Mclaren MCL40
LionsHeart
LionsHeart
Re: Mclaren MCL40
SilviuAgo wrote:
18 Feb 2026, 13:17
Nice comparison for rake, but also for cooling options between McLaren, Aston and RedBull. McLaren did again an amazing job in this area.
https://pbs.twimg.com/media/HBbIRDWawAA ... =4096x4096
I think the rake is more clearly visible here. The photos were taken from the same angle and height relative to the ground. The Aston Martin and Williams have more rake than the McLaren. The Ferrari has even less rake than the other cars on display. I can't attach a photo of Williams' car.
SilviuAgo
122
Re: Mclaren MCL40
McLaren: Front Wing detail
SilviuAgo
122
Re: Mclaren MCL40
LionsHeart wrote:
18 Feb 2026, 19:59
SilviuAgo wrote:
18 Feb 2026, 13:17
https://i.ibb.co/XxMwFD1F/8-C89-A869-F8 ... B333-F.jpg
https://i.ibb.co/PGjbnq5v/06567-A2-A-CB ... -A00-C.jpg
https://i.ibb.co/4ZHtBnKG/8443-C87-D-C5 ... 913018.jpg
To make a joke, maybe this is the reason AM is so slow, there is no driver inside :))))
Coming back to McLaren and those holes mentioned in my previous post, i found an Interesting photo of a mechanic adjusting the incidence of the active aerodynamics flaps through an access hole in the nose. Many teams use this solution, which was previously located directly on the flaps.
De Wet
Re: Mclaren MCL40
Looks like a mini "water slide" towards the rear of the sidepod before it flattens at the rear...
McFAN
McFAN
21
Re: Mclaren MCL40
De Wet wrote:
19 Feb 2026, 13:15
https://cdn.racingnews365.com/2026/Norr ... 1771498531
is this a new less downwashing version ?
De Wet
Re: Mclaren MCL40
McFAN wrote:
19 Feb 2026, 13:32
De Wet wrote:
19 Feb 2026, 13:15
Does look different to me... Not 100% sure though.
CjC
CjC
Re: Mclaren MCL40
De Wet wrote:
19 Feb 2026, 14:09
McFAN wrote:
19 Feb 2026, 13:32
De Wet wrote:
19 Feb 2026, 13:15
I’m not sure that it is. Check out _cerber1 post on page 20 of this thread. Looks to have mini water slides in that pic too- if they are even water slides.
Just a fan's point of view*
Re: Mclaren MCL40
Brake duct internal
Beware of T-Rex
Re: Mclaren MCL40
Flow viz. Notice how the upper-rear control arm redirects air upwards towards the sidepod inlet.
Beware of T-Rex
SilviuAgo
122
Re: Mclaren MCL40
One of the more interesting areas on this year's cars is the front wing, and more specifically its side part, where teams are using various aerodynamic concepts. Below I’m sharing an interesting comparison of all the versions.
_cerber1
295
Re: Mclaren MCL40
McG
-24
Re: Mclaren MCL40
_cerber1 wrote:
20 Feb 2026, 14:50
For anyone who doesn't speak Italian...
"McLaren has brought a very open bonnet vent, a quite noticeable difference compared to the version seen in the last few days."
Different angles though. It looks a lot more open because the angle is lower.
Finally, everyone knows that Red Bull is a joke and Max Verstappen is overrated.
McFAN
McFAN
21
Re: Mclaren MCL40
McG wrote:
20 Feb 2026, 16:40
_cerber1 wrote:
20 Feb 2026, 14:50
It is a lot more open
look at the gap to the exhaust.
CjC
CjC
Re: Mclaren MCL40
I haven’t followed the tv pictures at all really this test.
The McLaren looks low at the front. Front wing end plates touching the ground on roll, the front of the floor skimming the tarmac- a trait from the MCL39.
Have they had the car this low all test or have they been gradually lowering it as
they go?
Re: Mclaren MCL40
That outlet is massive. Largest opening that they have run in the last 3 years.
Beware of T-Rex
