Red Bull RB22
FilipR
FilipR
Re: Red Bull RB22
They seem to have a small vortex generator AKA ''sticky upper bit'' between both rear wing pillars. I went back in the thread and saw them using it in Canada as well. I've never seen that on a car before, any clue on what it might do?
venkyhere
44
Re: Red Bull RB22
Perhaps this has surprised not many, but surely it has surprised me - the RB22 doesn't have too big cooling exits for
barcelona's heat. I can see only the cannon exits and the main engine cover exit, no 'extra slats'. Considering that they still use air-to-air IC for charge air, this is something I didn't expect.
venkyhere
44
Re: Red Bull RB22
Something that has piqued my curiosity, about how the water coolers are located in the 'waterslide sidepod' and how the airflow through them is conducted. I have collected some pics from the internet and tried to make sense of how the airflow passes. I am able to visualize how the air 'enters' but not how the air 'leaves', especially with a barrier/wall placed right behind (inorder to make space for the waterslide).
If anyone has an idea of how the exiting hot air leaves and is collected (possibly by the main rear exit), kindly help by marking the path in the pic :
Re: Red Bull RB22
I would suggest it flows out via the vent in front of the Red Bull logo and under the bodywork with Red Bull on it to the rear cannon exit. Likely some air will flow down below the waterslide until it can join the air flowing to the cannon exits.
Brahmal
Brahmal
81
Re: Red Bull RB22
venkyhere wrote:
16 Jun 2026, 18:27
That "barrier/wall" is a baffle that seals against the outer bodywork to provide a ducting path for the radiator exhaust. As long as it's sealed properly the hot air would be pulled through narrow spaces and make sharp turns efficiently as it flows underneath the bodywork of the waterslides into the engine cavity and out from there.
venkyhere
44
Re: Red Bull RB22
Brahmal wrote:
17 Jun 2026, 03:33
venkyhere wrote:
16 Jun 2026, 18:27
The radiator is lying at (say)30 degree angle to horizontal. The exit air has to be from the face that's opposite to the face through which the cooling air enters, doesn't it ? So IMHO the air has to enter from below (that's how it lines up with the sidepod air inlet, when I look) and leave at the top. Are you saying the baffles are going to make the air turn 180 degrees and then a further 90 degrees to make it's way 'under' the waterslide, and then bend further to enter the main engine room, to finally exit at the rear ? Seems very 'lossy' to me.
a) What if the baffle is just bending the air 90 degrees laterally, 'into' the main engine room, to further be piped another 90 degrees (or close to 90) within the engine cover so as to line up with the main rear exit ?
b) what if the baffle is there to force the air 'up' and get 90 degree bent by a pipe* to then come out of the side cannon exits near the Redbull sign on the side ? (as suggested by @Just_a_fan).
All conjectures involve back to back direction changes, and can seriously cripple the suction effect from wherever the air finally goes out. The fact that they have placed the wall/barrier/baffle right at the rear of the radiator suggests that the benefit to the car from the waterslide is far more than the 'loss' from a compromised cooling flow. But its a compromised cooling flow nevertheless. It's nowhere as 'neat' (from a cooling perspective) as the slat exits slashed on top of the sidepod, like so many teams on the grid have done.
*corollary question - I've been asking this in this thread for I don't know how long - what are the two side cannon exits for ? they have been present on all versions of the sidepod we have seen until now and seem to suggest some kind of heat exchanger placed just beneath the 'window sill' of the drivers cabin. Perhaps that heat exhanger has been removed in this new layout, and the cannon pipe is being to used extract the main water radiators exit air ?
Brahmal
Brahmal
81
Re: Red Bull RB22
venkyhere wrote:
17 Jun 2026, 08:48
The path of travel for the airflow is probably less constrained and angular than you make it out to be, but basically yes. Keep in mind that with the car at speed the air is being "pushed" into the sidepod inlets and radiator, and then "pulled" through the body by a siphon or partial-vacuum effect created by the airflow around the outsides of the central and side cannon exits. I believe that McLaren in the last regs had additional baffles in the body to keep the sidepod and central body airflows discrete, but it doesn't appear that Red Bull have gone that far.
Air can be "forced" through tight spaces pretty efficiently as long as the amount of pressure is great enough and the ducting sealed properly. If you have a robot vacuum or certain other very compact vacuum cleaners, you may see the volume of space that the flat filter exhausts into is comparatively tiny, often smaller in volume than the filter itself! The airflow would certainly be more efficient flowing through a duct of constant volume and direction, but extreme size-constraints can make the trade-off worth it.
I'll attempt to draw what I'm talking about on the pictures you provided later today, but don't have time at the moment. I'm sure there are Youtube videos about this subject as well.
SilviuAgo
154
Re: Red Bull RB22
Red Bull RB22. Barcelona-Catalunya GP 2026:
During FP1, the Milton Keynes team tested a new front wing.
The area next to the endplate, the flaps, and the main plane were modified.
It was not used in the race.
venkyhere
44
Re: Red Bull RB22
First available pic from Austria
https://x.com/AlbertFabrega/status/2070 ... 94/photo/1
sidepod doesn't seem to have changed
euv2
euv2
Re: Red Bull RB22
Some changes visible, are the new shape of the sidepod inlet, the lower lip seems to have been pushed back further, now the opening is much more angular, the shape of the inlet has been completely changed too, now resembling more the previous generation of cars, the return of overbite?
Also, the upper SIS now looks to be bulkier and angled forward slightly, the rear view arm also attaches on the protruding element of the SIS instead of the bodywork.
Re: Red Bull RB22
euv2 wrote:
25 Jun 2026, 17:03
https://postimg.cc/14Ng41dr
https://postimg.cc/pmDnj48w
The sp inlet is similar to Mercedes shark bite
euv2
euv2
Re: Red Bull RB22
25 Jun 2026, 17:11
euv2 wrote:
25 Jun 2026, 17:03
You're right, it's a narrower version of the W17, which itself is a tamer version the last regs.
venkyhere
44
Re: Red Bull RB22
Seems like the upper SIS is sitting flush with the lateral outer edge of the sidepod , a.k.a sidepod width seems increased. Also, it seems the 'dog's head' on the rear wing actuator is permanent now.
Re: Red Bull RB22
venkyhere wrote:
25 Jun 2026, 17:51
So probably more undercut as a result
venkyhere
44
Re: Red Bull RB22
25 Jun 2026, 17:53
venkyhere wrote:
25 Jun 2026, 17:51
I don't know how that would work, if the waterslide is retained.
Let's wait for more pics.
