2026 Mercedes-AMG Petronas F1 Team
Re: 2026 Mercedes-AMG Petronas F1 Team
nitrotech wrote:
07 Jul 2026, 07:00
06 Jul 2026, 19:36
nitrotech wrote:
06 Jul 2026, 16:33
The problem of George lacking straight line speed is not just limited to British gp, it was there in almost every race and almost every lap. Just that it was glaringly obvious in British gp. Even in Austria race where he was leading, the gains that Kimi made was always on straights. There again, George was faster through most corners.
Maybe that is the issue. Isack Hadjar pointed this out during FP1 at Silverstone:
Isack : "The faster I go [corner], the less I have in the straights. It's unbelievable, there's no power."
Wood : "Yep, unfortunately that's the error. Go slow to go fast. Currently P1."
Despite being faster than Isack in corners, Max on average, had better straight line speed. These are laps where both were in clean air, except for one lap on one straight where Isack had power boost on overtake. Unless Isack was also driving a different PU like George or it's a "talent gap". :lol:
https://i.ibb.co/8LS81jJz/max-isack.png
I posted a comment from Isack Hadjar during FP1 and the parc ferme document seeking to provide context to the Russell- Antonelli straight line speed differences during qualifying.
Isack Hadjar burns the tires out faster than his teammate which effects the straight-line speed. Wheel spin consumes energy and being unable to run aggressive rear brake bias on worn tires limits the harvesting. It's a snowball effect which will cause straight line speed differences. I don't have any context for the random laps that you pulled but I do know that Verstappen was having a PU issue during the race:
Lambiase: “OK, Max, you’re doing a great job. Gap behind 2.2. You still have an issue with straight line so you’re making it up in corners, which is pretty good at the moment. So keep your head down, very good.
Verstappen: “Yeah, we should have just done what I said yesterday. I would have easily got to this place.”
https://www.planetf1.com/news/max-verst ... team-radio
This makes any comparisons to RBR drivers not relevant to the Merc drivers.
Beware of T-Rex
nitrotech
nitrotech
07 Jul 2026, 14:51
nitrotech wrote:
07 Jul 2026, 07:00
06 Jul 2026, 19:36
I agree. To be honest, the experience and opinion of No.2 drivers from RBR doesn't fit any narrative. They belong in a different world. It's a one car team.
Lasssept
132
zibby43
zibby43
Farnborough wrote:
07 Jul 2026, 07:27
zibby43 wrote:
06 Jul 2026, 18:21
Matt2725 wrote:
06 Jul 2026, 02:23
Not sure Kimi's issue was reliability. I suspect his car was damaged because as he's done all year, he rides his car over the kerbs a lot more aggressively than others. He broke his car riding the car over the larger green and white serrated kerbs beyond the red and white kerb on the outside of Copse.
Good point but I guess I was hoping the team would know this and ensure the car was robust enough to handle it.
With the PU regulated for minimum weight removed from equation, high % of remaining contribution is carbon composite structures. Much of this being resin component.
When they reduce weight of overall, I don't know where people think that reduction is coming from, primarily as above in removing anything they judge to be in excess of primary function. Notionally "non structural " component are first in the firing line for this process as durability can be less important, but there are limitations to how far this can go, and how much of a "thumping" it can routinely be exposed to.
Obviously being at minimum weight limit conveys advantage, and across all performance metric. The driver still has a part to play in risk reduction toward component failure though. It's still part of a driver's suite of attributes to recognise and act on this, giving consideration to unnecessary high load exposure is always part of the whole in reliability.
It would have been good to see the race played out in full, without this failure, but maybe a lesson learned from this case will pay dividend in future races.
All very reasonable and well-articulated points. I was being greedy but concede they’ve thought about the design far more than I have and it’s partially up to Kimi to unleash his speed in a way that also looks after the car.
wunderkind
wunderkind
Lasssept wrote:
07 Jul 2026, 17:59
Some autoclaves and CNC machines in Brackley are still in their original British American Racing colors.
MB_Racer
MB_Racer
Tonino wrote:
06 Jul 2026, 18:07
Hopefully the big news today is Max in, George out.
Didn’t Toto already said officially that he wanted to keep GR and KA for 2027 ?
Lasssept
132
The Race understands that Mercedes created a system whereby the drivers were given a tone in their ears when the battery got to a designated level above 0% where they had to lift off.
Having been comfortable with the process in the sim, and happy with it throughout practice, Russell and Antonelli committed to it throughout sprint and normal qualifying at Silverstone.
Lift off too late and hit 0% battery, then that means a breach of the technical rules - so likely exclusion from qualifying and starting from the back of the grid.
Waz wrote:
07 Jul 2026, 10:42
It's plausible that Kimi would not have been as quick, or kept his tires alive as long as he did without using the kerbs as he was.
Matt2725 wrote:
07 Jul 2026, 12:16
Waz wrote:
07 Jul 2026, 10:42
This was my thought going forward. Kimi will need to be a lot more careful with the kerbs, meaning he can't carry as much speed through the corners and likely reducing his pace by a fair amount.
zibby43 wrote:
08 Jul 2026, 00:12
Why is Kimi blamed for the failure of his brake shield, but George Russell just had "bad luck" when his tire had a puncture? Maybe Russell wouldn't have been as quick if he wasn't driving so hard that his tire popped.
Both of these arguments are low quality in my opinion.
Beware of T-Rex
Lasssept
132
zibby43
zibby43
09 Jul 2026, 22:53
Waz wrote:
07 Jul 2026, 10:42
Matt2725 wrote:
07 Jul 2026, 12:16
Waz wrote:
07 Jul 2026, 10:42
zibby43 wrote:
08 Jul 2026, 00:12
What caused George's puncture? Did he run over carbon? Was it curb related?
On the other hand, Kimi is known to ride the curbs aggressively and has had track limits issues at 2 circuits already this season.
Quantum
zibby43 wrote:
10 Jul 2026, 08:40
Brake Shields failures are notorious for being as prevalent as punctures and for the same reasons...right?
The stats back this up.
1 Brake shield failure in 2026.
Compared to over 10 in race punctures.
"Interplay of triads"
WardenOfTheNorth
MB_Racer wrote:
09 Jul 2026, 10:31
Tonino wrote:
06 Jul 2026, 18:07
Yes and pretty much all the reputable pundits are now saying Max missed his chance to move to Merc, thanks to Kimi showing what he's capable of, but that's not stopping all the Max to Merc shippers.....
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
WardenOfTheNorth
Lasssept wrote:
09 Jul 2026, 23:45
Funnily enough, Merc have just released their CLA AMG45 which features a wheel design called "Hamilton" :lol: :lol:
zibby43
zibby43
Quantum wrote:
10 Jul 2026, 09:06
zibby43 wrote:
10 Jul 2026, 08:40
And that settles that ha!
MB_Racer
MB_Racer
Can’t wait to have your guys & girls opinion!!
Does Mercedes have a problem when attacking / driving fast; to the limit with the W17 ?
As a remainder:
-Russell power unit breaking down Canada…
-Kimi ´s power unit in Barcelona…
-KA suspension & GR tire in Silverstone
