ISLAMATRON wrote:Its true, a properly broken in motor should have more power than a fresh lumpright off the assembly line, but with these motors a couple of installation and recon laps and scrubbing in a couple sets of tires and thatt baby is properly broken in and already reaching peak.
I think ESPI... was quoting about 2000km was about the maximum usefullness of these 2009 spec engines... I'd say they were broken in after about 50-100km
Breaking in is a bit of an unfair concept.
Bedding in is more descriptive.
Piston rings or cylinder bores are the only parts AFAIK, that need 'bedding in' on any reciprocating IC engine.
If you want to consider the history, years ago when the old two main bearing Austin Seven engine was common in racing, some engine builders built in a tighter main bearing clearance so that the crank would bend less in the middle.
Upshifts using this engine were executed when the driver heard the two middle pistons hitting the cylinder head. This established maximum revs.
I expect the Renault has similar problems.
What would Brundel know anyway?
