From what we've seen publicly (and logical in the throughput/capacity hike) the MGU is substantially larger in size this year.
1 blink is reduced max mguk powern (for batterie saving)Farnborough wrote: ↑15 Mar 2026, 17:33I saw, and wondered the same.hollus wrote: ↑15 Mar 2026, 17:00I noticed something with the rear facing red lights in the wing endplates.
We are used to them flasing when harvest kicks in, that is still there.
But I noticed that often, not always, they would blink red a single time, at the beginning of the straights or even at the end of the corner just before a straight.
Is that to signal that electric deplowment has started? And why would the guy behind need to know that you will accelerate faster?
P.S. attempting to fix the thread name now that we have more data and less spculation.
Likewise unable to attach definitive reason to it, but thought was toward finishing "harvesting" with at that point full forward torque deployed ? Possibly as the driver ultimately hit full power request in throttle travel.
Perhaps to give some warning to following driver of impending rear ending potential, but couldn't see enough incident to give reasonable correlated comment.
Well, I guess load increases the sound a lot then. For Mercedes it easily overpowers the ICE. (provided they didn't find a special position for the microphone atop the gearbox.Farnborough wrote: ↑17 Mar 2026, 13:11Something that is likely to increase the audible output is the shear load now passing through that gearset from crankshaft in pos & neg direction.
Competition gear sets ordinarily utilise straight cut gears, this for efficiency and load capacity. They make a big racket though
All method of noise and likely potential vibration reduction are dispensed with to reduce power loss when passing through.
I would think that herring bone gears would combine the advantages of both styles. Maybe a minuscule increase in friction.Farnborough wrote: ↑17 Mar 2026, 13:11Conventional gearset use skew/helical cut tooth form to mitigate the above, also needing to be physically larger, for the same load transferred. They do this by the geometry between teeth faces on opposing gear pairs "driving" into engagement with much more sliding together during takup and dissipation of the load as each tooth is used.
That puts more side/axial load into each component, needing more axial support from local "thrust" bearings, and more heat through that sliding action. These of course are simply a waste in F1 performance.
In effect, high highly loaded straight cut minimalised gear set design, when fully loaded, makes a complete "screamer" of a transmission system. That's regardless of MGU location.
The "stuttery" sound is pos and neg "drag" within the gear train, making just enough in that flick/flack effect to emit sound to us. Seems to be generated by crankshaft speed, with the generator intertia unable to follow exactly.mzso wrote: ↑17 Mar 2026, 14:10Well, I guess load increases the sound a lot then. For Mercedes it easily overpowers the ICE. (provided they didn't find a special position for the microphone atop the gearbox.Farnborough wrote: ↑17 Mar 2026, 13:11Something that is likely to increase the audible output is the shear load now passing through that gearset from crankshaft in pos & neg direction.
What do you think of this?:
It goes very silent when there's no load. There is only a stuttery sound, at much lower volume.
Is rotation by the ICE enough for this, or are they doing rev matching?
I would guess a geared electric motor would have substantial negative effect for a race engine if it's just dead-weight rotating. I don't think they'd want flywheels.
Any source for that?1 blink is reduced max mguk powern (for batterie saving)
https://www.youtube.com/shorts/hWFvl57aVvghollus wrote: ↑17 Mar 2026, 20:51Any source for that?1 blink is reduced max mguk powern (for batterie saving)
It sounds unlikely precisely at the begining of traction zones.
Or would it be in the transition from 0 towards max electric deployment? And calling that "reduced". It felt to me like the blink happened in full traction zones, but come to think of it, only from slow corners, so... throttle modulation?
What a bizarre thing to "broadcast".
Well, whatever is it that happens at the start of the straight, if it's brief enough it will only be one blink.hollus wrote: ↑17 Mar 2026, 20:51Any source for that?1 blink is reduced max mguk powern (for batterie saving)
Well, I was thinking a multi 100 kW electric motor might by hefty as a flywheel. So maybe using electricity to match revs when not allowed to drive or regen is allowed? (Both in F1 and WEC)Farnborough wrote: ↑17 Mar 2026, 14:50The "stuttery" sound is pos and neg "drag" within the gear train, making just enough in that flick/flack effect to emit sound to us. Seems to be generated by crankshaft speed, with the generator intertia unable to follow exactly.
If a test is made on a simple automotive alternator, spinning the rotor with electric drill, it spins very free when unloaded, but switching the field coil on when doing that to get power, then you really have to hold tight to it as torque reaction takes place.
What makes it complex to use? I mean you can't just slide the teeth into each other, but I can't think of anything else.Farnborough wrote: ↑17 Mar 2026, 14:50Herringbone is very complex to use, in comparison to a stripped back and crudely simple straight cut gearset. I doubt they've not considered and evaluated everything on the table currently in design of these in place now.
Thanks! Cheers.karana wrote: ↑17 Mar 2026, 21:14https://www.youtube.com/shorts/hWFvl57aVvghollus wrote: ↑17 Mar 2026, 20:51Any source for that?1 blink is reduced max mguk powern (for batterie saving)
Firstly, in this application, just noise output and nobody cares if it does or doesn't. That's the overriding factor here, with ultimate funding available, if its of value in transmitting power with less loss, would have been utilised by now by teams.mzso wrote: ↑18 Mar 2026, 00:39Well, I was thinking a multi 100 kW electric motor might by hefty as a flywheel. So maybe using electricity to match revs when not allowed to drive or regen is allowed? (Both in F1 and WEC)Farnborough wrote: ↑17 Mar 2026, 14:50The "stuttery" sound is pos and neg "drag" within the gear train, making just enough in that flick/flack effect to emit sound to us. Seems to be generated by crankshaft speed, with the generator intertia unable to follow exactly.
In the pre-race show they explained that Antonelli had trouble with his start because the battery was too full, so the ICE didn't have a load on it (from MGU-K) to properly spool the turbo. It sounds like quite a complicated dance to get the start correct. Not using too much battery while trying to warm the tires and brakes, but no overcharging the battery so that you have room to load the ICE against the MGU-K during the 5 second for the best turbo spooling. They'll have to do bespoke calculations for every single circuit.AR3-GP wrote: ↑11 Mar 2026, 00:13Why aren't the teams just charging the battery after the car stops in the grid box? This is permitted by the regulations:
https://i.postimg.cc/9QR6d88Q/image.png
Downside might be that you could overheat the ICE very easily without any airflow in the radiators.
Can't they have a burn off resistor (which can be used to heat up the engine, even) for such cases where battery is full and revvs need to be high ? This is a problem that was beautifully solved by the MGU-H after the KERS era, think of the effort that went into it, and now just because Audi doesn't want it, we don't have it.AR3-GP wrote: ↑19 Mar 2026, 04:31In the pre-race show they explained that Antonelli had trouble with his start because the battery was too full, so the ICE didn't have a load on it (from MGU-K) to properly spool the turbo. It sounds like quite a complicated dance to get the start correct. Not using too much battery while trying to warm the tires and brakes, but no overcharging the battery so that you have room to load the ICE against the MGU-K during the 5 second for the best turbo spooling. They'll have to do bespoke calculations for every single circuit.AR3-GP wrote: ↑11 Mar 2026, 00:13Why aren't the teams just charging the battery after the car stops in the grid box? This is permitted by the regulations:
Well carbon fiber is conductive. Why not pass current through the car?
