Jérôme d'Ambrosio will replace Vasseur.
Guessing this will be the algorithm deciding how much recharged is needed. These regulations need a serious rethink.
This is the case when you have to try, your home gp when if you start first you essentially win.edu2703 wrote: ↑06 Jun 2026, 17:38Another case of overdriving and hitting the wall for Leclerc. How long will it take for him to accept the car's limitations?
He better get it into his head that this car doesn't allow for more than a second-row start or P2 in the best-case scenario. Continue this overdriving and he'll get a beating from a 41-year-old "washed" driver this season.
Overdriving is a big risk that doesn't compensate for the results in most cases. It's a fine line between being called the new Senna or the new Maldonado, depending on what it leads to.
