there are strict rules regarding power demand.
Article 5.12.1 of the Technical Regulations states: “At any given engine speed, the driver torque demand map must be monotonically increasing for an increase in accelerator pedal position.”
This effectively means that the trigger for kicking in battery usage is throttle position - not a button on the wheel.
venkyhere
43
FW17 wrote:
03 Feb 2026, 18:22
"Monotonically increasing" means :
d(T-demand)/d(pedal.pos) is a +ve number for all values of pedal.pos, however small or big.
"Linear" is only one of the possible ways.
For example, the green curve can be used for a 'cool' lap, where the driver doesn't press pedal beyond 50% at any stage ; from 25% to 50% "almost all" of the ICE output is used to recharge battery via MGU-K, from 0% to 25%, "almost nil" of the battery output is deployed, and the car can be ready for a Q-lap at the end of the outlap, when they are doing a push-cool-push. In this case, for the 'cool' lap, the ICE is providing 'almost all' the power and the battery gets fully recharged from 25%-50% pedal stage AND from the braking/lift-off recharges.
FittingMechanics
FittingMechanics
FW17 wrote:
03 Feb 2026, 18:22
I think that this is intended to avoid any possibility of making "traction control". They are worried about that. My understanding is that drivers will be able to change the deployment maps and deploy manually.
Hoffman900
Hoffman900
242
venkyhere wrote:
03 Feb 2026, 19:03
FW17 wrote:
03 Feb 2026, 18:22
https://i.ibb.co/5gP1JspG/pedal-map-possibilities.png
This holds true for even mechanical linkages. We have used throttle linkages that can vary progression vs pedal position and you can tune this around a driver. Obviously it’s fixed once out the pits, but it’s a tuneable feature.
Dawntreader on X had some cool graphs of old Indy Car throttle progression vs pedal position. All mechanical. Most throttles aren’t linear, even most carb systems.
dialtone
dialtone
139
FittingMechanics wrote:
FW17 wrote:
03 Feb 2026, 18:22
That’s precisely it. They want the driver to control the throttle and not have them be just pressing and leaving a computer choose the optimal torque.
