Concept power units from 2030
NL_Fer
NL_Fer
82
Re: Concept power units from 2030
Just realised if we would get rid of the turbo, a GU-H will have an abundance of exhaust gas to recover energy. Also when going back NA engines, we don’t need the fuel flow limit anymore. A 2.4L NA V8 limited to 15000rpm would be pretty equal in power output for all manufacturers.
Also the potential for an exhaust gas race to feed the GU-H would be limited without a turbo to add excess air and lean the combustion.
It would be still pretty efficient converting all the exhaust energy to electric power and hopefully sound nice too.
mzso
mzso
75
NL_Fer wrote:
15 Apr 2026, 07:13
We don't need fuel flow limits with turbo engines either. It's there to force the engines to be efficient.
DenBommer
DenBommer
Maybe we could see Ferrari’s proposal in the next regulation change, like in this article.
It sounds nice to me. I just wonder how much power the ICE will have.
https://web.archive.org/web/20201024202 ... ersteller/
mzso
mzso
75
DenBommer wrote:
17 Apr 2026, 10:56
Why have V8-s with twin turbos? One talking point over the past couple years is making the cars shorter and lighter.
De Wet
mzso wrote:
17 Apr 2026, 12:20
DenBommer wrote:
17 Apr 2026, 10:56
And Sound Like Motorsport.
mzso
mzso
75
De Wet wrote:
17 Apr 2026, 14:58
mzso wrote:
17 Apr 2026, 12:20
DenBommer wrote:
17 Apr 2026, 10:56
Which goes from one cylinder two stroke 50cc to several liter v12-s.
De Wet
mzso wrote:
17 Apr 2026, 16:04
De Wet wrote:
17 Apr 2026, 14:58
mzso wrote:
17 Apr 2026, 12:20
Are we not talking F1 here ?
mzso
mzso
75
De Wet wrote:
17 Apr 2026, 16:33
mzso wrote:
17 Apr 2026, 16:04
De Wet wrote:
17 Apr 2026, 14:58
Well you said, motorsport. So 1.5l to 4.5l, 4-16 cylinders then. With or without turbo.
671
bananapeel23 wrote:
07 Apr 2026, 15:03
A wild concept would be a straight up engine formula, where the PU has an impact on the aero ....
Keep traction control and ABS banned .... Bring back vibration mitigation solution ....
it is impossible to have (eg at the current power of MGU-K) neutrality regarding ABS-like and TC-like behaviours
eg at high speed friction brake torque then sudden under-rotation can subvert GU-K response ...
I had suggested a 'flat-crank' ie 4-throw flat 8 for perfect balance (though it only fires 4 times per cycle)
similarly the 4 cylinder radial or some derived modules
btw
Ferrari has done F1 engines with cylinder counts from 2 to 18
a single and several twins have raced in F1 WDC events
WardenOfTheNorth
mzso wrote:
17 Apr 2026, 19:46
De Wet wrote:
17 Apr 2026, 16:33
mzso wrote:
17 Apr 2026, 16:04
Don't forget karts!!
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
Zynerji
112
For all the wrong reasons, I want air-cooled, removable jug, supercharged, 2 stroke I5's that run on nitromethane, and are disposable after every session. Oh, and 7 gears.
FW17
189
E-rev engine on what ever config and fuel.
A 1000hp generator with 4 motors 350hp for each corner and a 0.5kwh battery.
De Wet
mzso wrote:
17 Apr 2026, 19:46
De Wet wrote:
17 Apr 2026, 16:33
mzso wrote:
17 Apr 2026, 16:04
That's better... 50cc will not work to well in F1. 8)
671
FW17 wrote:
18 Apr 2026, 06:47
in the modern version of the free-piston ICE (no vibration, no crankshaft, no con-rods, no cams etc) .,...
the 2 pistons are each also the moving part of a linear (electrical) generator ....
which can also have ICE-controlling effects eg ... starting ...'revs' ... 'gears' ... etc
and maybe throw in an exhaust turbine etc ....
what's not to like ?
mzso
mzso
75
WardenOfTheNorth wrote:
18 Apr 2026, 01:03
mzso wrote:
17 Apr 2026, 19:46
De Wet wrote:
17 Apr 2026, 16:33
That last comment was about F1 only.
