Aston Martin AMR26
FNTC
FNTC
Re: Aston Martin AMR26
Found these now, from Tobi Grüner:
mzso
mzso
76
I wonder why they have thermometer stickers there. In the pits they can hardly be of much use, and while moving they would need a camera pointing at it, which would be more useful if it was a thermal camera in the first place.
Owen.C93
Owen.C93
189
mzso wrote:
12 Feb 2026, 21:38
The strips change colour at certain temps and then stay that way, so they measure peak temperature and can be read at the end of the day.
gromajor
gromajor
Concerning the front wing, I had a hard time to believe it was moving, because all the elements are connected together.
But now, thinking it's an Adrian Newey car, I wonder if they're simply not just flexing the last element.
He has quite some experience on flexing wings s far as I can remember. 😉
And they could do this to avoid the weight of the pivots.
FNTC
FNTC
mzso wrote:
12 Feb 2026, 21:38
I googled it now, and apparently they are stickers that show the maximum temperature, and stays on that value. Images from previous tests show them on brake calipers etc. I guess they want to make sure the carbon fiber doesn't get to hot there.
Ozan
Ozan
this car needs a cooling system rethinking, reminds me of the 2022 Aston car had the same double floor extreme undercut sidepods but switch to the other types later in the season
sucof
37
Very cool photos, thanks! I saw earlier those parts of the pillar, wondered if they hide some adjustments.
Now it looks like they might set the length of that pillar? Is that for tuning the main plate of the wing, or something else?
mzso
mzso
76
Owen.C93 wrote:
12 Feb 2026, 21:42
FNTC wrote:
12 Feb 2026, 21:42
Ah, I thought only ones that show the current temperature existed.
mzso
mzso
76
mzso wrote:
12 Feb 2026, 22:57
Isn't that just how they're mounted?
Do you mean the metallic / golden thing? That should be the hydraulic line for the DRS actuator
sucof
37
MtthsMlw wrote:
12 Feb 2026, 23:09
Ah, you might be correct!
vorticism
vorticism
449
vorticism
vorticism
449
Upper arms totally aft of the engine cover.
Brahmal
Brahmal
74
gromajor wrote:
12 Feb 2026, 21:42
I'm pretty sure an F1 team can figure out how to put a hinge on a wing stay.
Bence
Bence
dr_cooke wrote:
11 Feb 2026, 14:09
:shock: :shock:
Unfortunately I'm getting F92A vibes from this undercut; it is almost like Migeot's double floor concept.
...aaand the Golden Razzie goes to...
