Audi R26
Re: Audi R26
I think that is the gearbox and rear end on the right.
Beware of T-Rex
Brahmal
Brahmal
75
Re: Audi R26
Is that Binotto under the car?
Re: Audi R26
Beware of T-Rex
Re: Audi R26
Nicolas Carpentiers from Melbourne
Beware of T-Rex
Re: Audi R26
Beware of T-Rex
vorticism
vorticism
449
Re: Audi R26
Hollow spokes there, just very wide spokes.
vorticism wrote:
10 Jan 2026, 02:39
Flat-faced wheel spokes.
Re: Audi R26
vorticism wrote:
11 Mar 2026, 00:07
vorticism wrote:
10 Jan 2026, 02:39
https://i.postimg.cc/LX5NW5m3/Screensho ... 0103-3.png
ah that's very clever.
Beware of T-Rex
Farnborough
Farnborough
152
Re: Audi R26
Good detail of the split top "wishbone" as effectively two separate and simgular struts to form that arrangement.
Look at the outer end at the upright, see how far they are displaced vertically, one from the other, at that location.
Farnborough
Farnborough
152
Re: Audi R26
vorticism wrote:
11 Mar 2026, 00:07
vorticism wrote:
10 Jan 2026, 02:39
Clever design in concept certainly.
Effectively a "negative" image of how we conventionally think of spokes by flipping the thinking in this application.
Re: Audi R26
Something that always fascinated me is how the steering linkage uses such a narrow connection to the inner ball joint of the steering rack. Perhaps the load isn't very high if the geometry is correct (no POU, no scrub radius, high leverage relative to kingpin).
Beware of T-Rex
Stu
Re: Audi R26
Farnborough wrote:
11 Mar 2026, 00:20
And having just seen the wreckage photo in the W17 thread (thank you AR3-GP 🙏), not a universal thing to do.
Although we think of multi-link designs as a new tech approach, it is more in line kinematically with the old 1950’s & 1960’s approach (separated control arms and links); the big difference is the vertical displacement, which does make visually examining the suspension behaviour near impossible (makes a mockery of the ‘loads of anti-xxxx there’ comments). I have it on very good authority that it very specialist software is required to analyse the kinematics of modern multi-link systems.
Farnborough
Farnborough
152
Re: Audi R26
Stu wrote:
11 Mar 2026, 08:51
Farnborough wrote:
11 Mar 2026, 00:20
Its something that Audi themselves possess considerable experience around. Their A8 chassis birth brought this split top wishbone, not vertically but longitudinal in layout, to their car platform in early 1990s.
Essentially to deal with front driven wheel needs (Quattro & front drive iteration) dynamics by extremely detailed presentation of that tyre to road surface within constraint challenges.
It's a double "wisbone" installation with effectively separated "pushrod" spring and damper (without location duties) applied to near the base of upright location.
Ultimately, in that usage, it concisely controls the space in which the wheel moves very tightly through steering, while also bringing more advantageous control of contact tyre patch dynamics in presenting it to road surface.
That chassis was also multi link rear too. Folded into small space form with castor, camber and toe link independence in design.
They must possess significant knowledge and evaluation of such system as routine, plus James Key also advanced in this type thinking in previous chassis, going back to Toro Rosso concept that others copied.
Re: Audi R26
Motorsport Italy says Audi is the only team running 8 piston brake caliper (4 piston per side).
https://it.motorsport.com/f1/news/f1-au ... /10804434/
Beware of T-Rex
Brahmal
Brahmal
75
Re: Audi R26
12 Mar 2026, 20:44
The article also says "four pads." So two pads per front brake?
Re: Audi R26
Brahmal wrote:
12 Mar 2026, 21:20
12 Mar 2026, 20:44
Four pads would mean two on each side of the brake caliper. To be clear, the 8 pistons are also distributed 4 per side of the caliper. So the front brake calipers (left and right) would have a total of 16 pistons, and 8 pads. Sounds a bit mad :lol:
Beware of T-Rex
