Aston Martin AMR26
Luscion
Luscion
153
Re: Aston Martin AMR26
madridista
before
after
the outlet is much smaller, while the bodywork behind it is not wrapped anymore
venkyhere
45
madridista wrote:
27 Mar 2026, 14:32
before
https://pbs.twimg.com/media/HEanbN2XEAA ... =4096x4096
https://pbs.twimg.com/media/HEZ6YQVbYAA ... =4096x4096
after
must have figured out that in the tradeoff between :
more cooling flow large hot air exit with more body clearance but in separation to boundary layer
v/s
less cooling flow small hot air exit with minimal body clearance with attachment to boundary layer
the latter flow is beneficial for the rear downforce generating structures
venkyhere wrote:
27 Mar 2026, 15:07
madridista wrote:
27 Mar 2026, 14:32
before
after
v/s
I don't see that as being announced as new. If it was new, it would have been announced in the Car presentation form above. Looks like those 2 pieces are removable with an array of different covers available.
FNTC
FNTC
diffuser wrote:
27 Mar 2026, 15:22
Yeah, weird that the engine cover is not on the car presentation sheet. With the new cover, the old one looks like they had intended to have a slim cover but had to hack together that huge outlet to give the engine some breathing room. And now the new engine cover has been made to fit with that cooling panel under the MAADEN logo.
FNTC wrote:
27 Mar 2026, 17:14
diffuser wrote:
27 Mar 2026, 15:22
My thinking is that the different covers were designed that way from day 1 so technically it isn't new. We just haven't seen all the covers.
madridista
@RosarioGiuliana on X
Waz
Waz
madridista wrote:
27 Mar 2026, 19:25
https://pbs.twimg.com/media/HEaWPkSXIAA ... name=large
Slight difference in angle, but looks like same idea, less load. Which ties in with Japan's higher speed corners.
SSJ4
SSJ4
32
All 4 engine covers Aston martins have brought so far. Not all used
How do you post pictures on here btw?
hollus
¡Puxa Sporting!
Bence
Bence
It's dramatic how this car gets progressively worse and worse above 80-100km/h...
muzzytt
muzzytt
The new cover is added on you can see the screw holes they are obviously trying it out.
Maybe that's why it's not on the list of upgrades.
mzso
mzso
75
Bence wrote:
28 Mar 2026, 02:31
Probably all the damping weight.
SiLo
146
hollus wrote:
28 Mar 2026, 02:19
How to post a picture
Might need to update to say don't post on imgur as a few countries have it banned/disabled?
Felipe Baby!
GhostF1
GhostF1
115
Good wheelbase comparisons but also, drastic differences in the engine cover shape based on packaging underneath (purple line). The Aston is extremely compact. How quickly the line falls from the intake entry and remains really shallow.
