Audi R26
Re: Audi R26
JRodrigues wrote:
17 Feb 2026, 19:51
Tobi Grüner with the burnt sidepods on the R26..
https://pbs.twimg.com/media/HBXc6XPagAAbsaZ.jpg
And what is that little slot below?
Tire temp sensor
Beware of T-Rex
Owen.C93
Owen.C93
192
Re: Audi R26
JRodrigues wrote:
17 Feb 2026, 19:51
I think it’s a drain hose outlet. Williams have something similar.
Never really been confirmed though.
Brahmal
Brahmal
89
Re: Audi R26
Probably tire temperature sensor.
Brahmal
Brahmal
89
Re: Audi R26
lh13
lh13
Re: Audi R26
Audi using Alpine styling active rear wing.
Jakxy
Jakxy
Re: Audi R26
lh13 wrote:
18 Feb 2026, 09:58
You can’t copy that in a couple days , imo Audi was already working on that.
lh13
lh13
Re: Audi R26
Jakxy wrote:
18 Feb 2026, 11:51
lh13 wrote:
18 Feb 2026, 09:58
Probably started after Barcelona.
Re: Audi R26
lh13 wrote:
18 Feb 2026, 12:09
Jakxy wrote:
18 Feb 2026, 11:51
lh13 wrote:
18 Feb 2026, 09:58
People noticed in the first Bahrain test that Audi's rear wing wasn't closing properly at end of straight. So this probably already happened in Barcelona which is why they redeveloped the wing.
Beware of T-Rex
Re: Audi R26
It looks convex here? :wtf:
Beware of T-Rex
leblanc
Re: Audi R26
18 Feb 2026, 20:42
Have they changed the sidepod again? :shock: It looks convex here?
https://i.postimg.cc/y8R0cdgb/image.png
tbf that's a pretty potatoey frame grab
Re: Audi R26
Strange parts mounted to the front cake tin.
Beware of T-Rex
Re: Audi R26
19 Feb 2026, 09:22
https://i.postimg.cc/G3DZqxkQ/image.png
https://i.postimg.cc/PqcRMCJV/image.png
Monitoring component rubbing
Brahmal
Brahmal
89
Re: Audi R26
18 Feb 2026, 20:42
There's definitely a new bulge there at the base of the sidepod that can partly be seen in the subsequent image. It's much wider at the base and tapers down with height.
JRodrigues
JRodrigues
Re: Audi R26
Some more flowviz by Tobi Grüner:
GioKer32
GioKer32
Re: Audi R26
JRodrigues wrote:
20 Feb 2026, 12:31
https://pbs.twimg.com/media/HBmBaBhXgAAzn0d.jpg
May anyone help in understanding what the flow viz pattern allows to see? Take this image, upper flap: some outwash is visible due to the tip vortices plus the flow stays attached where the colour is uniform. But there is a clearer line (with less paint) on that same flap which to me is less obvious. Is that transition? Separation and reattachment?
