Aston Martin AMR26
MV8
Re: Aston Martin AMR26
Just posting
dren
228
11 Feb 2026, 12:17
We haven't seen a DRS actuator like this before.
https://i.postimg.cc/cLq6c8St/image.png
Looks like those 'wings' either side of the metal rod would shed vortexes onto the wing.
Honda!
dren wrote:
11 Feb 2026, 16:38
11 Feb 2026, 12:17
I don't think they are vgs. I think the tuning fork is just a way to have a coincident rotation axis for the two arms of the linkage.
#ReleasetheADUO
wiktor977
wiktor977
43
Huge angle of attack on the first flap but the mainplane is very flat
Seems to be air to air intercooler like Red Bull
Martin Keene
Martin Keene
The wiring harness is in the way for a proper look, but do you think that is a straight connection from charge cooler to inlet manifold?
In which case, as the airbox does not appear to be spilt into different sections, where is the turbo being fed from.
The Aston Martin has a working front wing active aero. It was just shown on the broadcast into T1. It works.
#ReleasetheADUO
vorticism
vorticism
449
MtthsMlw wrote:
11 Feb 2026, 17:03
https://pbs.twimg.com/media/HA4kKMZbwAA ... &name=orig
Excellent, thanks.
--fancy rockers/bellcranks
--two heave devices?
--the rearmost heave device has an airfoil shroud
--wastegate entry is visible on the tailpipe
--AMR with different weldment arrangements for their intercooler, compared to RBR (in house or supplier item?)
--they don't bother with ubiquitous divided roll hoop, instead split the ducts downstream from a single shared snorkel inlet
dren
228
Martin Keene wrote:
11 Feb 2026, 17:08
Honda!
dren
228
11 Feb 2026, 17:17
Full span or partial like the Merc?
Honda!
FrukostScones
11 Feb 2026, 17:17
I didnt see much working there. you mean the when they showed the comparison?
dren
228
vorticism wrote:
11 Feb 2026, 17:20
MtthsMlw wrote:
11 Feb 2026, 17:03
Excellent, thanks.
--Expert use of zip-ties in more than one strategic location.
Added one for you.
Honda!
Farnborough
Farnborough
152
MtthsMlw wrote:
11 Feb 2026, 17:03
Seems to have a "sleeve" thermal barrier on exhaust tail pipe, you can see the beginning of it aft of where the waste gate outlet joins main exhaust.
That's for you to look at mzso :D
dren wrote:
11 Feb 2026, 17:24
11 Feb 2026, 17:17
Same as Mercedes
#ReleasetheADUO
FrukostScones wrote:
11 Feb 2026, 17:24
11 Feb 2026, 17:17
I saw it. Flap was down on the straight into T1. Then it came up in the brake zone. It's there and it works.
#ReleasetheADUO
