I’ll leave the posts stay, as they include some arguments, but pretending to own the truth does not a forum make.
Please remain respectful as well.
Playing pigeon chess will not (is not) acceptable.
Ghost, just above, nailed it.
Orihara:
"One of the challenges is preventing the rear wheels from locking up when the driver downshifts while braking. This requires control from the transmission, and the power unit must correctly deliver the necessary torque so that the engine speed matches the downshift and prevents the wheels from locking up."
"The difficulty lies in the fact that the 2026 model’s power unit will use a method of energy generation called partial regeneration more frequently than before.
"When entering a turn, even with the throttle off, the engine generates nearly maximum power (due to braking from the MGU-K). If the engine torque fluctuates even slightly, the driver will notice the rear end drifting inward during the turn. In Monaco, you have no choice but to drive with a safety margin, so the key is how to stabilize the car and enter the turn with the same engine torque—and that’s what we’re trying to achieve."
"This partial regeneration also occurs during acceleration. The internal combustion engine must generate stable torque to counteract the braking force of the MGU-K; otherwise, the driver cannot safely press the accelerator. The main cause of this lies in the internal combustion engine’s lack of power and its still-immature combustion settings."
"Unstable torque means unstable combustion. The problem was that combustion in our internal combustion engine was unstable, which resulted in inconsistent torque every time. Up until the Miami Grand Prix, we were still looking for a way to fix it, but after the Miami Grand Prix, we found a solution that would improve things, and we’ve been gradually fine-tuning in that direction, so the number of issues we need to resolve has decreased. It has decreased, but we haven’t been able to eliminate them completely yet, and the big difference is that, while staying within this range is acceptable at other circuits, Monaco requires a much higher standard (which has made the problems more evident)."
That verifies a thing or two. Particularly that they're not jet ready with the new spec ICE, he said "around the summer" according to the translation. So I guess barring further delays it will be August.hkbruin wrote: ↑20 Jun 2026, 14:40Here is a recent article/interview of HRC President Koji Watanabe on 06.14.2026 from Japan’s Autosport Web:
https://www.as-web.jp/f1/1325833
This part - regenerating during acceleration - doesn't make sense.PlatinumZealot wrote: ↑21 Jun 2026, 17:48"This partial regeneration also occurs during acceleration. The internal combustion engine must generate stable torque to counteract the braking force of the MGU-K; otherwise, the driver cannot safely press the accelerator. The main cause of this lies in the internal combustion engine’s lack of power and its still-immature combustion settings."
Yes it does.mzso wrote: ↑21 Jun 2026, 20:50This part - regenerating during acceleration - doesn't make sense.PlatinumZealot wrote: ↑21 Jun 2026, 17:48"This partial regeneration also occurs during acceleration. The internal combustion engine must generate stable torque to counteract the braking force of the MGU-K; otherwise, the driver cannot safely press the accelerator. The main cause of this lies in the internal combustion engine’s lack of power and its still-immature combustion settings."
I did theorize this pre season. Charging the MGU-K during the very early phases of acceleration could act as a form of traction control. It allows the drivers to get on throttle early and the excess torque gets canceled out by the negative torque from the MGUK as it charges. Once the driver goes 100% throttle the MGUK would switch to deployment. It would help with corner rotation, traction management and harvesting all at once.mzso wrote: ↑21 Jun 2026, 20:50This part - regenerating during acceleration - doesn't make sense.PlatinumZealot wrote: ↑21 Jun 2026, 17:48"This partial regeneration also occurs during acceleration. The internal combustion engine must generate stable torque to counteract the braking force of the MGU-K; otherwise, the driver cannot safely press the accelerator. The main cause of this lies in the internal combustion engine’s lack of power and its still-immature combustion settings."
Maybe they're the only one doing this because they're grubbing for every bit of energy, because they otherwise don't have enough because of lack of ICE power.Farnborough wrote: ↑21 Jun 2026, 21:04If the driver request with throttle is LESS than peak ICE output, then the torque demand can be delivered (as requested by driver) to rear wheels by the ecu control opening throttling further than needed, then torque "held" at the demand by ramping up regeneration with MGUK "request" the two (front and rear of crankshaft demand) blended to give invisible torque delivery "flow" ..... if they get the software right ..... in driving the rear axle.
notionally any time the ICE max torque is enough to spin the wheels generating is usefulgearboxtrouble wrote: ↑21 Jun 2026, 21:08I did theorize this pre season. Charging the MGU-K during the very early phases of acceleration could act as a form of traction control. It allows the drivers to get on throttle early and the excess torque gets canceled out by the negative torque from the MGUK as it charges. Once the driver goes 100% throttle the MGUK would switch to deployment. It would help with corner rotation, traction management and harvesting all at once.
Partial load recovery is definitely preferable to superclipping. The latter actually slows the cars down while it's happening, the time gain in other parts of the track just outweigh the losses. The only downside of partial throttle recovery is increased fuel consumption (and apparently driveability at least for Honda).mzso wrote: ↑21 Jun 2026, 21:36One would think in Monaco, particularly with the power limit there is certainly no need for part-throttle recovery.
Also it's my impression of other engine manufacturers, that they mostly rely on (super)clipping, rather than part-throttle harvesting for the best overall performance.
The PU output must match the driver demand, so what you are proposing is not allowed, at least as a form of traction control.gearboxtrouble wrote: ↑21 Jun 2026, 21:08I did theorize this pre season. Charging the MGU-K during the very early phases of acceleration could act as a form of traction control. It allows the drivers to get on throttle early and the excess torque gets canceled out by the negative torque from the MGUK as it charges. Once the driver goes 100% throttle the MGUK would switch to deployment. It would help with corner rotation, traction management and harvesting all at once.mzso wrote: ↑21 Jun 2026, 20:50This part - regenerating during acceleration - doesn't make sense.PlatinumZealot wrote: ↑21 Jun 2026, 17:48"This partial regeneration also occurs during acceleration. The internal combustion engine must generate stable torque to counteract the braking force of the MGU-K; otherwise, the driver cannot safely press the accelerator. The main cause of this lies in the internal combustion engine’s lack of power and its still-immature combustion settings."
the FIA implies that it will always follow the functionality implemented in the ECU programme
They're allowed to regenerate under acceleration when throttle demanded is below max ICE output or something like that. I remember reading about a very complicated algorithm in these pages in preseason. That was when they could only recharge to a max rate of 250KW.mzso wrote: ↑21 Jun 2026, 20:50This part - regenerating during acceleration - doesn't make sense.PlatinumZealot wrote: ↑21 Jun 2026, 17:48"This partial regeneration also occurs during acceleration. The internal combustion engine must generate stable torque to counteract the braking force of the MGU-K; otherwise, the driver cannot safely press the accelerator. The main cause of this lies in the internal combustion engine’s lack of power and its still-immature combustion settings."
For arguments sake let's say the ICE creates 50% of the power and the MGU-K, the other 50%. At 25% throttle the ICE is running at 100%, the MGU-K at -75% leaving 25% to drive the wheels. The PU matches the throttle.karana wrote: ↑22 Jun 2026, 00:04Partial load recovery is definitely preferable to superclipping. The latter actually slows the cars down while it's happening, the time gain in other parts of the track just outweigh the losses. The only downside of partial throttle recovery is increased fuel consumption (and apparently driveability at least for Honda).mzso wrote: ↑21 Jun 2026, 21:36One would think in Monaco, particularly with the power limit there is certainly no need for part-throttle recovery.
This is also not new, Honda was already doing this in 2016. If you click on "read sample" in the following link you can see towards the end the telemetry of a q and a race lap at Austria from 2016 where you can see the MGU-K power being negative under partial throttle: https://www.amazon.co.jp/%E3%83%A2%E3%8 ... 2Y6RV63H2C
