2026 McLaren Mastercard F1 Team
Darth-Piekus
-1
Re: 2026 McLaren Mastercard F1 Team
Half the teams had deployment issues.
Emag
Emag
137
McLaren have a huge efficiency problem. The shorter gear ratios might have been the wrong call too, it will leave them vulnerable on tracks with long straights like this one.
But I am sure McLaren are not happy at all looking at the traces against Mercedes this session. They might be decent in some corners, but it doesn't matter in this formula. You need efficiency and battery management.
To clip more and have less overall deployment time with the same PU is a kick in the face.
They will have to pull another 2023-like mid-season upgrade to get this car into a position where they can win.
Developer of F1InsightsHub
bluechris
That cannot change the gearbox immediately if this is the only difference? They can keep the current one for the short track's.
Emag wrote:
07 Mar 2026, 09:22
I agree it's not just "we don't know what we're doing with the deployment because we're just a customer". They set short gear ratios because the car is draggy. Gear ratio is always tuned to the aero top speed. This is an energy efficiency formula. That drag is energy that cannot be recovered so you clip earlier and can't harvest as much. It snowballs.
That's also why (imo) Mclaren is even slower in race trim. The recovery limit increases to 8 MJ which hurts them even more because you use more energy than you can harvest if the car is not aero efficient. Remember we were having that discussion on test 2 night sesion with the PIA vs VER long runs where Mclaren had no top speed. It is because of the snow ball effect in the long runs.
#ReleasetheADUO
Darth-Piekus
-1
So its not aero issue but more from the engine and battery.
SilviuAgo
129
Limited running in FP1 due to broken gearbox/clutch
Engine issues in FP2
Interrupted FP3 and deployment issues
Deployment issues in Q1
Deployment issues and no power at the session end in Q2
Deployment issues in Q3 + broken front wing in the last run
And still he has also some positive outcome and happy with the quali position! Keep pushing!
Emag
Emag
137
Darth-Piekus wrote:
07 Mar 2026, 09:32
Engine and battery is not what's making the difference with Mercedes so I don't know what made you arrive to this conclusion :lol:
I think McLaren have got it very wrong, concept-wise. I don't know how hard it is to make a big shift within the season, but this car, the way it is right now, cannot win anything except for maybe Monaco.
Darth-Piekus
-1
Why do you think the concept is wrong aerowise? Both Mclaren seemed to have had problems unrelated to aero all tied to engine and battery deployment.
Emag
Emag
137
07 Mar 2026, 09:24
I think this is mostly it as well. It was probably not just the deg that was killing them in Bahrain, but they had less and less total energy remaining with each lap of a long stint until they couldn't deploy enough in a lap anymore.
Mercedes has the whole thing completely nailed.
_cerber1
299
I think it's too early to talk about aerodynamics and gear ratios until we solve the excess weight problem. Yesterday I saw a figure of 6 extra kilos; that's just a huge overweight.
haza
haza
I don’t think there’s any fundamental issue with the car Mercedes is faster almost everywhere on the straights and corner. Exits they simply have a better understanding of deployment and harvesting which is to be expected as they made the pu in the first place this was mentioned throughout testing and practice once McLaren have a better understanding of the hybrid system they’ll close up to a degree but this seasons going to be a massive development race anyway I’m quite happy all things considered 3rd best team at least ain’t a bad way to start a new set of regs especially considering the teams track history when it comes to a new regs reset
Emag
Emag
137
Darth-Piekus wrote:
07 Mar 2026, 09:36
Because the car is quite clearly very draggy. A trait they have carried over from the last two years, which unfortunately for them is a really big problem for this regulation set. Mercedes are forced, by regulation, to provide the same power unit to their customers as the one they use themselves. Any difference you see in deployment and top-end performance is all down to chassis efficiency. It doesn't matter how fast you are in the corners if you deplete the battery halfway down the straight.
Think of it this way. The battery power required to accelerate from 250 to 300 kmh (for example) is way way higher than 100 to 150 only because of drag. Drag "wastes" energy. If you are 5% more efficient, it makes a big difference in how much total power you have through the lap. It could easily be half a second if you can deploy for 1-2 seconds more throughout a lap.
Emag wrote:
07 Mar 2026, 10:24
The fact that straight line mode was removed between T8 and T9 today and McLaren turns out to struggle way more than others just points more and more to an overall efficiency problem.
They initially removed the zone but then put it back in place because the teams protested.
Mclaren was experimenting with rear wings perhaps trying to gain a bit of efficiency: viewtopic.php?p=1332042#p1332042
#ReleasetheADUO
_cerber1
299
Emag wrote:
07 Mar 2026, 10:02
I don't understand why you constantly criticize McLaren when they're not living up to your high expectations. The team is starting the season with the most significant changes in F1 history, and they have the fewest resources at their disposal. They clearly need time to optimize everything and catch up with the leaders. The worst thing is that you have a large following, but you don't feel responsible for your words.
f1isgood
f1isgood
_cerber1 wrote:
07 Mar 2026, 10:35
Emag wrote:
07 Mar 2026, 10:02
All Emag states is mostly factual. "Amazing" response.
