Ferrari SF-26
sucof
39
Re: Ferrari SF-26
.poz wrote:
18 Feb 2026, 18:23
flmkane wrote:
18 Feb 2026, 16:32
It's a monkey seat
it' an hot monkey seat
I'll call it "Monkey Grill" ©️
:D
McG
-24
Re: Ferrari SF-26
Reminds me of this
Finally, everyone knows that Red Bull is a joke and Max Verstappen is overrated.
FerrariF60
FerrariF60
Re: Ferrari SF-26
sucof wrote:
18 Feb 2026, 18:32
.poz wrote:
18 Feb 2026, 18:23
flmkane wrote:
18 Feb 2026, 16:32
It's a monkey seat
:D
that is genius by Ferrari; whatever it takes to get more downforce.
bananapeel23
34
Re: Ferrari SF-26
edu2703 wrote:
18 Feb 2026, 18:10
How come its always Ferrari that comes up with the wildest aero tricks. First the bath tubs in 2022, then the "S-duct" in 2023 and now the diffuser extension, followed by a (very crude) blown diffuser to further power up the diffuser extension.
Gabriox
Gabriox
Re: Ferrari SF-26
Is it me or is the rear suspension mounted higher than the first test they did in Bahrain? A la aston martin
Re: Ferrari SF-26
:idea: I see this as blowing the rear wing!! :idea:
ryaan2904
ryaan2904
36
Re: Ferrari SF-26
19 Feb 2026, 03:24
Could you explain? I feel blowing the rear wing is a bit far-fetched. It could just be that they are blowing high energy air upwards to energise the suction from the diffuser and improving diffuser performance
CFD Eyes of Sauron
NoDivergence
NoDivergence
52
Re: Ferrari SF-26
19 Feb 2026, 03:24
No shot
Brahmal
Brahmal
88
Re: Ferrari SF-26
ryaan2904 wrote:
19 Feb 2026, 04:07
19 Feb 2026, 03:24
Might have some influence on the rear wing, but diffuser is primary. That flap and surrounding aero features will create a strong low-pressure volume right behind it, increasing suction. I would think it also reduces efficiency of the exhaust pipe and hurts engine performance a little, but Ferrari clearly doesn't think so!
ryaan2904
ryaan2904
36
Re: Ferrari SF-26
Brahmal wrote:
19 Feb 2026, 04:31
ryaan2904 wrote:
19 Feb 2026, 04:07
19 Feb 2026, 03:24
So long as there is strong suction at the back it should be okay? Im very excited to see where each team claws performance back against merc's engines
CFD Eyes of Sauron
Fer.Fan
Fer.Fan
Re: Ferrari SF-26
Gabriox wrote:
18 Feb 2026, 22:28
According to Italian media it is the case. Rear suspension is mounted higer, BIG upgrade.
GrizzleBoy
GrizzleBoy
35
Re: Ferrari SF-26
19 Feb 2026, 03:24
Same.
If the air goes right up towards the wing and is high speed enough it could either:
- Speed up air below the rear wing to create downforce if the flow is meant to supplement
- Slow down airflow below the rear wing relative to the air above it and create lift/less floor drag if the flow ito be disruptive
Farnborough
Farnborough
152
Re: Ferrari SF-26
Brahmal wrote:
19 Feb 2026, 04:31
ryaan2904 wrote:
19 Feb 2026, 04:07
19 Feb 2026, 03:24
There's a possibility that it may improve turbo spool up while sitting statically, but cleared more effectively into that under wing flow space when moving, that to mitigate exhaust flow losses.
"Tuning" the end of exhaust pipes right at that far extremity can be of significant benefit to up stream pulsing etc within the system. Not generally seen on turbo system outlet, they may have found something here on these quite distinct set of components and while running below optimisation during start procedure circumstances.
venkyhere
45
Re: Ferrari SF-26
ryaan2904 wrote:
19 Feb 2026, 04:07
19 Feb 2026, 03:24
It's blowing the 'gap' between rear wing and diffuser at such an angle that it produces additional suction strong enough to :
- increase the speed of air hitting the underside of rear wing mainplane
- increase the speed of air exiting the diffuser.
Re: Ferrari SF-26
The Ferrari seems to always have this whisp of "smoke" trailing the impact structure.
Beware of T-Rex
