Mercedes W17
Re: Mercedes W17
Closing front wing fully 0.4 seconds later means you load the rear of the car more than the front and thus can put more rear brake bias and harvest just that bit more energy than your rivals.
maygun
maygun
Re: Mercedes W17
With fixed wing, if the car becomes quicker, I wonder what the next "theory" of the armchair aero experts would be: https://www.the-race.com/formula-1/myst ... d-f1-2026/
johnnycesup
johnnycesup
Re: Mercedes W17
Yeah, the whole "loophhole" idea was a bit crazy to me.
Still we found a couple of things out:
- The system is hydraulic (a pneumatic system would make very little sense)
- The "low pressure" position is the straight line mode
- Mercedes were probably told to fix it before Suzuka
Farnborough
Farnborough
152
Re: Mercedes W17
maygun wrote:
26 Mar 2026, 10:27
Is there a theory ?
They've got a defined time to close it, without exception or tolerance outside that. Clearly the rules state that for a reason, and they were in breech of a hard limit.
That will always generate conjecture in this sport. We can't see what it did in reality, but suspicion will always come towards such a clear breech.
SiLo
144
Re: Mercedes W17
I wonder if closing the wing in this fashion (if it's not just broken). Helps with the balance shift of the car under braking. If you close the wing AND brake at the same time, maybe the shift in balance is unsettling the car, and closing the wing in this manner maintains a more stable aero and braking platform for the drivers.
Felipe Baby!
GSBellew
GSBellew
Re: Mercedes W17
Would requiring hydraulic pressure to force the wing closed not leave them open to it failing in the straight mode, which is if I am not mistaken forbidden and any failure must see the wing default to cornering mode ?
mzso
mzso
76
Re: Mercedes W17
johnnycesup wrote:
26 Mar 2026, 12:32
Still, it's illegal. And they should be disqualified. If the fuel flow an engine accidentally goes above the limit, even for a moment it's an automatic disqualification. Not penalizing it will just lead to more of these accidentally-on-purpose "miscalculations".
matteosc
matteosc
32
Re: Mercedes W17
mzso wrote:
26 Mar 2026, 15:24
johnnycesup wrote:
26 Mar 2026, 12:32
I agree, because if the car is underweight because of a miscalculation you still get disqualified. The reason why they did not is that they did not gain an advantage. It may be true, but if in Japan they end up having the same behaviour, that would be something extremely suspicious.
To be clear: I think this is nothing and the reasons why they are so fast are others (engine and most importantly software, probably from Formula E experience).
FNTC
FNTC
Re: Mercedes W17
Agree that DQ should have been done if the wing takes more than 400ms to close. Doesn't matter if its by design or due to a problem. The regulation is there for a reason. If you have a fuel leak and finish the race with less than the required fuel amount, you will get a DQ. Etc.
Gridlock
42
Re: Mercedes W17
FWIW according to Merc via The Ted on Sky, "this was an error, a mistake, not by design"
#58
Re: Mercedes W17
johnnycesup wrote:
26 Mar 2026, 12:32
It's pneumatic. Otherwise it would be odd to have a label which says "no gas pressure"? but then this can also be a case of the semantics of german engineers who learn english.
Beware of T-Rex
Lasssept
118
Re: Mercedes W17
maygun
maygun
Re: Mercedes W17
Farnborough wrote:
26 Mar 2026, 12:41
maygun wrote:
26 Mar 2026, 10:27
Is there a theory ?
The theory was that they were using this mechanism as an advantage, with very sure, opinionated arguments.
Re: Mercedes W17
maygun wrote:
26 Mar 2026, 10:27
You're citing an article from a longtime Mercedes sympathizer, Mark Hughes. Same guy that jumps to Mercedes defense every time they are under regulatory pressure. Last time he wrote a rubbish article claiming that the compression ratio reg changed backfired on rival teams and that they would vote against the compression ratio regulations changes that they requested.
 Mercedes' F1 rivals might now vote down their own engine proposal | BY MARK HUGHES
Guess what didn't happen.
Nothing excuses being non-conformant and winning 2 GPs. Mark Hughes should focus on that aspect, winning with an illegal car, and less on running PR service for Mercedes.
Beware of T-Rex
bonjon1979
bonjon1979
30
Re: Mercedes W17
Yeh, it's not intentional for the plank to be worn too thin, or for their to be a tenth of a mm more slot gap in the rear wing. If you don't conform to the regulations then you should be disqualified.
