Red Bull RB22
Re: Red Bull RB22
07 May 2026, 02:26
02 May 2026, 16:34
You could also think of the leading edge of the flap like points on a clock. It's position relative to the rotation axis defines whether it also moves up or down when it starts to rotate. In Red Bull's case there would be no downward translation of the flap to cause a collision with the mainplane. In Ferrari's case it doesn't matter because they rotate it the opposite way, but you can see if Ferrari rotate there's the same direction as Red Bull, then Ferrari's flap would just smash into the mainplane. The circle plot shows this. The flap leading edge on the Ferrari must move downward before it moves upwards in order to rotate counterclockwise like Red Bull.
https://i.postimg.cc/vmjRFPJL/image.png
Your drawing is a bit exaggerated. Both have pivots a few inches rear of the leading edge. The Redbull flap is a bigger barn-door style flap though.
The pivot point on the Ferrari wing is inside the 3rd wing element.
#ReleasetheADUO
Silent Storm
Silent Storm
132
Re: Red Bull RB22
https://www.linkedin.com/posts/dominik- ... paign=copy
CFD sim of RB wing by Dominik Balasko. Tap the link to watch his simulation...
Red Bull's Macarena Wing — Compromise or Genuine Gain? 🏎️ Red Bull debuted their Macarena-style flipping rear wing in Miami — and the architecture tells a different story to Ferrari's. What they share: Both deploy trailing-edge-first. The goal: exploit the deployed position aerodynamically, not just reduce drag. Where Ferrari extracts more: Ferrari's endplate actuation places the flap rearward into the diffuser upwash at full deployment. The flap curves that upwash into a forward-inclined lift vector — an active aero gain, not just camber-change drag relief. Red Bull's centred actuation keeps the flap forward of that corridor. The gain is drag reduction, not lift generation. Where Red Bull has the advantage: Ferrari acts from one endplate only. That's a massive torsional load across the full flap span — asymmetric, structurally demanding, and a real weight penalty. Red Bull's central mount is symmetric, lighter, and allows significantly faster opening and closing. The aero behavior on closing reflects that too. Ferrari's flap only re-enters the slot gap suction region late in the closing stroke — delayed reattachment, wide hysteresis loop, slow downforce recovery. Red Bull's closing sequence tells a different story: • Slot gap suction re-established from the start of the stroke • Partial attachment present early → lift builds linearly through the return • Smooth, predictable downforce recovery with no step-change in loading In practice: more consistent aero loading on corner entry, directly influencing trail-braking margin and rear stability under rotation. My take? Red Bull probably won't match Ferrari's peak straight-line delta. But a lighter, faster actuation system combined with linear lift build-up through the closing stroke means more consistent performance lap-to-lap — and in a race environment, that's often the more valuable commodity. Not a compromise. A deliberate trade-off — peak gain for aerodynamic consistency. Full simulation breakdown below — DRS hysteresis study in STAR-CCM+, flow visualization included. Credit for the geometry goes to Emil Qvist
venkyhere
43
Re: Red Bull RB22
Silent Storm wrote:
07 May 2026, 08:37
bold text : Would it be possible to explain with a simple diagram (hand-drawn would suffice) ? My understanding was that the purpose of the downwash generated from the upside-down flap is to bend-down the upwards rising diffuser exit a little bit, so that the overall floor downforce vector's 'angle' is less inclined towards rear, thus reducing drag. Kindly help me understand the creation of a separate lift-vector (with the airflow in the reverse direction for the flap's aerofoil shape) that you mentioned.
Silent Storm
Silent Storm
132
Re: Red Bull RB22
Someone uploaded a comparison video on X
SiLo
144
Re: Red Bull RB22
Silent Storm wrote:
07 May 2026, 21:33
Think I need to see a wider view from the CFD traces.
Felipe Baby!
carisi2k
29
Re: Red Bull RB22
Does anybody have any info about the steering upgrade to fix the issues Red Bull were having with the RB22 in the first 3 races? Is it possible that only Max had this upgrade and not Isack.
Silent Storm
Silent Storm
132
Re: Red Bull RB22
carisi2k wrote:
08 May 2026, 03:45
Not an upgrade but a fix, more like a driver preference fix.
Re: Red Bull RB22
04 May 2026, 19:46
04 May 2026, 17:49
michl420 wrote:
04 May 2026, 12:30
Mayb in the new rules this min radius rules are only for convex and not for concav? Kind of a loophole?
I believe that above the floor surface especially in rear corner, there is a volume where there is a relaxation or essentially no radius restriction to allow the presence of slots and small flicks and complexity in the rear corner of the floor for teams to regain downforce. I believe where the sidepod outer face slopes down it overlaps with this volume and they are therefore able to use the relaxed radii rules here to blend the outer face of the water slide into the sharp fence
We have confirmation of this novel approach to waterslides
https://i.ibb.co/cXgbbNvH/20260504-184044.jpg
https://i.ibb.co/wFMRpfpH/20260504-184049.jpg
Very extreme. It ties in with the gaping hole in the diffuser side wall. It always amazes me how RedBull really focuses on linking aerodynamic structures in the most extreme ways.
Re: Red Bull RB22
07 May 2026, 03:56
07 May 2026, 02:26
02 May 2026, 16:34
https://i.postimg.cc/SKGZPMws/image.png
That is clear from the start. It is also in a similar position to the redBull's... a few inches from the leading edge as I said. The context is the rotating flaps so the leading edge of those.
Re: Red Bull RB22
08 May 2026, 14:34
07 May 2026, 03:56
07 May 2026, 02:26
The rotation point of the Ferrari wing is in the 3rd element. The rotation point of the Red Bull wing is above the 2nd element. Is that more clear?
#ReleasetheADUO
Re: Red Bull RB22
A bit of paddock chatter about Red Bull's new sidepod concept
#ReleasetheADUO
Re: Red Bull RB22
Something that I noticed was the reduced size of the cooling outlets in Miami compared to Bahrain.
#ReleasetheADUO
Re: Red Bull RB22
08 May 2026, 16:20
08 May 2026, 14:34
07 May 2026, 03:56
That doesn't matter. The geometry from leading edge to pivot is what matters.
Can you visualize that? If not? Make abounding box and then place the pivot. The tip of the bounding box should not clash with the main wing element. You could have as many flaps as you want.
Cassius
Cassius
Re: Red Bull RB22
08 May 2026, 19:31
https://cdn-4.motorsport.com/images/amp ... etail.webp
Yes, it is I feel one of the 'issues' they have been able to solve:
- Starts & other engine gremlins (not fully solved yet, although progress made, maybe counted as solved?)
- (cooling) efficiency (solved - less louvres / smaller rear exit,new macarena rear wing, intake/sidepod)
- balance in yaw (probably due to insufficient out-wash to ingress of rear wheel wake into diffuser) (solved via new sidepod, but also front wing?)
- weight (not yet solved)
- low speed mechanical grip (partly solved, maybe new suspension will follow if that is the rumour)
We can add the solved steering issue to this list as well.
Darth-Piekus
-1
Re: Red Bull RB22
08 May 2026, 19:31
Is there an analysis behind those innovative sidepods and the difference than the rest? Also are there comparison pictures with the previous ones?
