2026 Scuderia Ferrari HP F1 Team
aMessageToCharlie
aMessageToCharlie
Re: 2026 Scuderia Ferrari HP F1 Team
Xyz22 wrote:
29 Jun 2026, 11:52
This is the first year in a long time that Ferrari has a driver problem. Leclerc is performing like Massa at the end of his career, absolutely awful. This makes Hamilton look decent but he is miles slower than Antonelli and Max.
Not looking good. This is going another very long and disappointing season.
LOL you need to calm down. He had like 4 bad results in a completely new formula, possibly driving with a new brake setup and just qualified P2 at the last GP.
Mercedes was always going to run away with it. The team is losing on politics, not due to the drivers IMO.
This is another unnecessary complication that needs rethinking. The SM rear wing is slow to rotate so they can’t rely on the brake pedal to re-engage and have to do it early & manually; and with that comes the inevitable mistake. Good catch by HAM
Luscion
Luscion
153
Ferrari bringing an updated macarena wing, low drag diffuser and revised ftm to Silverstone
https://autoracer.it/ferrari-spielberg- ... lori-aduo/
Xyz22
Xyz22
125
aMessageToCharlie wrote:
29 Jun 2026, 12:27
Xyz22 wrote:
29 Jun 2026, 11:52
4 bad results is a colossal amount. Hamilton was only slightly better this weekend, which doesn’t really bode well at all considering Leclerc actual level.
rifrafs2kees
rifrafs2kees
Xyz22 wrote:
29 Jun 2026, 12:47
29 Jun 2026, 12:27
Xyz22 wrote:
29 Jun 2026, 11:52
I hope the modes scrub this trash off the site. Zero value add. This driver x vs y is getting tiring,
You could've searched the web for possible causes of their collapse. E.g. Lando thought Ferrari was pushing too hard in the corners to achieve lap time due to deployment handicap.
For you none of the millions of hours of technical homework matters, however. It's all down to terrible drivers because they must deliver stellar results regardless of conditions. Thanks Einstein.
Jdn1327
Jdn1327
Luscion wrote:
29 Jun 2026, 12:35
Will deg in Silverstone be as bad as Spain?Ferrari can make a 3 stop work in Silverstone no?
Jdn1327 wrote:
29 Jun 2026, 15:23
Temperatures likely to be 26-28deg C for Saturday and Sunday with no rain currently forecast. Could be a stiff breeze from the West which is a tail wind in the high speed Abbey (T1) and Copse (T9) corners. Will that temperature be enough to cause high deg? Tyres will be C1, C2, C3 rather than Austria's C3, C4, C5 so we'll have to wait and see what happens.
Edit: have seen C2, C3, C4 for Silverstone which might make it more tricky if temperatures get a bit higher.
f1316
89
Just_a_fan wrote:
29 Jun 2026, 17:53
Jdn1327 wrote:
29 Jun 2026, 15:23
I think the issue is that Silverstone has fewer braking zones than Barcelona - even though both circuits have a lot of fast corners, they’re not as similar as we sometimes think. So deployment will probably be a particular problem.
Can the high speed corner performance + some kind of tyre deg advantage for that kind of corner cancel that out? Tough to say but I doubt it.
My hope is that perhaps they haven’t optimised the deployment software for the ADUO upgrade - so while Hamilton said the “grunt” out of a corner felt good, they ran out of deployment too soon - and maybe there’s more potential there? But that’s just wishful thinking, not necessarily based on anything.
