Mercedes W17
Re: Mercedes W17
21 Mar 2026, 00:18
mzso wrote:
21 Mar 2026, 00:00
.poz wrote:
20 Mar 2026, 23:49
The wing clearly performs a two-phase motion: an initial instantaneous step followed by a slow secondary movement.
Look at the video at x0.25 speed
Seems bluntly illegal to me, to be honest.
I'm surprised that no one protested it.
No guarantee that other teams spotted it.
.poz
.poz
53
Re: Mercedes W17
mzso wrote:
21 Mar 2026, 00:00
.poz wrote:
20 Mar 2026, 23:49
As far as I understand, there are no rules stating that the closing speed must be linear, nor that it must be the same in every corner; there is only the 400ms limit (which, to the naked eye, seems to be exceeded).
mzso
mzso
76
Re: Mercedes W17
.poz wrote:
21 Mar 2026, 01:05
mzso wrote:
21 Mar 2026, 00:00
.poz wrote:
20 Mar 2026, 23:49
Feels like, by a good margin.
Partymood
Partymood
-3
Re: Mercedes W17
Brahmal wrote:
18 Mar 2026, 05:05
OO7 wrote:
17 Mar 2026, 19:56
I had initially thought the actuator was underperforming and perhaps the reason for Antonelli's lockup towards the end of the race. However I later realised both cars had been doing this all race. It appears to function at its slowest rate at the car's highest speed.
That's when the air resistance is at its greatest so no wonder it takes longer. Doesn't mean that it's intentional, might just need to beef the mechanism up a little.
Never the less, if it takes longer then 0.4 of a second from point A to point B, fully open to fully closed, it can't be legally run in a race or qualifying.
LM10
LM10
127
Re: Mercedes W17
Brahmal wrote:
18 Mar 2026, 05:05
OO7 wrote:
17 Mar 2026, 19:56
Were the other cars driving in a vacuum? Like it was said, weird that no team protested, but they might have not spotted it.
Sempre Forza Ferrari
Stu
Re: Mercedes W17
0.4s is quite a long time (they cover quite a big distance in that time span).
Lasssept
122
Re: Mercedes W17
Xavier Gàzquez
vorticism
vorticism
449
Re: Mercedes W17
The driveshaft has its own dedicated fairing. Six suspension arms. Seven discrete aero elements. The driveshaft fairing must be heavier, stronger than the others, since it wouldn't be able to contact the driveshaft along that half meter span. It couldn't be a simple thin skin like the others.
Martin Keene
Martin Keene
Re: Mercedes W17
The 400ms is an interesting rule, because is that 400ms when the car is stationary or when running, because surely as the aero load builds on the wing during the closing process, the wing will likely slowdown. Very, very fractionally slow down, but when there is a rule measure in ms, details matter.
There is nothing in the rules that mentions whether it is stationary or at speed, so therefore, it must apply in both conditions.
Farnborough
Farnborough
152
Re: Mercedes W17
vorticism wrote:
23 Mar 2026, 13:30
Normally eight arms (effectively two wishbone each side) plus pushrod, plus halfshaft fairing, non load bearing.
They're all in there, but orientation is not easy from camera's angle of approach in that image.
Brahmal
Brahmal
74
Re: Mercedes W17
Martin Keene wrote:
23 Mar 2026, 15:16
"Under all operating conditions" is definitely stipulated in the aero rules, but I don't have time to look it up right now.
Farnborough
Farnborough
152
Re: Mercedes W17
Lasssept wrote:
21 Mar 2026, 23:48
https://pbs.twimg.com/media/HD9RoiSXEAA ... name=large
Xavier Gàzquez
I've got the following arrangement:- the main diagonal link (foremost on car, furthest from camera) as pushrod, and going through the orifice on engine cover to top of torsion bar location.
The two links, immediately closer to camera and above/below that pushrod, are the top wishbone effectively, with large vertical displacement for anti-squat etc.
The two lowest links, in front of and behind the driveshaft cowl/fairing, are effectively the bottom wishbone, with rearmost on car (closest to camera) the rear "toe" link.
Total of 4 links for geometry, 1 for pushrod spring damper actuation, 1 cowl for driveshaft .... and obviously repeated opposite side of chassis.
What do others see ?
JRodrigues
JRodrigues
Re: Mercedes W17
Martin Keene wrote:
23 Mar 2026, 15:16
It is compliant under ambient temperature :-k
Re: Mercedes W17
Stu wrote:
21 Mar 2026, 14:24
It's definitely more than 0.4s and I doubt it's a "gas leak" . The timing of the 1st stop of the front wing is the same as the time it takes to close the rear wing. Here's a video:
and gif:
#ReleasetheADUO
Re: Mercedes W17
edit: or not, see later post.
A source from a rival team indicated to PlanetF1.com that it is commonplace for teams to delay the activation and deactivation of straight-line mode between the front and rear of the car.
However, this usually sees the front wing close later than the rear wing in order to reduce the potential for bottoming and skid wear.
The source added that this critical balance limitation definitely increases the risk of instability in combined braking events.
https://www.planetf1.com/news/lewis-ham ... uch%20more!
#ReleasetheADUO
