Red Bull RB22
Cassius
Cassius
Re: Red Bull RB22
venkyhere wrote:
05 Mar 2026, 13:40
euv2 wrote:
05 Mar 2026, 13:00
Verstappen come Leclerc in low-profile mode: "I think we still have quite a bit of work to do to be on the front row, but it's something I had already anticipated." There's a lot of concern even outside of Honda (egregious case) regarding the vibrations generated by the engines. Red Bull PT had to lower its Power Unit in the second test precisely for this reason, and even Mercedes isn't totally confident in terms of reliability. It'll be a weekend to follow entirely #AutoRacer #AusGP #F1
What impact could this have besides lower CG?
I think it's a language barrier issue. "Lower" (used by google translate) wouldn't necessarily mean physically lowering the engine mounting (which I don't think is possible to do in the pitlane without a change in the monocoque) , it could most likely mean 'lower engine mode' , since running in higher power mode possibly produced larger vibrations.
Of course it is lower engine mode.
More important question is, is this reliable info . Only 1 source saying RBPT also has vibration issues, an Italian one?
if you look at telemetry between first and second week, you only see that the week 2 practice 3 low fuel runs by Max had some conservative modes, especially in s3.
So I don't believe this story at all.
Re: Red Bull RB22
Beware of T-Rex
Re: Red Bull RB22
LolImage
Re: Red Bull RB22
Beware of T-Rex
SiLo
144
Re: Red Bull RB22
Doesn’t this inner tunnel quickly ramp down to a flat floor? I think people aren’t getting that there isn’t a tunnel all the way along the floor there.
Felipe Baby!
Re: Red Bull RB22
SiLo wrote:
06 Mar 2026, 02:40
That's also a question that I had. It's not a true tunnel.
Beware of T-Rex
Re: Red Bull RB22
Melbourne
Old front wing is dummy wing for pitstop practice.
Beware of T-Rex
venkyhere
43
Re: Red Bull RB22
06 Mar 2026, 02:47
SiLo wrote:
06 Mar 2026, 02:40
No it isn't. We were aware that it isn't a tunnel anyway when we saw it in Bahrain2.
It is, however, a venturi-like mouth between the tub and the innermost 'dagger' => strong longitudinal vortex running near the center of the floor, hugging the keel
venkyhere
43
Re: Red Bull RB22
06 Mar 2026, 06:05
beneath halo "ROKT pipe" with it's own cooling exit, is no longer there, replaced by tight body panel.
Cassius
Cassius
Re: Red Bull RB22
venkyhere wrote:
06 Mar 2026, 06:56
Als the rear cooling exit is tighter vs Bahrain as expected.
Badger
Badger
46
Re: Red Bull RB22
Shrunk cannon outlet and no sidepod cooling outlets.Image
Ft5fTL
30
Re: Red Bull RB22
SiLo wrote:
06 Mar 2026, 02:40
We use very similar ruleset here on the MVRC. Ofcourse im not %100 sure that the mandatory surface areas are the same so need clarification about it. There is some kind a loophole on the rules on our challenge that kinda allows some extension on the leading edge with an aggresive turning vane that kinda reminds last years floor leading edge. The only requisite for this kinda design is tightly packaging on the stepped area.
Here is an example image. The highlighted part is the RS-FLOOR-STEP part.
Mantium Challenge - Pure Power Racing
djos
130
Re: Red Bull RB22
Here’s some RB22 photos I took last night. The brake calliper in bits is very cool. It’s a shame Imgur doesn’t let you post the full res photo.
Plus one of the RedBull team showing off last years steering wheel.
https://imgur.com/gallery/redbull-rb22- ... gp-h1VgkDV
Edit: figured out how to get a preview working - full album is via the link above:
"In downforce we trust"
Re: Red Bull RB22
djos wrote:
07 Mar 2026, 00:42
Here’s some RB22 photos I took last night. The brake calliper in bits is very cool. It’sa shame Imgur doesn’t let you post the full res photo.
They really rolled out the red carpet for you. Nice shots!
Beware of T-Rex
djos
130
Re: Red Bull RB22
07 Mar 2026, 00:47
djos wrote:
07 Mar 2026, 00:42
Cheers. RedBull and Racing Bulls gave us access all the way up to the front of the garage, it was pretty amazing. My wife works in the Disability support sector (became a pro at navigating the systems as our son has severe Autism/ADHD) and the Melbourne GP reserves the Friday night pit-lane tour for parents and their kids with a disability.
Btw, here's some RB22 PU testing I filmed - turn it up till your ears starting ringing, and that's how loud it was. it definitely sounds different to last years Honda.
