2026 car comparisons
venkyhere
45
Re: 2026 car comparisons
13 Feb 2026, 10:27
I'm unsure if it's a difference of perspective, but Red Bull seems to have a larger exhaust pipe and it is also positioned much higher above the impact structure than the others (Mercedes, Ferrari).
Also note the 4 channel rear brake duct exit of the Mclaren. It is much more complex than the other 3 teams.
https://i.postimg.cc/vB4d7N1F/image.png
Also noteworthy is the amount of cooling-exit opening that the Redbull needs to have over the other three, because they are sticking to air-to-air ICs which will have a domino effect on all the packaging under the engine cover. Could well be the reason for the 'higher mounted' exhaust pipe.
wiktor977
wiktor977
43
13 Feb 2026, 03:22
wiktor977 wrote:
13 Feb 2026, 02:55
One thing that I don't really understand is the big difference between the teams when it comes to the downforce levels of their wings. I know it's just the test but why do they even bother with lower downforce wings when you hide them at every straight?
https://i.postimg.cc/cC8Gwd7z/Mc-Laren.jpg
https://i.postimg.cc/nVsX073p/RB.jpg
https://i.postimg.cc/sf02WXyv/Ferrari.jpg
https://i.postimg.cc/fRvyJvR8/Mercedes.jpg
https://i.postimg.cc/zXbGFrXS/Audi.jpg
https://i.postimg.cc/pdGdBX8z/Aston.jpg
The front wings are not exclusively downforce generators. They are also important tools for aero balance and flow conditioning to the floor and rear of the car. So, it's not always the case that you want the largest possible front wing.
Of course, but I'm still surprised by how some teams are approaching this, but again, it's only a test.
SSJ4
SSJ4
32
Farnborough
Farnborough
152
SSJ4 wrote:
13 Feb 2026, 20:27
They appear to have marked the 2025 McLaren purple on the steering link and not the pull rod.
The comparison doesn't appear valid for that one.
MIKEY_!
09 Feb 2026, 06:45
MIKEY_! wrote:
09 Feb 2026, 05:34
The raised centre section of the red bull front wing is an interesting choice, presumably made possible by (or resulting from) an extreme amount of rake.
Do you think it's raised? I think it's the opposite. RB have a low mainplane and a low nose. The others have high nose and lifted mainplane at the tips.
The centre section of the wing is raised within the regulation boxes, because that's the only way to make such a neutral dihedral wing fit in an aggressively dihedral regulation box. Hopefully this diagram makes it clearer: low nose on the left, high nose on the right - green is the reg boxes, red is the car centre line, grey is the reference plane, black is the bodywork cross-section. When rake is applied, the nose, wing and regulation boxes are lowered closer to the ground.
MIKEY_! wrote:
14 Feb 2026, 08:25
09 Feb 2026, 06:45
MIKEY_! wrote:
09 Feb 2026, 05:34
https://i.postimg.cc/W1N7kx3M/rb2026-fw.png
That makes sense. Its possible that they want the higher wing in order to increase the clean air to the floor for the higher speed corners. Red Bull is the only team that doesn't have a big anti-dive on the front suspension. How does it relate? I think they want more dive under braking which will lower the front wing and increase the ground effect/load for the slow corner entries.
Beware of T-Rex
Brahmal
Brahmal
88
Brahmal wrote:
18 Feb 2026, 05:48
The exhaust of the Alpine is higher and point upwards while that of the McLaren and the Mercedes does not. They all have the same PU. Odd.
Beware of T-Rex
Brahmal
Brahmal
88
Brahmal
Brahmal
88
Alpine
Haas
Aston
Cadillac
Williams
Red Bull
Ferrari
https://www.planetf1.com/features/f1-20 ... -technical
Mclaren vs Aston
Beware of T-Rex
Mclaren vs Ferrari
Beware of T-Rex
Luscion
Luscion
153
Re: Ferrari SF-26
19 Feb 2026, 09:58
Ferrari just did something absolutely bonkers. Their DRS flap inverts. Completely upside down. :shock: :shock:
I watched it rotate 360 degrees :shock:
https://i.postimg.cc/rmsg7M0m/image.png
video of it
Re: Ferrari SF-26
MtthsMlw wrote:
19 Feb 2026, 10:41
They really studied the rule book this year. I love it.
The actuator/s seem to be in the endplate.
https://cdn-8.motorsport.com/images/mgl ... ari-s.webp
https://cdn-4.motorsport.com/images/mgl ... rrari.webp
I wonder if it acts like an airbrake momentarily when driver hits the brakes...Could give gains in the brake zone too.
Beware of T-Rex
ryaan2904
ryaan2904
36
Re: Ferrari SF-26
Luscion wrote:
19 Feb 2026, 10:02
19 Feb 2026, 09:58
video of it
Wow
CFD Eyes of Sauron
