Ferrari SF-26
gordonthegun
254
Re: Ferrari SF-26
The new floor. Only the bargeboards are visible:
atanatizante
133
Re: Ferrari SF-26
"Ferrari's Barcelona package introduces the full configuration of the winter-optimized front wing with extensive modifications for moving flap flows, alongside the year's third floor specification featuring multi-area revisions.
It includes Tondi's team's FTM refinements and minor bodywork tweaks mirroring Mercedes' silhouette.
Additionally, Leclerc will run a critical brake test to solve recent issues." 📰 @Auto_Racer_it
The Italian media are also reporting a new and more refined update for the Macarena wing, as well as a new mechanism for the front active wing, as can be seen in these two photos:
Jesus
gordonthegun
254
Re: Ferrari SF-26
f1316
88
Re: Ferrari SF-26
sucof wrote:
11 Jun 2026, 18:38
f1316 wrote:
11 Jun 2026, 01:16
SiLo wrote:
11 Jun 2026, 00:13
It’s underpowered not draggy
That is also my understanding (and, even if the contention is that the FTM takes away some power, that’s not the same as drag).
But that’s what he’s said several times and I tend to think he’s reasonably reliable, so just curious.
Norris explicitly said, Ferrari choose a more draggy solution (overall) for their cars, for more downforce.
This was surprising, as Norris and Mclaren has the least reason to be political about this or to lie, at this point.
I tend to give this high trust scores :)
I just wonder in which area did they do this, as it is not obvious. Do they simply run bigger wings? What are your opinions?
I don’t know about the cause but Straight line mode and Macarena updates (mentioned above) could be part of the solution.
I still wonder if what Norris (who, as a driver, may not always use the right technical language) means is that Ferrari chose to do things like FTM that reduce power - and therefore limit straight line speed - and he’s referring to that as “draggy” when it’s really a different thing but with basically the same effect (in theory).
Fwiw: for ages I kept thinking that the RB Macarena was more efficient because the slot gap was bigger - I don’t know why but it took me ages to realise that the gap between the two elements is not really what’s important, it’s the profile (irrespective of how close together they are). Everyone else probably already knew that but I was having F1 commentator derangement syndrome :lol:
Re: Ferrari SF-26
sucof wrote:
11 Jun 2026, 18:38
f1316 wrote:
11 Jun 2026, 01:16
SiLo wrote:
11 Jun 2026, 00:13
Would that be the McLaren that uses the Mercedes powertrain. No reason to cast shade elsewhere, eh?
Luscion
Luscion
142
Re: Ferrari SF-26
Barcelona upgrades
Fakepivot
Fakepivot
Re: Ferrari SF-26
why did they increase the side pod size?
Owen.C93
Owen.C93
191
Re: Ferrari SF-26
Fakepivot wrote:
12 Jun 2026, 14:34
https://pbs.twimg.com/media/HKnK90iXsAE ... ?name=orig
Probably developed in conjunction with the floor update and it manipulates the front wheel wake together with the floor board to rebalance the front floor pressurisation.
Luscion
Luscion
142
Re: Ferrari SF-26
venkyhere
43
Re: Ferrari SF-26
Fakepivot wrote:
12 Jun 2026, 14:34
From a non-aerodynamicist's perspective :
'mimicking Mercedes' sidepod shape to a large extent'
sucof
38
Re: Ferrari SF-26
venkyhere wrote:
12 Jun 2026, 15:30
Fakepivot wrote:
12 Jun 2026, 14:34
Look it at again... its the opposite.
The prev design was more like what Merc had, and it was not a copy since both car debuted with it in 2026.
I think you might be misled by the painting of the Merc sidepod.
This new Ferrari pod is a lot less similar to Merc, a bit like something form the past.
In the official explanation it says something like managing wheel wake better. Makes sense.
LM10
LM10
127
Re: Ferrari SF-26
Isn’t the undercut bigger now which likely was the primary goal of the sidepod redesign?
Sempre Forza Ferrari
Re: Ferrari SF-26
