Ferrari SF-26
fourmula1
fourmula1
Re: Ferrari SF-26
Is the section below solid or is that a tunnel the exhaust gas goes into the crash structure? Is that possible?
bananapeel23
34
Re: Ferrari SF-26
fourmula1 wrote:
06 Mar 2026, 14:59
I don't think the crash structure could handle the heat, given that they chose to make the exhaust gas deflector out of metal, while the crash structure is made of carbon fibre.
fourmula1
fourmula1
Re: Ferrari SF-26
If it is truly just a blocking plate is it more to increase the exhaust speed rather than be a wing that directs it upwards?
There could very well be a hole there?? The Ferrari still smokes a ton out of the back of the crash structure.
F1NAC
173
Re: Ferrari SF-26
That smoke is from oil breather and the pipe exits from crash structure.
Stu
Re: Ferrari SF-26
venkyhere wrote:
04 Mar 2026, 20:32
matteosc wrote:
04 Mar 2026, 20:22
venkyhere wrote:
04 Mar 2026, 18:22
Ah.
That makes more sense.
Assuming a baseline top speed of 330 kph with normal wing, that would mean
Cd (macarena) = 0.9559 x Cd (normal), a drag reduction of 4.4% for the extra 5kph, which sounds realistic.
(higher baseline top speed would mean smaller reduction)
The number reported was kW, not km/h. 4-5 km/h would be huge, but it is not what is rumored to be.
As the crude calculation showed, 4-5 KW is too little gain for inventing a whole new rear wing system. Which could mean, that the aim of the macarena wing is not really drag reduction, but something else like play-room for lower static rear ride height
From my background in Cycling Time Trials, we would discuss aero improvements from a Watt perspective, we all knew that they were ‘virtual’ Watts, but we were measuring our own output. Every watt ‘saved’ with aero improvements was converted into increased speed (and reduced time.
If (if!!?) this is using the same reasoning what team would overlook the performance equivalent of 4-5kW of motive power for the length of each straight section?
Or, if you want to look at it another way, would you give up on being able to save 4-5kW of fuel demand to maintain the same pace as the cars you are following?
Both are achievable and deliverable every lap. There is a net-positive effect on battery use, start weight and lap-time from both.
Re: Ferrari SF-26
#ReleasetheADUO
catent
Re: Ferrari SF-26
Something I noticed during qualifying is that Ferrari doesn't have those long, flat endplates, which extend out from the upper part of the front-wing, parallel to the ground.
McLaren and Mercedes do, and I thought Red Bull did, too, but upon looking at photos of their car, it appears they, like Ferrari, do not.
venkyhere
43
Re: Ferrari SF-26
catent wrote:
08 Mar 2026, 02:37
https://www.formulaonehistory.com/wp-co ... 0x580.webp
https://images.immediate.co.uk/producti ... e=1000,667
https://images.ps-aws.com/c?url=https%3 ... 20x742.jpg
https://images2.minutemediacdn.com/imag ... 0jw9vv.jpg
They are called 'diveplanes' colloquially. Like the ones you see on the sides of a submarine. Their purpose in these front wings is to generate spinning vortices that propel around the outside of the front tyres.
Great pics, btw. Helps compare the different wing levels across the teams.
Re: Ferrari SF-26
One of the reasons that the FIA momentarily decided to remove the active aero zone between T6 and T9 in Melbourne is because some drivers said they were sliding in the curves with the wings open in this zone, especially when following other cars in dirty air. I can't imagine how that would have felt if you also have a flipping rear wing that reduces the load even further.
I think the flipping wing has to be somewhat track specific. It works when the straights are straight. When the straights are curved and you need more maneuverability in wheel-to-wheel, I'm a bit more skeptical that the drivers would want it. You need a minimum amount of load to remain maneuverable at high speeds.
#ReleasetheADUO
bluechris
Re: Ferrari SF-26
09 Mar 2026, 08:39
For the tracks you mention that the straights have slight turns, they cannot have it but with a wing degree that gives them not the full potential but a bit less to be safe? if offcourse its better than the normal wing.
Re: Ferrari SF-26
bluechris wrote:
09 Mar 2026, 10:56
09 Mar 2026, 08:39
Yes that's a good idea. They should fine tune the amount of load that they are dropping for each track. They have to make sure the car doesn't become dangerous in dirty air racing.
#ReleasetheADUO
Brahmal
Brahmal
74
Re: Ferrari SF-26
bluechris wrote:
09 Mar 2026, 10:56
They are only allowed to have the wings in 2 positions during a race, open and closed, no intermediate steps allowed. However, nothing is stopping them from adjusting the wing opening between races. I imagine they would be doing that primarily on the front wing to balance out the car, since a rear wing with DRS-like or macarena opening mechanism might set up unwanted aero interactions if the flap only opens part way. Audi and Alpine with their flat-folding rear wings could theoretically adjust their opening amount without much problem, but not sure why they would want to.
scuderiafan
Re: Ferrari SF-26
09 Mar 2026, 11:00
bluechris wrote:
09 Mar 2026, 10:56
09 Mar 2026, 08:39
I wish we could have actual active aerodynamics like some of the recent hyper road cars from Ferrari, Merc, Pagani. Then you wouldn't be forced into 100% open or 100% closed. But I digress...
"You're so angry that you throw your gloves down, and the worst part is; you have to pick them up again." - Steve Matchett
Patiently waiting...
Re: Ferrari SF-26
@scarbstech
#ReleasetheADUO
porridge
Re: Ferrari SF-26
upside-down wing
