BigBeansBoy wrote: ↑05 Mar 2026, 15:421. Is the standard part from the FIA so it can’t have changedDe Wet wrote: ↑05 Mar 2026, 14:57https://i.ibb.co/G4sb5wWQ/image.jpg
Changes I have noticed. Looks like the Beam Wing (4) has a lower angle.
It would be interesting to look in the telemetry to see how top speed is affected, but then we won't know if it's just different deployment.SilviuAgo wrote: ↑06 Mar 2026, 17:28Piastri and Norris with a different rear wing design, flow-vis for Norris' wing
https://pbs.twimg.com/media/HCuWpz4XIAA ... name=large
Oscar was generally higher most of the laps I checked but not sure if it was a case of Lando running more conservatively.AR3-GP wrote: ↑06 Mar 2026, 20:08It would be interesting to look in the telemetry to see how top speed is affected, but then we won't know if it's just different deployment.SilviuAgo wrote: ↑06 Mar 2026, 17:28Piastri and Norris with a different rear wing design, flow-vis for Norris' wing
That’s the mandated part of the nose that’s meant to crumble I think. The actual crash structure is rearwards of it.
It's not. In the new regulations there's a 2 part crash structure in the nose. Intention is to have protection left for a secondary impact. What we're seeing is how it's supposed to have worked.
