Red Bull RB22
Lasssept
123
Re: Red Bull RB22
Ozan
Ozan
Re: Red Bull RB22
this is the best iteration of macarena wings in my opinion, just look at that opening size :wtf:
Re: Red Bull RB22
Ozan wrote:
30 Apr 2026, 23:05
Please do explain why this particular design is better than other's...
Luscion
Luscion
136
Re: Red Bull RB22
Paa
Re: Red Bull RB22
Ozan wrote:
30 Apr 2026, 23:05
Does the opening size matter?
It is an honest question. As a layman I would think only the cross section of the wing (opened and closed) and the profile matter. Is the gap between the top and bottom matters much as long as the profile shape and cross section area is the same?
Badger
Badger
46
Re: Red Bull RB22
Paa wrote:
01 May 2026, 01:45
Ozan wrote:
30 Apr 2026, 23:05
No, I don’t think it does. The theoretical benefit of the RB design should come from speed of operation, weight, and overall simplicity. The drag reduction effects would be similar IMO.
matteosc
matteosc
32
Re: Red Bull RB22
Badger wrote:
01 May 2026, 09:27
Paa wrote:
01 May 2026, 01:45
Ozan wrote:
30 Apr 2026, 23:05
I think that:
1) The central actuator will generate more drag than embedding the actuator in the side
2) The exposed tips of the wing when open will generate vortices (not sure if this is a wanted or a necessity)
3) When closed, the wing will have "standard" efficiency, but Ferrari's version will be more efficient
Edit: Just pointing out the minus here. RedBull solution seems lighter, simpler and easier to tune/iterate upon.
Badger
Badger
46
Re: Red Bull RB22
New floor edge?
amr
amr
Re: Red Bull RB22
I think there are just different philosophy to it.
RB aims for bigger gap as with a bigger gap one wing element will have less influence on the other one and therefore both will be closer to their theoretical efficiency thus reducing drag as a Rear Wing element.
Ferrari aims for altering the overall flow at the end of the car sacrificing individual wing efficiency maybe. Their macarena is a system solution working in conjunction with the blown exhaust winglets.
But who the hell knows without running cfd and compare.
Valeo
Valeo
Re: Red Bull RB22
Badger
Badger
46
Re: Red Bull RB22
Uncertain on the floor, it looks quite similar except for a minor difference on the rear corner. It was new for Japan.
Otherwise they've brought a crazy amount of changes. Sidepods completely different, rear wing, front wing, exhaust flap, mirrors, weight. Make or break.
Owen.C93
Owen.C93
191
Re: Red Bull RB22
Valeo wrote:
01 May 2026, 11:42
Looks like it gets quite sharp as the sidepod reaches the floor, forming a strake.
I would have thought that would violate the minimum radius rules, but maybe it’s relaxed lower down.
venkyhere
43
Re: Red Bull RB22
Valeo wrote:
01 May 2026, 11:42
This seems like a 'lets incorporate every flavour of sidepod style seen in recent past' design
waterslide - check
bathtub - check
no undercut - check
narrower than upper SIS width - check
Worryingly, it does look like an 'all-chips-on-red' gamble borne out of a 'lets play it by ear' attitude. How many times has the sidepod been revised from the first bahrain test ? 4 times ? 5 times ? Doesn't it seem like a Thomas-Alva-Edison style invention-purely-via-experimentation ?
Luscion
Luscion
136
Re: Red Bull RB22
Upgrades at Miami GP
Brahmal
Brahmal
75
Re: Red Bull RB22
Owen.C93 wrote:
01 May 2026, 13:14
Could you be more specific? I'm not seeing what you are referring to.
Paa wrote:
01 May 2026, 01:45
Any two aero surfaces running roughly parallel to each other will create a volume of high-pressure air flow between them, and that pressure will increase the closer the two surfaces are, which induces drag. However, there will be a point of diminishing returns beyond which increasing the gap will provide less drag benefit.
It's impossible for us to tell where that point is relative to the Red Bull and Ferrari wings, without access to CFD. However, one possible hint is in Ferrari's design. Their wing pivots around the middle of the flap, and because of how their actuator functions there is no obvious reason why that pivot point can't be higher up, which would increase the gap. So maybe the slot gap when opened is as big as it needs to be.
It's also possible that Red Bull's decision to mount their flap on swing arms (which increases the opened slot gap) is done purely because that is the geometry needed for the whole mechanism to function, rather than chasing a bigger slot gap.
