2026 car comparisons
venkyhere
43
Re: 2026 car comparisons
(pics from Australia GP)
1. much more arch-y nose for the RB22 than the W17 (alongwith rest of the field)
2. 'base-bodyline-height' seems to be slightly lower for the RB22 than the W17 (using tyres as reference, btw dont want to get lulled into thinking RB22 has more camber on front, since even if the camera shot is from the same corner at the same angle, we can't know how 'laterally loaded' the front wheels are in both cars) , perhaps from PU sitting 'lower'(?) in the RB22
3. W17 with more spoon on the RW mainplane but with smaller chord length for the flaps
4. W17 with more outward lateral camber on the RW endplates
5. RB22 seems to have the tighter lateral packaging on the engine cover
6. Is the airbox of the RB22 'much bigger' (what we saw in the tests) than the same on W17 ? Something has changed with one of them
7. RB22 with higher nose and more 'gap under FW' than the W17, perhaps the reason for (1) ?
8. FW endplates' upper tip vortex seems to be located very differently - W17's is very outboard ; RB22's is very inboard, almost hinting that it's directed straight at the brake cooling ducts
The Ferrari powered cars are practically silent.
#ReleasetheADUO
Front brake ducts. From left to right: RBR, Mercedes, Ferrari
#ReleasetheADUO
#ReleasetheADUO
Brahmal
Brahmal
74
Nice pictures. It is a little difficult to compare all the brakes because it's unclear what stage of disassembly each of them are. Underneath the outermost cake-tin, how many layers are there generally? Two?
Brahmal wrote:
12 Mar 2026, 21:12
I made this picture when there was a lot of discussion about Mclaren's rear brake drums last year. I would count this as 2 or 3 shells. Depends on if the innermost brake rotor shroud is considered a shell.
#ReleasetheADUO
Brahmal
Brahmal
74
12 Mar 2026, 21:18
https://i.postimg.cc/ry57LrZ4/image.png
About what I thought: outer cake-tin, inner cake-tin, then ducting. It's uncertain whether the rotor shroud is something that all teams have as a separate part or layer. I think some of them incorporate that as part of the ducting layer, Ferrari being one as I don't recall seeing just the rotor shroud in any of their pictures.
Brahmal
Brahmal
74
Here is a couple more pictures of the Audi showing different stages of disassembly. Maybe the idea of "layers" is meaningless as there seems to be a pretty wide variance between teams.
michl420
michl420
12 Mar 2026, 19:44
https://pbs.twimg.com/media/HDOcTq7XoAA ... =4096x4096
This winglets on the inside are all slightly different. Do they not have a fix geometry by regulation?
Emag
Emag
137
Emag wrote:
13 Mar 2026, 13:20
First indication that McLaren's gear ratio choice might be the wrong one for this power unit. I suspected after Australia it might have been an issue. I don't know if it's rectifiable within the season.
Maybe they can win Monaco with this car this year :lol:
Toto hinted that McLaren's choice with regards to gear ratios could be one of the limiting factors for McLaren at the moment. In a way I get the intuitive sense in it, since shorter gears generally mean higher RPMs at higher gears, something which seems desirable for super clipping through the corners. But I am wondering if it's substantially compromising their top end speeds and bleeding laptime down the straights. If they're allowed a change this season, it's likely they lengthen their 8th gear for better top speed while keeping the others relatively close to each other like they have them right now. It would mean using 7 gears most of the time, but keeping 8th for that extra top end speed when needed.
Developer of F1InsightsHub
Brahmal
Brahmal
74
Taking a second look at the steering knuckle, it appears to be 3D printed. At the very least the casting has been designed in a similar way to the "Pareto optimization" that Czinger uses to make the 21C hypercar. Video explainer below, not surprised to see F1 teams already doing this.
OO7
OO7
171
I'm not sure if this is the correct thread and I don't have the screen shots, but both Charles Leclerc and Kimi Antonelli locking up towards the end of the Chinese Grand Prix, gave some insight into the degree of lower, front tyre wake control the Ferrari and Mercedes cars were capable of.
LeQuick
LeQuick
I watched some highlights of the 2024 & 2025 Chinese GP's and it's crazy how large the cars look compared to the 2026 cars even though by F1 standards these a very large.
Brahmal wrote:
16 Mar 2026, 05:31
That's interesting. It probably helps the teams to reduce weight.
#ReleasetheADUO
f1316
88
LeQuick wrote:
17 Mar 2026, 10:27
It’s true - the size reduction this year is much more noticeable than I was expecting. It shows that it’s good to keep chipping away at this - if it were me, I would have small, incremental reductions in car dimensions and weight each year within this regulatory cycle.
