I know, The rads for the intercooler are usually in the sidepods. Thus my point still stands, if they can run hotter they don't need as much cooling, and that has aerodynamic benefits.
As I quoted earlier, Charles chose to run those specific brakes. Unless he lied to the press, he is predominately to blame.catent wrote: ↑18 Jun 2026, 15:37I would ask you to do the following thought experiment: If Hamilton lazily slid into the wall under the same circumstances, and he indicated the rear brakes did not work as they should have, would you also deem such an incident ‘driver error’?
I suppose only you truly know the answer to that question, but I think it’s rather clear the answer to my hypothetical would be ‘no’, had the driver involved been named ‘Hamilton’.
It all depends on what context the Hp numbers were given. For example maybe the intercooler by itself is only with 5HP, but when the new fuel is included it's worth 10 to 15HP etc.
Even if that is the case. It's the team's responsibility to give a driver a functioning car. Not that I see how breaking the front wing would cause a failure like this. We must have seen a hundred crashes that are like this or worse in a year, without anyone having a hydraulics failure.Just_a_fan wrote: ↑16 Jun 2026, 23:46Single point of failure system - if the steering system leaks then the hydraulic system leaks. It's one system for steering, gears, etc., and the rear portion of the braking system controlled by the car (hydraulically).
I don't see any thing about that in the rules. The only thing i see in the rules is that the FIA must approve/Homogenate it.
We are describing the same phenomena with different ontologies. I appreciate the integration. However, my answer includes personal conjecture on additional combustion benefits beyond simple aerodynamic benefits to the car. In this sense, they may be partially solving the ICE power deficit while also reducing drag on the car, which is the most intelligent and practical avenue to take in the context of the car's current relative performance.
So the team are deliberately breaking Charles's car are they? Because that's the alternative.mzso wrote: ↑18 Jun 2026, 22:40Even if that is the case. It's the team's responsibility to give a driver a functioning car. Not that I see how breaking the front wing would cause a failure like this. We must have seen a hundred crashes that are like this or worse in a year, without anyone having a hydraulics failure.Just_a_fan wrote: ↑16 Jun 2026, 23:46Single point of failure system - if the steering system leaks then the hydraulic system leaks. It's one system for steering, gears, etc., and the rear portion of the braking system controlled by the car (hydraulically).
You would actually find I am very consistent on these sorts of incidents. Yes of course I would blame Lewis for not checking that his brakes are working before taking a last minute turn in, wishing that they would somehow warm up at that very moment.catent wrote: ↑18 Jun 2026, 15:37Neither of us know exactly what happened. Only the team does.PlatinumZealot wrote: ↑18 Jun 2026, 12:06Technically it was driver error induced though. Brakes warm-up is down to the driver isn't it?
They wouldn't use that term "running" hot for intake air. The engine running hot has always been for jacket water temperatures.leblanc wrote: ↑18 Jun 2026, 17:24we are speaking of IATs and the intercoolerdans79 wrote: ↑16 Jun 2026, 17:34Look at the car.leblanc wrote: ↑16 Jun 2026, 16:35There are only a very few reasons why you would want hotter IATs. The only two I can think of that benefit the current engine formula are better lean burning and better control of combustion phasing. This could be thought of a relatively stop-gap fix to the smaller turbo design constraints.
Cooling package from Friday.
what they ran in qualifying and the race.
If you can run hot and not loose a lot of power from the ICE, you can potentially gain back more performance aerodynamically.
