2026 BWT Alpine Formula One Team
WardenOfTheNorth
Re: 2026 BWT Alpine Formula One Team
The black and gold with a red and green stripe on the cover could make for an awesome livery!!
Apparently Alpine have already said they'll keep some of the Alpine blue on the car though....I think that's a mistake!!
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
FW17
184
WardenOfTheNorth wrote:
30 May 2026, 00:21
Jambier wrote:
29 May 2026, 19:25
Finally! They will get rid of the ugly pink
I wonder if another team will pick up BWT?
Yeah
Williams will pick it up and we will have a 1992 livery again
Jambier
30 May 2026, 00:22
Indeed, I am curious of the livery.
How to match both Gucci and Alpine colors is not easy
WardenOfTheNorth
No. I was having a play on AI trying to come up with some ideas. With the blue they all looked rubbish!!
Foryster
Foryster
What was that today? 3x speeding in the pits - and lots of other drivers speeding as well.
It's super suspicious what happened. Any ideas? or just a simple team error?
FNTC
FNTC
They were saying on Sky that if you have the limiter on 60kph but cut the corners on pit entry, you drive a slightly shorter route, making the speed above 60. It's not actually a speed measurement, but distance by time.
Foryster
Foryster
its being said that Gasly knew it - FIA warned them. So its his fault in the end. Pity.
ChrisM40
ChrisM40
If your measurement points are on a curve the minimum possible distance should be the trigger. Regardless of the regulation its extremely dumb to do otherwise.
