2026 car comparisons
Re: 2026 car comparisons
vorticism wrote:
11 Feb 2026, 16:59
Surely those RB22 pillars will be copied. Two large VGs right under the wing? Seems ideal.
That's a good spot. I didn't notice it initially. Are they treating it as part of the rear wing pillar to legalize it?
Beware of T-Rex
vorticism
vorticism
449
Front pushrod, wide spaced arms, big round snorkel, three-element rear wing, low nose, vertical inlets, stalky mirrors, front wing between front tyres, and a certain double-digit integer...
11 Feb 2026, 17:03
vorticism wrote:
11 Feb 2026, 16:59
That would be my guess.
gavingav1
35
NoDivergence
NoDivergence
52
The super drooped nose of the McLaren is noticeably different
vorticism
vorticism
449
The high middle section of the front wing on the RB22 that others have been pointing out is visible there, too. And the high front wing tips of the Alpine are again visible there.
michl420
michl420
vorticism wrote:
11 Feb 2026, 16:59
Normal they are trying to make it as short as possible to disrupt the flow as little as possible. But maybe it changed with this low AoA wings.
Haas front wing active aero moves the entire span of the wing instead of just the 2 outboard flaps. Williams, Ferrari, and RBR also look like they move the full span.
Beware of T-Rex
michl420
michl420
Most cars have the rear wing with a long main plan and 2 short flaps. Aston Martin and Audi have a big second element.
Williams and Aston Martin are the rake leaders (most rake), followed closely by Mclaren.
Beware of T-Rex
ryaan2904
ryaan2904
36
SB15 wrote:
11 Feb 2026, 11:51
Most of the team already has a lot of outwash. That didn't take long
Thats a lot of unwanted air going into the diffuser area on the Ferrari. Ouch.
CFD Eyes of Sauron
Seanspeed
Seanspeed
One of my 'will never happen' fantasies is seeing how a full on top F1 organization today would design a 1990 F1 car knowing everything they do now and with all the modern resources we have today.
wiktor977
wiktor977
43
One thing that I don't really understand is the big difference between the teams when it comes to the downforce levels of their wings. I know it's just the test but why do they even bother with lower downforce wings when you hide them at every straight?
wiktor977 wrote:
13 Feb 2026, 02:55
https://i.postimg.cc/cC8Gwd7z/Mc-Laren.jpg
https://i.postimg.cc/nVsX073p/RB.jpg
https://i.postimg.cc/sf02WXyv/Ferrari.jpg
https://i.postimg.cc/fRvyJvR8/Mercedes.jpg
https://i.postimg.cc/zXbGFrXS/Audi.jpg
https://i.postimg.cc/pdGdBX8z/Aston.jpg
The front wings are not exclusively downforce generators. They are also important tools for aero balance and flow conditioning to the floor and rear of the car. So, it's not always the case that you want the largest possible front wing.
Beware of T-Rex
I'm unsure if it's a difference of perspective, but Red Bull seems to have a larger exhaust pipe and it is also positioned much higher above the impact structure than the others (Mercedes, Ferrari).
Also note the 4 channel rear brake duct exit of the Mclaren. It is much more complex than the other 3 teams.
Beware of T-Rex
FittingMechanics
FittingMechanics
13 Feb 2026, 03:22
wiktor977 wrote:
13 Feb 2026, 02:55
Could also be a balance thing. If you generate a lot of downforce at the rear you can balance it with higher downforce at the front.
