Brahmal wrote: ↑02 Jul 2026, 03:51
diffuser wrote: ↑02 Jul 2026, 03:21
In any case, the wheel hub is on the opposite side of the ICE. It's located almost directly behind the driver's head, only a couple of centimeters farther rearward.
I think he's referring to the part that the brakes and wheels are attached to. The ones in front are called steering knuckles, not sure what the rear ones are called as I've heard it referred to as the knuckle, spindle, or hub carrier.
yes thats correct. i was talking about the opposite end of that top wishbone that everyone was saying was a radical design during preseason. one end connects to the rear crash structure, the other connects by the wheel hub assembly. just thought that regardless of whether the inboard mount was at the crash structure or the gearbox casing, theyre both solid compaired with the rear wheel mounting side. if that makes sense.. regardless, the current mounting has been done before in prior newey cars, with no vibration issues that we know of. and sure, "vibrations are complicated". but people seeing that "radical" suspension arm, and deciding that its the cause of their vibration issues, is pretty amateur to begin with, with no evidence to speak of. i know its just speculation. speculate is all we can do without anybody from the team giving up information.
