Audi R26
Brahmal
Brahmal
75
Re: Audi R26
12 Mar 2026, 21:27
Brahmal wrote:
12 Mar 2026, 21:20
12 Mar 2026, 20:44
Motorsport Italy says Audi is the only team running 8 piston brake caliper (4 piston per side).
https://it.motorsport.com/f1/news/f1-au ... /10804434/
The article also says "four pads." So two pads per front brake?
Four pads would mean two on each side of the brake caliper. To be clear, the 8 pistons are also distributed 4 per side of the caliper. So the front brake calipers (left and right) would have a total of 16 pistons, and 8 pads. Sounds a bit mad :lol:
Oh wow, I assumed that "4 per side" was referring to the left and right side of the vehicle, not the left and right side of the brake disc! For context, what is the typical arrangement for one front wheel? Six pistons and two pads?
Re: Audi R26
is it just me or does the Audi chassis has this alien (to F1) look in the way it's constructed?
De Wet
Re: Audi R26
Brahmal wrote:
12 Mar 2026, 21:54
12 Mar 2026, 21:27
Brahmal wrote:
12 Mar 2026, 21:20
Total overkill with all the Li-Co & electrical management. :D
Re: Audi R26
I think having more pistons allows them to exploit the brake pad contact area more efficiently. The brake pad is not infinitely stiff. That means the force from the piston is concentrated inside the contact area with the pad. The "fringes" of the pad don't clamp the brake disc with as much force. Its wasted area.
More pistons (which are smaller) also might allow them to concentrate the force on the disc at the outer most edge of the brake disc. Due to the greater moment arm at this point, it's more efficient to bite the brake disc near the outer edge. The limit of brake disc diameter is that it needs to fit inside the wheel so you're fighting against that when you design the caliper.
#REPEALtheADUO
JPower
JPower
43
Re: Audi R26
22 Mar 2026, 15:23
Reminds me of the 2006-13 Corvette Z06. On the iron brake package, I think it had 6 pads for each caliper.
Brahmal
Brahmal
75
Re: Audi R26
Re: Audi R26
Another good one from there. flow viz. Very clean streamlines.
#REPEALtheADUO
Re: Audi R26
Another view of Audi's hollow wheels
https://x.com/n_mode_log/status/2036460 ... 05/photo/2
#REPEALtheADUO
Re: Audi R26
#REPEALtheADUO
Brahmal
Brahmal
75
Re: Audi R26
Brahmal
Brahmal
75
Re: Audi R26
That's a nice solution. Let's see if they dispense with the lay-flat wing like Alpine did. It appears to still be on the car.
Re: Audi R26
It seems like Audi would have a very easy time adopting the Red Bull sidepod solution as they are the closest to it in practice. They have the gulley but lack the hard shoulder which is seen as a loophole.
#REPEALtheADUO
Re: Audi R26
No active aero components this weekend.
#REPEALtheADUO
F1maniac^2
F1maniac^2
Re: Audi R26
23 May 2026, 06:59
Well Rbr clearly copied Audi on the bodwork tail. Surely Audi is better of with what they have
porridge
Re: Audi R26
