Ferrari SF-26
Luscion
Luscion
136
Re: Ferrari SF-26
Miami GP upgrades
michl420
michl420
Re: Ferrari SF-26
amr wrote:
01 May 2026, 08:34
Does anyone know if they are still using external mechanical cranking devices these days or are the engines started exclusively with the mgu-k?
I wonder what is the hole in the oval plate within the FIA lights ring used for? It seems to have move in the lower part.
Same for the rectangular opening that use to be at the very top of the cash structure and now is on top of the lights cluster?
It look like attempts of lowering the center of gravity. Lots of work in the background.
C5.15 Starting the engine
The car must be fired up with its on-board system (MGU-K) at any time.
Re: Ferrari SF-26
sucof wrote:
01 May 2026, 15:06
Horsepower is not what you need to start an engine, more like high torque. And slow high torque rotation has different requirements, so something that was engineered and optimised for high rpm high horse power, might not be optimal to repeatedly start an engine from stop.
One might argue that you need high torque because the speed is low - you need the torque to give a reasonable power level at the low speeds being used.
Brahmal
Brahmal
74
Re: Ferrari SF-26
Re: Ferrari SF-26
I've been thinking about the purpose of the "sticky-uppy bit" in the center of Ferrari's macarena wing. I think its purpose is to pretension the flap. It makes some drag which when applied in this position relative to the rotation point is creating a "restoring torque" that keeps the wing under a rotational tension when it's upside down. Either that or it's some kind of counterweight or mass damper to do the same thing.
#ReleasetheADUO
bananapeel23
34
Re: Ferrari SF-26
The new monkey grill is so beautiful. Everyone is trying their best to copy it, but none of them look anything like it. This thing has to provide a MASSIVE advantage if other teams are trying their best to make poor copies without the advantage of diff placement.
sucof
37
Re: Ferrari SF-26
Emag
Emag
137
Re: Ferrari SF-26
Hmmm in the telemetry, for Antonelli it just looks like he deploys less at the beginning and more later in the lap. So I wouldn’t call it an issue, just a different deployment strat, but let’s see later today in quali.
As for Ferrari, there was definitely something off with the deployment in SQ3. Its almost as if the software gets “confused” if you go faster in the corners. It deploys more there and there’s less left for the straights.
Developer of F1InsightsHub
sucof
37
Re: Ferrari SF-26
Emag wrote:
02 May 2026, 15:24
Indeed that was what Leclerc complained about in past races as well.
Sad they are this bad with the software... Huge potential thrown away.
bananapeel23
34
Re: Ferrari SF-26
I’m surprised that they still haven’t brought a diveplane. Almost everyone else uses one now.
F1ern
F1ern
16
Re: Ferrari SF-26
Ferrari closed down the venting louvers on the enginecover.
Fer.Fan
Fer.Fan
Re: Ferrari SF-26
02 May 2026, 05:28
https://i.postimg.cc/zGjTzLXF/Red-Bull-RB22.gif
Just look at RedBull macarena wing, it opens much higher compared to Ferrari.
Redbull the wing opens up much higher, main plane.
To me it looks much better solution, far better then Ferraris, redbulls wing generates less drag och higher topspeed.
matteosc
matteosc
32
Re: Ferrari SF-26
Fer.Fan wrote:
03 May 2026, 12:40
02 May 2026, 05:28
Being higher does not generate less drag. Exposed tips, instead, usually generate more drag.
From a very simplistic analysis there is no reason to think that the RedBull solution has less drag than Ferrari. If anything it would be reasonable to think the opposite.
By the way, it seems that RedBull has been working on this for a while, before Ferrari showed its solution. So may not be inspired by Ferrari's wing at all.
Brahmal
Brahmal
74
Re: Ferrari SF-26
Brahmal
Brahmal
74
Re: Ferrari SF-26
02 May 2026, 05:28
That may be the case, but Ferrari clearly consider it to be an aerodynamic element as well. It even has it's own tiny little gurney flap!
