Red Bull RB22
venkyhere
43
Re: Red Bull RB22
Darth-Piekus wrote:
09 May 2026, 10:19
08 May 2026, 19:31
Something that I noticed was the reduced size of the cooling outlets in Miami compared to Bahrain.
https://cdn-4.motorsport.com/images/amp ... etail.webp
Is there an analysis behind those innovative sidepods and the difference than the rest? Also are there comparison pictures with the previous ones?
viewtopic.php?p=1341371#p1341371
venkyhere
43
Re: Red Bull RB22
08 May 2026, 19:31
do you have pics of the main exit at the rear, how different was it in Miami w.r.t Bahrain (hot v hot) ?
Re: Red Bull RB22
venkyhere wrote:
09 May 2026, 15:45
08 May 2026, 19:31
In Bahrain there were louvers in the side next to the driver. In Miami I noticed that it was a bit less than what Ferrari used.
Beware of T-Rex
venkyhere
43
Re: Red Bull RB22
10 May 2026, 03:00
venkyhere wrote:
09 May 2026, 15:45
08 May 2026, 19:31
https://i.postimg.cc/7YbmPtGK/image.png
This is really encouraging. The 'benchmark' in this regard is McLaren. If track-to-track, the RB22 has 'cooling exit area' comparable to McL40, that will be the 'tell' that Redbull have solved their cooling issues.
carisi2k
29
Re: Red Bull RB22
Cassius wrote:
09 May 2026, 09:48
08 May 2026, 19:31
Yes, it is I feel one of the 'issues' they have been able to solve:
- Starts & other engine gremlins (not fully solved yet, although progress made, maybe counted as solved?)
- (cooling) efficiency (solved - less louvres / smaller rear exit,new macarena rear wing, intake/sidepod)
- balance in yaw (probably due to insufficient out-wash to ingress of rear wheel wake into diffuser) (solved via new sidepod, but also front wing?)
- weight (not yet solved)
- low speed mechanical grip (partly solved, maybe new suspension will follow if that is the rumour)
We can add the solved steering issue to this list as well.
I was also wondering if any weight came off with these updates but apparently not. If they can get that 30kg out of the car then the others won't know which way to look.
mzso
mzso
76
Re: Red Bull RB22
carisi2k wrote:
10 May 2026, 23:53
Cassius wrote:
09 May 2026, 09:48
08 May 2026, 19:31
How could anyone possibly know the weight without another sneak video?
carisi2k
29
Re: Red Bull RB22
I believe that Wache said they are still to find any weight loss gains.
venkyhere
43
Re: Red Bull RB22
carisi2k wrote:
11 May 2026, 08:37
Really ? if the peformance upswing in Miami was without saving weight from Japan, then I think RB22 would become the fastest car purely by weight saving (when others are near the weight limit) with a big margin. That sounds too unrealistic. Which means there indeed was weight saving in Miami.
Cassius
Cassius
Re: Red Bull RB22
venkyhere wrote:
11 May 2026, 10:01
carisi2k wrote:
11 May 2026, 08:37
They were able to reduce from ~12kg to 6-7kg overweight with the Japan and Miami upgrades. How much in Miami is not clear, but with all these new parts it is almost certain they were able to reduce it further with the Miami upgrade.
Wache said they will bring the final weight reduction update to Austria.
FW17
184
Re: Red Bull RB22
Cassius wrote:
11 May 2026, 10:09
venkyhere wrote:
11 May 2026, 10:01
carisi2k wrote:
11 May 2026, 08:37
Can there be weight reduction in the PU? or it completely homologated and cannot be changed?
mzso
mzso
76
Re: Red Bull RB22
venkyhere wrote:
11 May 2026, 10:01
carisi2k wrote:
11 May 2026, 08:37
I think the flip-wing came with a weight penalty...
Re: Red Bull RB22
Is there a clear reason why the bib concept with the isolated forward section that was adopted in miami (a similar design to the launch spec SF-26) is advantageous under these rules?
Does it exploit a loophole or is it more a choice around flow conditioning ahead of forward floor/fences
carisi2k
29
Re: Red Bull RB22
Cassius wrote:
11 May 2026, 10:09
venkyhere wrote:
11 May 2026, 10:01
carisi2k wrote:
11 May 2026, 08:37
Do you have a link to where that information is given?
Stu
Re: Red Bull RB22
12 May 2026, 20:00
https://pbs.twimg.com/media/HHYpApmasAA ... &name=orig
I would say that primarily it is a conditioning device for when yaw is present (in that location steering lock can cause local yaw conditions even when the car is, fundamentally, in a yaw neutral state.
Re: Red Bull RB22
motorsport-italy
Beware of T-Rex
