2026 Hybrid Powerunits
hollus
Re: 2026 Hybrid Powerunits
I am pretty sure this is not AI in the sense of what passes for AI in the last 3 years.
“The algorithm” here is probably not more than a meduim complexity excel sheet, only running in real time and not on Excel.
¡Puxa Sporting!
DDopey
DDopey
Before this generative AI that is now the hype, there was already AI, it's an umbrella term. Under it you have machine learning.
In ML you have models like, machine learning regression models. These take in a lot of parameters and then do a prediction of a value. This does not cost a lot of computation and is deterministic so this could be used. This makes most sense for the engines.
There are also a bit more of advanced ML models with deep learning, like Recurrent Neural Network (RNN) or Convolution Neural Network (CNN), depending on the complexity of the models these can also be used but require much more computation (still possible on embedded hardware, but heavier than the regression models). These are used to find hidden patterns, do classifications, image recognition and such. So depending on how sophisticated the need is this could also be used, but I dont think so.
liuzka
liuzka
I was just wondering that everyone is complaining about AI and how they do not understand it, but that is bit stupid if it’s their own work.
While ML needs usually quite big dataset I would imagine that they run it in simulator before weekend as for base “map” and then it gets fine tuned during actual driving. If it works like this it might make simulator work very important and also that simulator driving is as close to real driving would be crucial. I have no idea if simulator is driven by computer or human.
On the other hand if customer teams get their “AI” from PU manufacturer then it is totally valid criticism.
spokes
spokes
Just putting my boring solution to all these "algorithm" "ai" deployment issues into the ether...here's to hoping someone at the FIA makes this the rule :D
I think this should, and could, be solved by having power modes that are closely related to the driver's throttle pedal position, and limit the amount of modes allowed (let's say 10). This way, engineers can work on developing deployment modes specific to tracks, but the driver controls which mode he uses.
For example, you have power modes 1-10, mode 1 deploys the least amount of energy, but inversely, harvests the most. therefore focuses on harvesting. Mode "5" delivers a balanced amount of energy deployment, and recharges an equal amount, allowing drivers to charge up what the same amount they use in a lap. Mode 10 would provide the most power, but not to exceed what the driver's right foot requests.
If the driver is giving 100% throttle he's getting 100% battery deployment, or if the driver is giving 50% throttle he's giving 50% of the battery deployment etc.
In this way, engineers can setup the modes specific to the track conditions, and drivers can get dependable output, allowing them to change modes when they need something from the battery/power unit.
venkyhere
45
spokes wrote:
23 Jul 2026, 19:53
My friend, the problem in question is not 'the quantum' (rate/duration) of charge/discharge , but the 'timing' of it => 'how-much' is not the issue, 'when' is the issue. The throttle pedal is a 'suggestion' now, rather than the 'command' it used to be before. The timing is decided by a computer based on how it 'senses' the position of the car on track (GPS ? distance covered ? custom positioning signal ? I'm not sure, but whatever it is, it's based on some 'learning' from previously fed data, in tandem with actual data collected during practice).
Its the most f****ed-up way to implement ANY RACING series.
spokes
spokes
venkyhere wrote:
23 Jul 2026, 20:53
I love the way you put it! a suggestion versus a command.
Because of the nature of electric power (being able to provide instant torque), my suggestion was more so a knob on the driver's steering wheel that essentially controls how much output can be given, relative to the driver's pedal.
i.e. in Mode 1, you only ever deploy max 10% of battery output at a given time. So if you give 100% throttle, in mode 1, you only get 10% of the batteries max deployment. If you do 50% throttle (still in mode one), you only deploy 5% of the batteries max deployment. The driver still commands how much power he wants, but he has more control over how much torque can be given depending on the mode he is in.
ispano6
164
liuzka wrote:
23 Jul 2026, 19:19
Correct, most of people who talkdown "AI" don't know what LLM, generative AI, ML really mean.
The core algorithm is a machine learning model. I've had to explain this in other places but most people here haven't taken a class on machine learning or have trained their own models so they don't appreciate what AI is doing.
ML models rely on polynomial equations that iterate over many data points to plot a line of best fit and given the number of factors and how much weight is applied to them (as exponents) becomes far more complex than a simple line of best fit. Over many iterations the algorithm/graph's inflection points reach convergence after having "mapped" a finite but large set of possibilities based on or accounting for factors that occur during the race - both predictable and the intangibles. The strategy is choose the model(s) or in this case "maps" that are best suited given the changing conditions.
gearboxtrouble
gearboxtrouble
ML models aren't technically AI in my book. We've been using them for 20+ years in the financial industry and they're really just more dynamic statistical models - think regressions with benefits. Using them to optimize energy in an energy constrained formula is a no brainer and they were almost certainly used in the last engine rules as well. The difference is sub optimal behavior is far more visible because you're talking about a loss of 450hp instead of a loss of 80hp in the old rules (MGUH could make up 80hp to the MGUK at full throttle). This feels like another red herring to divert attention away from the fundamental problem of this ruleset - the ICE component is undersized relative to the electrical component. No amount of software fiddling will change that and even the painful, long drawn out move to 60/40 will only help on the margins at places like Spa and Silverstone. To at least recover some driver agency they could maybe replace automated deployment with a two stage accelerator pedal where there is an easy and repeatable way to control when energy is deployed for the driver. We'll still be this energy starved disaster but at least when something goes awry it will be on the driver and not some computer.
