Badger wrote:
20 Feb 2026, 11:40
20 Feb 2026, 11:38
Badger wrote:
20 Feb 2026, 10:33
Brain drain is simply not an excuse for Honda because there has been almost none of it.
It's not brain drain in the classic sense. HRC shut down a lot of the F1 attache. People retired, moved to other departments within Honda, and so on. So they lost quite a bit.
Yes, but that part was self-inflicted and more about shuffling people internally. The idea that the competence at Honda was acquired by RBPT and that is why they are now struggling is for the birds.
Agree.
Beware of T-Rex
RA626H. You can make out parts of the induction system here.
Beware of T-Rex
krich
krich
21 Feb 2026, 17:19
https://pbs.twimg.com/media/HBmiHSXaEAA ... ame=medium
That’s some serious tight packaging lol
lio007
327
Similar to aero testing restrictions the PU manufacturers also have a limited amount of test bench runs at their disposal. They already have to do extra reliability test runs and use some testing allocation... which hampers them on future development. Will be interesting to see how they dig themselves out of the mud.
ObsessiveHamster
You’ve been posting this AI slop in other threads as well, without adding anything of value of your own thoughts and input.
Cold Fussion
Cold Fussion
96
delsando53 wrote:
22 Feb 2026, 14:05
Increase in compression ratio?
1. Piston Crown with Gradient Thermal Expansion Profile
Concept: Machine the piston crown (dome) with a tapered thickness gradient (thinner at center, thicker at edges) from allowed single-piece iron-based alloy (e.g., 42CrMo4 per 15.8.1). This promotes uneven axial expansion: the hotter center bulges more than the periphery, reducing chamber volume at runtime. Pair with aluminum block/head for radial bore expansion that complements the effect without conflicting.
Achieving 20:1+ CR: Cold test: 16:1 compliant. Hot (~100-150°C): ~0.15-0.25mm axial growth shrinks volume by 6-12%, yielding 20-23:1 effective. Practical via precise CNC machining (no major changes).
Reliability/Low Failure: Gradient reduces stress concentrations; oil cooling jets (per 5.25) prevent overheating. Proven in endurance testing (Appendix 4); <0.5% failure risk with standard tolerances (±0.1mm bore per 5.6.1).
Outside-the-Box Twist: Incorporate allowed micro-texturing (laser-etched patterns per 15.7) on the crown to create "thermal pockets" that trap heat locally, amplifying targeted expansion like a passive heat sink—enhances stability without added mass.
2. Cylinder Head with Embedded High-Expansion Inserts
Concept: Use permitted "other inserts" (non-combustion-exposed initially, up to +1% volume per 5.3.7/15.8.8) in the aluminum head, made from high-expansion aluminum-lithium alloy (≤2.5% Li per 15.9.3). Position annular inserts around valve seats or spark plug bosses; they expand inward at heat, encroaching on chamber space. Head remains single-piece; inserts interference-fitted.
Achieving 20:1+ CR: Cold: Inserts recessed, CR=16:1. Hot: 0.08-0.15mm protrusion reduces volume 4-8%, for 19-21:1. Combines with deck height min 168mm (5.6.8) for fine control.
Reliability/Low Failure: Inserts limited size; coatings (up to 0.8mm thick per 15.7.2) prevent galling/loosening. Thermal cycling tested (dyno runs per Appendix 4); negligible risk with vibration isolation.
Outside-the-Box Twist: Design inserts as hollow "bladders" filled with compliant low-melt wax (phase-change material per 15.2 exemptions), which expands volumetrically at temp—acts like a mini-piston, boosting effect reliably without mechanics.
3. Special Exhaust Valves with Extended Tulip Expansion
Concept: Optimize hollow, sodium-filled exhaust valves (per 15.8.6, min stem Ø4.95mm per 5.6.12) with an elongated tulip head geometry (head Ø27-29mm per 5.6.14). Use nickel-based alloy for higher axial expansion; at heat, the tulip "stretches" deeper into the chamber when seated, reducing volume. Intake valves (solid) balanced for symmetry.
Achieving 20:1+ CR: Cold: Standard seating, 16:1. Hot: ~0.1mm deeper seating cuts volume 3-6%, achieving 18-20:1 (stackable with other methods for 22:1+). Fixed cam profile (no VVT per 5.9.2).
Reliability/Low Failure: Sodium cooling aids heat dissipation; proven valve tech with <1% failure in high-rev ops (up to 10,500 rpm per 5.5). No changes to conrod length (119.5-120.5mm per 5.6.9).
Outside-the-Box Twist: Angle valves slightly (allowed within tolerances) with a "canted" seat insert that warps minimally at temp, creating a conical volume reduction—like a passive iris, enhancing combustion without wear.
Additional Outside-the-Box Ideas for Power Gains (Beyond CR)
These exploit other 2026 rules gray areas for +15-30 hp, reliable and practical without major redesigns:
Optimized Fuel Atomization via Injector Geometry: Use high-pressure direct injection (up to 500 bar per 5.10) with multi-hole nozzles shaped for thermal vaporization enhancement. At hot temps, fuel pre-heats passively in lines, improving combustion efficiency (sustainable fuels per Article 16). Gain: 10-15 hp; reliable with standard filters.
Passive Turbo Spool Assist via Exhaust Pulse Tuning: Tune exhaust manifold lengths (fixed per 5.8) for harmonic resonance at mid-revs, reducing lag without MGU-H. Pair with valve overlap minimization—boosts torque by 5-10%. Low risk; dyno-tuned.
ERS Battery Thermal Management Loophole: Exploit no explicit temp limits on ERS components by using phase-change insulation (per 15.2) around the battery (4 MJ delta per 5.14). Maintains optimal 60-80°C for efficiency, adding 10-20 kW deployment. Passive, reliable.
Crankshaft Bearing Surface Optimization: Maximize allowed bearing areas (≥2500mm² mains per 5.6.6) with micro-grooved coatings for reduced friction at high temps. Lowers parasitic losses for +5-10 hp; no failure risk with oil systems.
Why do you constantly post LLM crap without disclosure? Is this a crappy bot account or someone trying to role play as an engineer?
gansaraku
gansaraku
Cold Fussion wrote:
delsando53 wrote:
22 Feb 2026, 14:05
The thermal expansion argument doesn’t hold up physically.
Typical coefficients of thermal expansion:
Steel (e.g. 42CrMo4): ~11–13 µm/m·°C
Aluminum alloys: ~21–23 µm/m·°C
If a 40 mm piston crown heats up by 100–150°C, the real axial growth is only:
≈ 0.04–0.06 mm
Not 0.15–0.25 mm.
And that’s best case.
In reality, the head and block expand too, so the net chamber volume change would be even smaller.
There simply isn’t enough thermal expansion available in these materials to shift compression ratio from 16:1 to 20:1.
Physics limits it long before regulations do
Enviado desde mi M2007J3SG mediante Tapatalk
Craigy
87
gansaraku wrote:
22 Feb 2026, 16:33
If I put a void in the top of the cylinder head with a reed valve (simple bimetallic strip) tuned to be closed at combustion temperatures but open during room-temp and/or 130C testing (as you like), I can make practically any compression ratio I want.
If I put this void in the TJI injector assembly I can make it exceptionally fast to swap out and/or tune the void volume, the reed valve open/close temp and/or shape of the throat for resonation.
I was shouted down for saying this a few weeks ago. What exactly would stop it from being possible, and what exactly would stop it from being legal to the currently written rules?
From where I sit, nothing and nothing are the two answers, but I'd be happy to listen.
Rodak
Rodak
37
What exactly would make it work, and what exactly would make it legal?
delsando53
delsando53
ObsessiveHamster wrote:
22 Feb 2026, 15:29
Fair enough if my posts came across as low effort to you I can see how that might look from the outside.
Just to clarify where I'm coming from:
I'm not an engineer, researcher or expert. I'm a regular person who's genuinely curious about this topic. I find it interesting to feed real questions into AI, see what it says, and then bring those answers here to see if people think they're plausible, complete nonsense, or somewhere in between. That's literally all I was doing testing ideas in a discussion space and hoping for some actual thoughts in return.
I didn't post to spam, promote, or annoy people. I thought forums like this were exactly for exchanging ideas (even half-baked ones) without instant judgment. If I dropped it in the wrong thread or over-posted, that's on me I apologise
But calling someone's genuine curiosity " zero value…. It basically tells normal people "stay in your lane, only experts allowed to be curious here". Anyways point taken :)
Cold Fussion
Cold Fussion
96
delsando53 wrote:
22 Feb 2026, 23:16
I'm not an engineer, researcher or expert. I'm a regular person who's genuinely curious about this topic. I find it interesting to feed real questions into AI, see what it says, ...
If you are genuinely curious then perhaps do some actual reading on the topic, idle curiosity existed before 2022 so I have full faith in your ability to intelligently engage in topics that interest you.
delsando53 wrote:
22 Feb 2026, 23:16
... and then bring those answers here to see if people think they're plausible, complete nonsense, or somewhere in between. That's literally all I was doing testing ideas in a discussion space and hoping for some actual thoughts in return.
You and I have a fundamentally different view as to what constitutes a discussion. Writing a prompt and then posting a firehose of --- onto a message board devoid of any context or original thought is not a discussion, it's just yet more useless noise everyone else has to deal with.
delsando53 wrote:
22 Feb 2026, 23:16
What ideas are you exchanging? The point of messages boards is talking to real people, and the value of this board specifically is there are a lot of qualified. technical people here which can provide real insight to complex topics. Diluting that by bombarding the forums with a firehose of nonsense from LLM's makes the experience worse for everyone else. Perhaps you can ask your preferred LLM about the concept of dead internet theory.
delsando53 wrote:
22 Feb 2026, 23:16
No one is saying stay in your lane if your not an expert, in fact there has been a lot of inane posts here over the years and they still at times provide interesting discussion, but just showing up and dumping ai slop on everyone and saying "how about that" leaves a poor taste in peoples mouths.
urbanglowcam
21 Feb 2026, 17:19
Wow. Thanks for sharing this shot. I haven't seen the same glimpse from other teams' powertrains but is having the powertrain this tightly packed typical or does this lean more towards the "size zero" 2015 McLaren Honda philosophy?
ryaan2904
ryaan2904
36
21 Feb 2026, 17:19
Any reason why Honda stick to A2A intercoolers unlike Mercedes or Ferrari?
CFD Eyes of Sauron
gearboxtrouble
gearboxtrouble
ryaan2904 wrote:
23 Feb 2026, 03:28
21 Feb 2026, 17:19
Guessing same reason as Red Bull - weight and packaging. A2A intercoolers are lighter and can be mounted higher up which lets you shrink the sidepod intakes.
21 Feb 2026, 17:19
I think we can see more than at first glance. The rear left mounting hardpoint in the launch photos of the RA626H is visible under the bodywork. So this gives a reference for how the intercooler, intake and the rest of the components are installed relative to the chassis.
Beware of T-Rex
