Good question. Hungary is NOT a Sprint race weekend. So that decreases the need for a filming day but it doesn't mean there will not be.
I wonder if they will test anything new in Spa free practices?
It's a natural approach for the engine and chassis to race separately. First, we'll see the effect of the chassis update alone. Then, in the next race, we'll see the new engine and what it brings. Of course, it needs a bit of a math since they're not on the same track. A one-month gap means a slightly longer wait for most awaited one. But it will let HOnda more time to work on the engine, and if, let's say, the parts installed to reduce vibrations are removed or replaced with lighter ones, then perhaps that one-month period before the new engine is installed could be used for marriage optimization, in addition to the usual things. Of course, if there's a work ban, that's a different matter.Ashwinv16 wrote: ↑06 Jul 2026, 00:17https://x.com/HondaRacingF1/status/2073 ... 19541?s=20
Honda confirms new engine for Dutch GP so nothing for Spa and Hungary in terms of engine.
After all the fiasco seems reasonable to provide lower expectations, they know that 2.5 seconds is the bare minimum achievable.krich wrote: ↑06 Jul 2026, 11:54i think the upgrade is acording to their data much bigger (3-4 seconds?) and they are not sure if that will correlate to track. Newey pointed at monaco last year they would need 6-9 months for calibrating the simulator.
Lets see but their interviews points to that, that's why maybe they are lowering expectations on interviews
It's maths without numbers, since we don't know any of them.diffuser wrote: ↑05 Jul 2026, 03:11The only way the math works is if the weight they added to resolve the vibration issue was insignificant.avada wrote: ↑04 Jul 2026, 18:56
Horner seems less likely because he want's total control, which apparently why he was sacked from Red Bull.
Talk of Honda is carefully avoided.diffuser wrote: ↑04 Jul 2026, 17:25Right, one of the conditions for Newey joining AMR F1 was that he needed total control. Now that he has it, he's gonna give it Horner? Horner's behavior was one of the reasons Newey left RBR. None of this makes any sense when you loook at. Why would Newey recreate RBR at AMR if he left cause he didn't like it there any more? People just throw any name out.
"On the chassis side, we're quite a long way overweight. Some of that comes from the PU integration issues with Honda, "
Gone because they added something to manage vibrations, with a weight penalty. It sounds like a workaround, not a fix.
But how can they do that with the same engine? Taking so much weight out of the chassis that it compensates for the weight penalty caused by the integration issues?
Or did they find a way to otherwise deal with the vibration? It will be weird if they they found a solution for this PU, but the vibration comes back after the PU upgrade.
Remember you add weight to your wheels when you remove the vibrations from them, balance them. They put grams on to balance wheels.
That's because it's a rotating weight discrepancy problem, in that a wheel is usually manufactured within fairly good tolerance, but adding a tyre to that wheel brings natural imperfection in rubber/material distribution.avada wrote: ↑06 Jul 2026, 13:07It's maths without numbers, since we don't know any of them.diffuser wrote: ↑05 Jul 2026, 03:11The only way the math works is if the weight they added to resolve the vibration issue was insignificant.avada wrote: ↑04 Jul 2026, 18:56
However wheel balancing doesn't seem to be relevant, or even similar. The chassis doesn't spin. The crankshaft and the rotor of the MGU does, and if adding or removing a bit of weight to them, they would have done that ages ago.
I'm not that optimistic, it will take time to recover, and Newey said recently that there are a lot of things to change at AM to be a competitive team.krich wrote: ↑06 Jul 2026, 11:54i think the upgrade is acording to their data much bigger (3-4 seconds?) and they are not sure if that will correlate to track. Newey pointed at monaco last year they would need 6-9 months for calibrating the simulator.
Lets see but their interviews points to that, thats why maybe they are lowering expectations on interviews
there's no type of V-6 in which such a balance can exist ...Farnborough wrote: ↑06 Jul 2026, 13:36.... In these PU, I'd seriously doubt any of the manufacturers could not adequately "balance" the reciprocating components to ultimately fine degree, meaning that's not the problem.
